New Tires = slight body rub so I ordered some 5100s
Old 11-01-2011, 11:45 AM   #1
bgsmith [OP] bgsmith is offline
bgsmith will become famous soon enough
bgsmith's Avatar
bgsmith's Tacoma Gallery
Ok so I recently installed some new wheels and tires with spacers, so the wheels wouldn't rub the calipers, now I am experiencing some slight body rub. Was going to eventually order some 5100s to level my truck out anyway so I went ahead and ordered them now, what would you suggest is the best setting on the stock coils. I would like to go 1.75 with them for maximum clearance but don't want my truck to be too high in the front as the rear is staying stock for now (my little wheel and tire project has ended up costing me a small fortune so far).
I have searched a ton of this and got a lot of info but would just like some opinions and maybe some pics of trucks with stock rears and the 5100s in the front.
Old 11-01-2011, 11:56 AM   #2
TW's Official anti body-lift pundit
TacoMX is one of the sharper tools in the shedTacoMX is one of the sharper tools in the shedTacoMX is one of the sharper tools in the shedTacoMX is one of the sharper tools in the shedTacoMX is one of the sharper tools in the shedTacoMX is one of the sharper tools in the shedTacoMX is one of the sharper tools in the shedTacoMX is one of the sharper tools in the shedTacoMX is one of the sharper tools in the shedTacoMX is one of the sharper tools in the shedTacoMX is one of the sharper tools in the shed
TacoMX's Avatar
EMS: Paramedic
TacoMX's Tacoma Gallery
first notch above stock should level out the truck and help clear the tires.
Old 11-01-2011, 12:02 PM   #3
bgsmith's Avatar
Probably a dumb question, but can they be adjusted while on the truck, or do you have to take apart the whole coil/shock in order to do so?
Old 11-01-2011, 12:04 PM   #4
:POOPCORN:
98tacoma27's Avatar
Marines:
98tacoma27's Tacoma Gallery
Nope, they have to be apart.
Old 11-01-2011, 12:05 PM   #5
DevilDogTacoma is a splendid one to beholdDevilDogTacoma is a splendid one to beholdDevilDogTacoma is a splendid one to beholdDevilDogTacoma is a splendid one to beholdDevilDogTacoma is a splendid one to beholdDevilDogTacoma is a splendid one to beholdDevilDogTacoma is a splendid one to behold
DevilDogTacoma's Avatar
Law Enforcement: Police officer in MD and Marine in B Co 4th LAR Bn
DevilDogTacoma's Tacoma Gallery
My truck with 5100s on all 4 corners, fronts set at 1.75", no TSB or AAL in the rear, and 265/65/17 General Grabber AT2s on XD Addicts. I had a tiny bit of fender rub when turning in reverse, but I just grabbed a hack saw and trimmed off the plastic piece at the front of the wheel wells.
Old 11-01-2011, 12:14 PM   #6
bgsmith's Avatar
Thanks for the pick, yeah I was rubbing a ton on the fenders, trimmed them back, still needs more though. Big concern on the rubbing on the frame which is why I picked up the 5100s for the front.
Old 11-01-2011, 12:15 PM   #7
bgsmith's Avatar
Figured as much, thanks.
Slight Tire Rub - Rear Block??? Jah310 Suspension 15 01-07-2013 04:19 PM
Body mount Rub / Chop help ffemt2987 2nd Gen. Tacomas 5 12-10-2011 06:13 PM
Tires rub body mount after LR UCA install, will more castor help? Dr.D Suspension 30 10-29-2011 03:16 PM
285/75/16 tires, rub or no rub??? lepedog23 2nd Gen. Tacomas 8 06-13-2010 10:00 AM
ordered my 5100s David Tarantino Suspension 16 10-29-2008 08:09 PM
