3 inch lift with 35's????
Discussion in 'Suspension' started by francis1291, Oct 13, 2011.
  1. Oct 13, 2011 at 3:50 PM
    francis1291
    francis1291 [OP] Well-Known Member
    10 4x4 SR5 super white
    3" procomp lift wit 20" rockstars on 33 toyo mt's
    I have a pro comp 3 inch lift and i am trying to trade or sell my 33's and I have a guy offered to tradae me 35's federals and I am just curious can i fit them with out trimming alot? My 33's only scrub when I back up and the mud flap but I trimmed them mud flap so they only rub when I back up for some reason. I am not wanting to trim my bumper of anything major. If needed i will take more pictures of what I have if it helps. I think It will only be a 1" difference with the tire since its a circle. I think
    Thanks, Trevor
  2. Oct 13, 2011 at 3:52 PM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    cut cut cut
  3. Oct 13, 2011 at 3:57 PM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    go buy a grinder with a cutting wheel.
    aka no they wont fit with minimal cutting
  4. Oct 13, 2011 at 3:58 PM
    Sublime
    Sublime Well-Known Member
    Phoenix, AZ
    08 TRD 4x4
    Dude, you'll have to cut lots on the inner fenders, beat the pich weld back, cab mount chop, ditch the flares as they will tear up, and possibly need to cut the firewall and reinforce it back. Search under 35's with 3" lift. It's all in there. Re-gear to 4.56's for sure too!
  5. Oct 13, 2011 at 3:59 PM
    creedler
    creedler Well-Known Member
    Max
    Eugene, Oregon
    Stock for now
    Old build in sig
    so much cutting you better buy an industrial sized grinder or something :D you will also probably have to use wheel spacers and have a body mount chop done.
  6. Oct 13, 2011 at 3:59 PM
    francis1291
    Why y'all saying cut? If I take the flap off it looks like they might fit.
  7. Oct 13, 2011 at 4:06 PM
    ATriplett513
    ATriplett513 Well-Known Member
    Phoenix, AZ
    2011 Dbl Cb, 4x4, 4.0L, 6-speed
    Looks like you already have your answer.
    Trade and post some pics.
  8. Oct 13, 2011 at 4:12 PM
    1337Taco
    1337Taco Well-Known Member
    Kevin
    NorCal
    2015 4X4 Manual
    Wheel spacers will make you rub so much more, do not get wheel spacers.
  9. Oct 13, 2011 at 4:17 PM
    Rebel Taco 22
    Rebel Taco 22 mall crawler
    Search, this has been discussed. Yes, you will have to cut. A lot.
  10. Oct 13, 2011 at 4:18 PM
    senor taco
    senor taco ROLLIN ON RUST
    Steve
    Monterey Bay, Ca
    O7 Tacoma PreRunner SR5
    17in fj cruiser wheels satoshi grille with devil horns emblem Single in double out 50 series flowmaster with stainless tips Kenwod ddx512 double din touch screen DVD reciver with a single Rockford fosgate 12 in sub with an alpine amp tinted tail and third break light silverstar head and fog lights k&n drop in Billy 5100's on all 4 corners with a 2"AAL
  11. Oct 13, 2011 at 4:18 PM
    97yota4wd
    Eric
    Mesa, AZ
    DO IT DO IT!!
  12. Oct 13, 2011 at 4:24 PM
    francis1291
    I have 1/4 wheel spacer on it now.
  13. Oct 13, 2011 at 4:26 PM
    motorsport36
    motorsport36 Black Lights Matter
    Jason
    Furnace, AZ
    98 SR5 AC 4x4
  14. Oct 13, 2011 at 6:08 PM
    Blacktacoma23
    Blacktacoma23 If your tires don't rub you can fit bigger tires
    CO
    2011 Mall Crawler/84'
    6" BDS DB, 37", Dirt King, Total chaos UCA's w/ Heims, Fox c/o's, 4-banger fenders, 37" Nittos, 4.88 w/ rear ARB, AP Expos, 17x9 Method beadlocks, cab mount relocation, "Insain fab" tub, 5% tint, 10" Rockford Fosgates, Magnaflow 18" custom catback exhaust, AFE intake, Trail Gear bumper, Crown brake lines F/R
    Not yet, I have 34's on right now. But my AP fenders are getting installed, Then ill run 35" MTR's
    hate to break the news but you will have to remove the flares/do the cabmount chop ect...
  15. Oct 13, 2011 at 7:23 PM
    Sublime
    Phoenix, AZ
    08 TRD 4x4
    Sick truck man! So you were good with 34's?
  16. Oct 13, 2011 at 8:03 PM
    francis1291
    I just called pro comp and the said what size rim would be best so I bought them and only rub the mud flap. Sounds like im lucky I guess since I didn't do no trimming.
  17. Oct 13, 2011 at 8:05 PM
    brian
    brian Another Traitor
    Elizabeth City, NC
    2017 F-250 Powerstroke
    How wide are your 35's? The curious is peaking on wether or not I could clear 285/75/17's now..... thats a 34x11.5. I need every bit of clearance I can gain with my long ass truck! I will be due for tires soon.
  18. Oct 13, 2011 at 8:06 PM
    1337Taco
    Kevin
    NorCal
    2015 4X4 Manual
    Do you wheel? You will definitely rub while offroad.
  19. Oct 13, 2011 at 8:07 PM
    1337Taco
    Kevin
    NorCal
    2015 4X4 Manual
    Do it Brian! JLee and I could help you get those things to fit no problem. :D
  20. Oct 13, 2011 at 8:09 PM
    jandrews
    '09 FourDubDee TRD OR
    "fitting" for over the road driving is not the same as fitting over anything but asphalt.
    Hope you never hit a pothole.
    33s rub a little. 35s rub a fuckton and require a lot of cutting. When my current tires wear out, I'll be going to slim 34s (34x11 or so). I'll keep everyone posted.
