3" lift vs 6" lift
Old 10-13-2011, 12:44 AM   #1
R o C C o 5 7 has much to be proud ofR o C C o 5 7 has much to be proud ofR o C C o 5 7 has much to be proud ofR o C C o 5 7 has much to be proud ofR o C C o 5 7 has much to be proud ofR o C C o 5 7 has much to be proud ofR o C C o 5 7 has much to be proud ofR o C C o 5 7 has much to be proud ofR o C C o 5 7 has much to be proud ofR o C C o 5 7 has much to be proud of
R o C C o 5 7's Avatar
R o C C o 5 7's Tacoma Gallery
3" lift vs 6" lift
I have a 2.5 spacer kit om my 08 4x4 tacoma with 285 tires.Now I want to up grade to a 6" lift,but many experts are telling me to go with a 3" lift,but I see all these cool tacomas with 6" lifts.Dude at latest 4x4 expo told me you have to cut the frame for a 6" lift. What's up with that?
Old 10-13-2011, 12:48 AM   #2
Lest We Forget
cmack cmack cmack cmack cmack cmack cmack cmack cmack cmack cmack
cmack's Tacoma Gallery
For a 6" lift you gotta cut the front crossmember. It's a DB (drop bracket) lift. You in turn have less than stock clearance on the bottom. So more or less, if it's a street truck and it's solely for looks, go for it. If you are into offloading, do a good 3" lift and run 33s. Or hell, some guys even have gotten away with 35s on a 3" lift.
Old 10-13-2011, 12:50 AM   #3
nofords08 is one of the sharper tools in the shednofords08 is one of the sharper tools in the shednofords08 is one of the sharper tools in the shednofords08 is one of the sharper tools in the shednofords08 is one of the sharper tools in the shednofords08 is one of the sharper tools in the shednofords08 is one of the sharper tools in the shednofords08 is one of the sharper tools in the shednofords08 is one of the sharper tools in the shednofords08 is one of the sharper tools in the shednofords08 is one of the sharper tools in the shed
nofords08's Tacoma Gallery
or some guys wheel the shit out of drop bracket lifts, and i only have 2" less ground clearance than my friends taco with the all pro LT kit and same size tires
Old 10-13-2011, 12:51 AM   #4
ColtsTRD's Avatar
ColtsTRD's Tacoma Gallery
6" lifts require a drop bracket and thats why most guys including myself aren't fond of them. Thats why the majority of us go with the 3" lift.
Old 10-13-2011, 12:52 AM   #5
Superior Member
707tothe907 is one of the sharper tools in the shed707tothe907 is one of the sharper tools in the shed707tothe907 is one of the sharper tools in the shed707tothe907 is one of the sharper tools in the shed707tothe907 is one of the sharper tools in the shed707tothe907 is one of the sharper tools in the shed707tothe907 is one of the sharper tools in the shed707tothe907 is one of the sharper tools in the shed707tothe907 is one of the sharper tools in the shed707tothe907 is one of the sharper tools in the shed707tothe907 is one of the sharper tools in the shed
707tothe907's Avatar
707tothe907's Tacoma Gallery
Mad bro?
Sorry.. Had to.
Old 10-13-2011, 12:53 AM   #6
ColtsTRD's Avatar
Originally Posted by 707tothe907 View Post
Mad bro?
Sorry.. Had to.
he doesn't get mad
Old 10-13-2011, 12:53 AM   #7
Mad bro?
Sorry.. Had to.
haha no im not mad, just stating my opinion
Old 10-13-2011, 12:53 AM   #8
ColtsTRD's Avatar
seeeee...told ya!
Old 10-13-2011, 12:54 AM   #9
Originally Posted by ColtsTRD View Post
he doesn't get mad
only when i dont get service while posting and pooping do i get "mad"
sorry OP didnt mean to turn your thread to shit, me and scott just like posting about poops
Old 10-13-2011, 12:58 AM   #10
Lest We Forget
Also, something to keep in mind:
If you ever want to remove the 6" and put it either back to stock or run a 3" lift, it requires a lot more work than putting a 3" lift on and removing if ever wanting to go back to stock or change the setup. Just an FYI.
