6 inch pro comp lift with Icon coilover and AllPro Chromoly UCA
Old 10-18-2011, 07:40 PM   #1
Tacochaos [OP] Tacochaos is offline
Tacochaos is on a distinguished road
Tacochaos's Tacoma Gallery
Just recently got my truck lifted exactly how i wanted. 6 inch pro comp lift, Icon coilover and the UPC from ALLPRO. I'm also rolling on Ballistic Jesters. Is anyone else running These UCA from ALLPRO? They "skweek" like a Mother f*****
Old 10-18-2011, 07:43 PM   #2
PLC721 is one of the sharper tools in the shedPLC721 is one of the sharper tools in the shedPLC721 is one of the sharper tools in the shedPLC721 is one of the sharper tools in the shedPLC721 is one of the sharper tools in the shedPLC721 is one of the sharper tools in the shedPLC721 is one of the sharper tools in the shedPLC721 is one of the sharper tools in the shedPLC721 is one of the sharper tools in the shedPLC721 is one of the sharper tools in the shedPLC721 is one of the sharper tools in the shed
PLC721's Tacoma Gallery
not sure about the squeaking but thats a nice set up you got on a 6" lift
Old 10-18-2011, 07:55 PM   #4
btw when was the last time you greased bushings?
Old 10-18-2011, 08:14 PM   #5
Max's Canadian Twin
theduck911 is one of the sharper tools in the shedtheduck911 is one of the sharper tools in the shedtheduck911 is one of the sharper tools in the shedtheduck911 is one of the sharper tools in the shedtheduck911 is one of the sharper tools in the shedtheduck911 is one of the sharper tools in the shedtheduck911 is one of the sharper tools in the shedtheduck911 is one of the sharper tools in the shedtheduck911 is one of the sharper tools in the shedtheduck911 is one of the sharper tools in the shedtheduck911 is one of the sharper tools in the shed
theduck911's Avatar
theduck911's Tacoma Gallery
Uniballs squeak at low speeds, but also grease your bushing in your upper control arms. DO NOT GREASE the uniball.
Old 10-18-2011, 08:17 PM   #6
S.B. is one of the sharper tools in the shedS.B. is one of the sharper tools in the shedS.B. is one of the sharper tools in the shedS.B. is one of the sharper tools in the shedS.B. is one of the sharper tools in the shedS.B. is one of the sharper tools in the shedS.B. is one of the sharper tools in the shedS.B. is one of the sharper tools in the shedS.B. is one of the sharper tools in the shedS.B. is one of the sharper tools in the shedS.B. is one of the sharper tools in the shed
S.B.'s Avatar
S.B.'s Tacoma Gallery
You can spray the uniball with some Dupont Teflon lube. It gets rid of the squek. Also it could me your bushings, make sure you don't ocer grease them, they are super picky.
Old 10-18-2011, 08:59 PM   #7
Originally Posted by Blacktacoma23 View Post
Shit nice truck, Ive always wanted those wheels.
Im lucky to have them, These wheels are on back order nation wide for 2 months.
Old 10-18-2011, 09:01 PM   #8
Where can i get Dupont teflon lube?
Old 10-18-2011, 09:19 PM   #9
They should have been greased when the shop put my UCA on.. At least i hope they did. Nice truck by the way!!
Old 10-18-2011, 11:16 PM   #10
the full Monty
Manwithoutaplan is one of the sharper tools in the shedManwithoutaplan is one of the sharper tools in the shedManwithoutaplan is one of the sharper tools in the shedManwithoutaplan is one of the sharper tools in the shedManwithoutaplan is one of the sharper tools in the shedManwithoutaplan is one of the sharper tools in the shedManwithoutaplan is one of the sharper tools in the shedManwithoutaplan is one of the sharper tools in the shedManwithoutaplan is one of the sharper tools in the shedManwithoutaplan is one of the sharper tools in the shedManwithoutaplan is one of the sharper tools in the shed
Manwithoutaplan's Avatar
Manwithoutaplan's Tacoma Gallery
how much where those uc all pro???
Old 10-18-2011, 11:19 PM   #11
ktmrider is one of the sharper tools in the shedktmrider is one of the sharper tools in the shedktmrider is one of the sharper tools in the shedktmrider is one of the sharper tools in the shedktmrider is one of the sharper tools in the shedktmrider is one of the sharper tools in the shedktmrider is one of the sharper tools in the shedktmrider is one of the sharper tools in the shedktmrider is one of the sharper tools in the shedktmrider is one of the sharper tools in the shedktmrider is one of the sharper tools in the shed
ktmrider's Avatar
ktmrider's Tacoma Gallery
Triflow dry lubricant is what I used on my OE replacement UCAS and my LT kit and they make the uniballs silent, you can buy it here
http://www.wheelersoffroad.com/05uptacotc.htm
Old 10-19-2011, 07:38 AM   #12
Out the door $600
Old 10-19-2011, 10:42 AM   #13
Originally Posted by PSU Taco85 View Post
For the squeak, hopefully they were greased good before installing. And nice setup! Looks like you have a buttload of preload on those shocks though..how is the ride?
