top strut mount
Old 10-06-2011, 11:16 PM   #1
tacomazach [OP] tacomazach is offline
tacomazach has a spectacular aura abouttacomazach has a spectacular aura about
tacomazach's Avatar
tacomazach's Tacoma Gallery
top strut mount
I'm about to replace my coils and shocks. would it be easier to order a new top strut mount, or should I just use the factory strut mount? Would rockauto's monroe strut mount be ok to use? http://www.rockauto.com/catalog/moreinfo.php?pk=1129714
Old 10-06-2011, 11:17 PM   #2
braaap
steve o 77's Avatar
steve o 77's Tacoma Gallery
I reused it
disregard the pic
Old 02-22-2013, 02:43 AM   #3
VazBro is on a distinguished road
VazBro's Avatar
VazBro's Tacoma Gallery
Hi,
I am a new member and I am about to do the same. I have ordered the OME supesnion kit and I don't want to deal with the spring compressor. Can I use the Monroe strut mount in the link above or this one? (click on the link).
Also, what is the Toyota OEM strut mount part number? I have a 2013 Tacoma DC 4x4.
Thanks in advance
http://www.partsgeek.com/gbproducts/...Fel7QgodH0sAuw
Old 09-27-2013, 01:24 PM   #4
dcmichell is on a distinguished road
Army: Retired Medic
dcmichell's Tacoma Gallery
Failed Strut
New here to the forum; I don't want to hijack a thread, but also don't want to start a new one on the subject of "strut mount".
So I had OEM struts and bearing plates/mounts installed in my 2002 4x4 Xtra Cab two weeks ago. Day before yesterday hit a small pothole going through a residential area at about 20mph and you can see the result in the pic.
Does anyone know if this would be due to a faulty strut or a faulty bearing plate/mount?
Old 09-27-2013, 01:34 PM   #5
Mr Salty is one of the sharper tools in the shedMr Salty is one of the sharper tools in the shedMr Salty is one of the sharper tools in the shedMr Salty is one of the sharper tools in the shedMr Salty is one of the sharper tools in the shedMr Salty is one of the sharper tools in the shedMr Salty is one of the sharper tools in the shedMr Salty is one of the sharper tools in the shedMr Salty is one of the sharper tools in the shedMr Salty is one of the sharper tools in the shedMr Salty is one of the sharper tools in the shed
Mr Salty's Avatar
Mr Salty's Tacoma Gallery
Holy crap man!
Need more pics so we can see whats going on.
For one, those don't look like factory bushings and two it sure seems like theres a lot of thread up top (possibly the strut was over torqued). The reason I mention the bushings is because if they are poly they don't compress as easy as the rubber ones and with that much thread that bolt had to be torqued on pretty darn tight.
Old 09-27-2013, 01:43 PM   #6
Mr Salty's Avatar
The bushings will be shot, I'd just get all new assemblies with washers and bushings if I were you. They are not that much at all
Aside from monroe, KYB probably carries them. Perhaps even moog. The Monroes are good though and I actaully like the quality of their studs over KYB.
Old 09-27-2013, 03:12 PM   #7
Army: Retired Medic
I'm in the process of moving and am currently living 850 miles from all my tools; I have a local shop repairing it. I've asked them to make sure they don't toss any of the parts they pull off, so I'll get some pics of the failed parts to see if that sheds any more light.
I'm just salty 'cause they were just installed two weeks ago and are warrantied for one year - the only problem is that I'm four hours away from the nearest authorized shop to service under warranty!
My hope is that when I take the parts and pics in to the shop that did the work, the guy will treat me fair and at least refund the cost of the parts.
Thanks for the insight, I'll compare the amount of exposed threads to the one on the other side for sure!
strut top plate 04quad 1st Gen. Tacomas 0 07-25-2011 01:43 PM
Top strut plates surfrat Suspension 3 03-06-2010 10:24 AM
WTB: 07-09 front strut hardware (top nut, top coil retention plate with rubber).... sincitytaco Buy / Sell / Trade 4 06-01-2009 02:13 PM
Rotating top of strut? mr.g Suspension 7 05-17-2009 10:26 AM
Wanted: 2005+ OEM Strut Mount- Top Brunes Buy / Sell / Trade 2 05-03-2009 05:43 PM