Old 10-13-2011, 12:59 AM   #11
i know all about this
Old 10-13-2011, 01:00 AM   #12
if you have to ask, u can't afford it
tacobo670 is one of the sharper tools in the shedtacobo670 is one of the sharper tools in the shedtacobo670 is one of the sharper tools in the shedtacobo670 is one of the sharper tools in the shedtacobo670 is one of the sharper tools in the shedtacobo670 is one of the sharper tools in the shedtacobo670 is one of the sharper tools in the shedtacobo670 is one of the sharper tools in the shedtacobo670 is one of the sharper tools in the shedtacobo670 is one of the sharper tools in the shedtacobo670 is one of the sharper tools in the shed
tacobo670's Avatar
tacobo670's Tacoma Gallery
i got procomp stage II. i wheel the shit outta my truck. i guess the only thing i worry about is hitting the front cross members n the rear axle when wheeling. other than that, there is alot of clearance IMO. i also decided to invest in sliders... just in case. also one bad note is that the 6in has a higher center of gravity n is less maneuverable around obstacles, but thats where if ur careful u can just crawl over it.
Old 10-13-2011, 01:02 AM   #13
tacobo670's Avatar
... also the tire size will give u a little bit more clearance. taller tire=taller truck. Correct?
Old 10-13-2011, 01:04 AM   #14
bingo!
Old 10-13-2011, 01:04 AM   #15
Lest We Forget
Taller tires will infact add ground clearance. For example, if you go from a 31" tire to a 33" tire, you're adding an 1" of ground clearance.
Old 10-13-2011, 01:05 AM   #16
ColtsTRD's Avatar
Its true....I shit a squirrel today...poor lil feller
Old 10-13-2011, 01:05 AM   #17
tacobo670's Avatar
hooray! like a good neighbor, state farm is there... with a giant stuffed panda bear!
Old 10-13-2011, 01:06 AM   #18
Slamry
1337Taco is one of the sharper tools in the shed1337Taco is one of the sharper tools in the shed1337Taco is one of the sharper tools in the shed1337Taco is one of the sharper tools in the shed1337Taco is one of the sharper tools in the shed1337Taco is one of the sharper tools in the shed1337Taco is one of the sharper tools in the shed1337Taco is one of the sharper tools in the shed1337Taco is one of the sharper tools in the shed1337Taco is one of the sharper tools in the shed1337Taco is one of the sharper tools in the shed
1337Taco's Avatar
1337Taco's Tacoma Gallery
Yes, but a 3" lift will still have more ground clearance than a 6" drop bracket lifted one.
Old 10-13-2011, 01:07 AM   #19
i think i ate your chocolate covered squirrel
Old 10-13-2011, 01:07 AM   #20
ColtsTRD's Avatar
x2
and you CAN fit 35s on a 3" lift...just gotta trim and cut like a mother fucker!
Fitment: 07 with a 3" lift 33"12.5" 17" Saskyota Wheels & Tires 9 01-16-2014 12:17 PM
Let me see your DC's with 265 duratracs on 2.5" front lift with 2" rear lift BenWA 2nd Gen. Tacomas 8 11-08-2013 01:55 PM
Can I add a 2" body lift to my 3" suspension lift and not have problems with the VSC blue86gt 2nd Gen. Tacomas 17 08-10-2011 11:14 PM
Toytec 3" Spacer Lift w/ AAL or the Pro Comp 3" Suspension Lift hawaiian_fantasy Suspension 1 04-12-2010 04:30 PM
= => Will A "SPINDLE" Lift Help my Rubbing? 285/70/17 w/4.5 BS @ 2.5 Lift <= = RAD 2nd Gen. Tacomas 21 11-03-2009 11:44 PM
