Extended travel worth it?
Old 10-07-2011, 03:02 PM   #1
tacundra [OP] tacundra is offline
tacundra is on a distinguished road
tacundra's Tacoma Gallery
Just picked up a new to me 07 DCSB 4x4.
I have run spacers, fagtech's, bilstein's, sway-a-way's and Icon's on prior tacoma's.
I have never run an extended travel coilover with the UCA. I know it will help with alignment when going 3" on the lift.
Is the extra droop travel worth the extra expense for the UCA? what say you?
Trying to decide which way I am going with suspension this time.
Old 10-07-2011, 03:09 PM   #2
Banned
97yota4wd is one of the sharper tools in the shed97yota4wd is one of the sharper tools in the shed97yota4wd is one of the sharper tools in the shed97yota4wd is one of the sharper tools in the shed97yota4wd is one of the sharper tools in the shed97yota4wd is one of the sharper tools in the shed97yota4wd is one of the sharper tools in the shed97yota4wd is one of the sharper tools in the shed97yota4wd is one of the sharper tools in the shed97yota4wd is one of the sharper tools in the shed97yota4wd is one of the sharper tools in the shed
97yota4wd's Tacoma Gallery
yes!!
ext travel FTMFW
Old 10-07-2011, 03:20 PM   #3
The Mad Scientist
jberry813 is one of the sharper tools in the shedjberry813 is one of the sharper tools in the shedjberry813 is one of the sharper tools in the shedjberry813 is one of the sharper tools in the shedjberry813 is one of the sharper tools in the shedjberry813 is one of the sharper tools in the shedjberry813 is one of the sharper tools in the shedjberry813 is one of the sharper tools in the shedjberry813 is one of the sharper tools in the shedjberry813 is one of the sharper tools in the shedjberry813 is one of the sharper tools in the shed
jberry813's Avatar
jberry813's Tacoma Gallery
The answer, as normal, is it depends on you, the driver.
If you're a mall crawler, or even only go offroading once a year, then no not worth it. If you actually wheel your truck on any regular basis and want to get the most out of it, then yes. I beat the shit out of my midtravel setup and it was well worth the coin.
If you end up with a uniball UCA, there will be more cleaning/maintenence involved than a regular ball joint. However the benifits are of course the extra travel/articulation and the ability to actually get your caster back into spec.
Old 10-07-2011, 03:24 PM   #4
I do wheel...I probably wont beat my 07 as bad as this one:
Old 10-07-2011, 03:30 PM   #5
Banned
i think you would be better off going with long travel lol
Old 10-10-2011, 03:45 PM   #6
Anyone run both extended and standard travel? What is your opinion?
Old 10-10-2011, 03:48 PM   #7
Max's Canadian Twin
theduck911 is one of the sharper tools in the shedtheduck911 is one of the sharper tools in the shedtheduck911 is one of the sharper tools in the shedtheduck911 is one of the sharper tools in the shedtheduck911 is one of the sharper tools in the shedtheduck911 is one of the sharper tools in the shedtheduck911 is one of the sharper tools in the shedtheduck911 is one of the sharper tools in the shedtheduck911 is one of the sharper tools in the shedtheduck911 is one of the sharper tools in the shedtheduck911 is one of the sharper tools in the shed
theduck911's Avatar
theduck911's Tacoma Gallery
PM member pAP
He had stock length Coilovers (Walker Evan's) and now has Fox Ext. Travel, he could give you a good Idea of the difference.
Old 10-10-2011, 03:52 PM   #8
The Mad Scientist
jberry813's Avatar
I've ran both. I'll answer "opinion" with my previous statement. It's obviously called an upgrade for a reason.
Icon Extended Travel SAIRS Suspension 8 01-04-2012 01:39 PM
Which size extended travel? SETX Suspension 8 12-06-2011 10:26 AM
Extended travel vs. Standard Tacoma mud 1st Gen. Tacomas 12 07-30-2011 01:34 PM
2.0 SAW Extended Travel Rear Shocks SC4333 2nd Gen Tacoma Marketplace 4 03-02-2011 05:29 PM
Icon extended travel with 4x4 HB52taco Suspension 12 05-11-2010 06:58 PM