The ride is a bit stiff, i cant tell if its because they are new and need to be broken in or i need to play with the preload....
Old 10-27-2011, 12:58 AM   #14
Biker Trash
2WheelDave is on a distinguished road
2WheelDave's Avatar
Law Enforcement: 5149 1/2
2WheelDave's Tacoma Gallery
I recently installed their Uppers as well. I've been considering the same Coil Overs, but am on the fence and tired of repair after repair after repair. $pent way too much in $u$pen$ion fixes, due to Pro-Comp 6" lift i$$ue$. So gonna lay low for awhile on the wheeling. I've already destroyed my $teering on my 2011 with only 14k miles. Replaced the rack and pinion, broke several tie rods and finally upgraded to DOM tubing with heim joints. Broken rear lift blocks and the replacement are cracked now. So here comes another $600 for leaf packs. $ounds like I have lower ball joint issues ready to fail now as well. But it can wait. Had to temporarily use 1 1/4" wheel spacers, because my tires rubbed big time on the sway bar after installing the UCA's. Ever try driving yours on the street without the swaybar? Make sure you're sober if you do! It's just fine when you're wheeling, so gotta get quick disconnects too! $$$. So, with that in mind and about $7k in upgrades and repairs in only ONE year...I'd do it all over again. Cuz I still kept up and blazed the hoards of boulders and granite that my fellow Jeeper buddies said I could never do in my 'perty lifted Tacoma'! Even without lockers and never got wenched! At least I always won the bet and drank free beer at the end of the day. Good luck! ! And Remember..."Live to Wheel, Wheel to Live".
Old 10-27-2011, 01:17 AM   #15
Biker Trash
2WheelDave's Avatar
Oh ya, regarding any noise issues. You will pick up more road noise from the Uniballs, poly bushings and the DOM tubing in the Uppers. Depending on your environment and wheeling conditions, use a dry teflon lubricant on them, because the top holds debris like a wishing well, so get in the habit of wiping them out at the end of the day. All-Pro used to sell a cap to go on top, but it was junk and people used some 'One-size-fits-all' type Daystar poly tie rod dust boot that works better, so All-Pro discontinued them. I use synthetic grease for the bushings. Works awesome and it's even red to match the bushings! lol
Old 10-30-2011, 03:06 PM   #16
Zombie Killer!
705 Taco is one of the sharper tools in the shed705 Taco is one of the sharper tools in the shed705 Taco is one of the sharper tools in the shed705 Taco is one of the sharper tools in the shed705 Taco is one of the sharper tools in the shed705 Taco is one of the sharper tools in the shed705 Taco is one of the sharper tools in the shed705 Taco is one of the sharper tools in the shed705 Taco is one of the sharper tools in the shed705 Taco is one of the sharper tools in the shed705 Taco is one of the sharper tools in the shed
705 Taco's Avatar
705 Taco's Tacoma Gallery
Dude you're hard core. I like the Pro Comp kit but it's really not built for hard core wheeling. It's more for the lifted street truck crowd.
Old 10-31-2011, 06:39 PM   #17
I finally went out and bought some synthetic grease for my bushing and it cured all the awful noise i was getting. apparently my bushings never got greased when my UCA were put on. If anyone is considering ALLPROs UCA I would highly recommend them.
Old 10-31-2011, 06:45 PM   #18
Im also using 1 1/4 wheel spacers at the moment because im a dumb ass and got the wrong back spacing on my wheels. My buddy is running the icons on his taco and is also using no sway bar. he has had his icons for over a year and does some serious offroading with his truck. The icons have done an amazing job holding up to his abuse. I would recommend them. where can you get quick disconnects for the sway bar?
3 inch Pro Comp Lift silvertaco13 2nd Gen. Tacomas 29 01-28-2015 07:49 PM
Pro Comp 6 inch lift justin_birch Suspension 25 06-22-2013 08:54 AM
3 inch Pro Comp Lift? eztrucken Suspension 7 08-28-2012 10:21 PM
Pro comp or icon coilover? KingofRedwood Wheels & Tires 24 08-10-2011 03:12 PM
3 inch Pro Comp Lift silvertaco13 2nd Gen. Tacomas 1 11-08-2010 01:47 PM
