spindles + coilovers??
Old 11-13-2008, 10:23 AM   #1
dabighi [OP] dabighi is offline
dabighi has a little shameless behaviour in the past
dabighi's Tacoma Gallery
so im lookin at total chaos' site and they now make a pair of 3.5" lift spindles for the 2nd gen tacos. they say that these can be paired with aftermarket coilovers for up to 6" of lift. hows this possible dont really understand it. are there any negatives to doing it? like crappy alignment, destroying bushings or links at a faster rate?
Old 11-13-2008, 12:30 PM   #2
Mod'n on a Budget
1BlkT is one of the sharper tools in the shed1BlkT is one of the sharper tools in the shed1BlkT is one of the sharper tools in the shed1BlkT is one of the sharper tools in the shed1BlkT is one of the sharper tools in the shed1BlkT is one of the sharper tools in the shed1BlkT is one of the sharper tools in the shed1BlkT is one of the sharper tools in the shed1BlkT is one of the sharper tools in the shed1BlkT is one of the sharper tools in the shed1BlkT is one of the sharper tools in the shed
1BlkT's Avatar
1BlkT's Tacoma Gallery
It's definitely possible. I mean I have the Allied's combined with a Bilstein Coilover. It gave me about 6.5'' of lift up front so I've since then adjusted the coilovers down so there isn't as much of a rake. I'm not really sure how to explain how it works but there are more knowledgeable people on here that will chime in.
Old 11-13-2008, 02:01 PM   #3
Any dog under 50# is a cat and cats are useless...
jhodge83's Tacoma Gallery
from what i understand....the lift spindles lower the tires toward the ground, while keeping all the hookups and connections at stock. then the coilovers lift it like it would a stock vehicle. the lowering spindles on other vehicles work the same way by raising the tires and keeping everything else stock
Old 11-13-2008, 02:08 PM   #4
MASTER KNUCKLE BLEEDER
TRDATER will become famous soon enough
TRDATER's Avatar
TRDATER's Tacoma Gallery
Spidle lifts are very common on 4x4 and 2 wheelers they drop the location of the spindle , this elimates the need to lower control arms. You can combine the two, i would check angles after adjustments,
Old 11-13-2008, 02:12 PM   #5
chris4x4's Avatar
chris4x4's Tacoma Gallery
Cant run a spindle lift on the second gen. 4x4's. There is no place for the front shafts to pass thru.
Old 11-13-2008, 03:00 PM   #6
TRDATER's Avatar
As long as lowers would be dropped with crossmember it is possible for a spindle lift,
Old 11-13-2008, 03:15 PM   #7
mjp2's Avatar
mjp2's Tacoma Gallery
Methinks your geometry is off.
Old 11-13-2008, 03:21 PM   #8
TRDATER's Avatar
All 6 inch generation 2 lifts are drop spindles with new lower control arm cross members.
Old 11-13-2008, 03:21 PM   #9
chris4x4's Avatar
Lift spindles have no provision for the front drive shafts to pass thru. You can put the lowers whereever you want, the drive shaft cant pass thru a hole that does not exist.
Methinks I agree with you.
Old 11-13-2008, 03:24 PM   #10
chris4x4's Avatar
OK, now thats different from what the OP was talking about. He was talking about the 3.5" lift spindles. Yes, 6" spindles have a provision for the front shafts.
Old 11-13-2008, 03:32 PM   #11
mjp2's Avatar
I think it's been resolved but...
I spent the time to do this so I'm posting it anyway. The red line is pretty much where the front axle would be.
So yeah, spindle lift + Gen 2 + 4x4 = outa luck.
Old 11-13-2008, 03:42 PM   #12
06Bluez has much to be proud of06Bluez has much to be proud of06Bluez has much to be proud of06Bluez has much to be proud of06Bluez has much to be proud of06Bluez has much to be proud of06Bluez has much to be proud of06Bluez has much to be proud of06Bluez has much to be proud of06Bluez has much to be proud of
06Bluez's Avatar
06Bluez's Tacoma Gallery
Why are spindles so expensive when they look so simple? arent they like $700?
Old 11-13-2008, 03:44 PM   #13
TRDATER's Avatar
The truck in question is a prerunner not a 4 by like chris commented on the spindles, no 3.5 drops will not work on a 4x4 obviously.
Old 11-13-2008, 04:08 PM   #14
Mayor of TW
Delmarva is one of the sharper tools in the shedDelmarva is one of the sharper tools in the shedDelmarva is one of the sharper tools in the shedDelmarva is one of the sharper tools in the shedDelmarva is one of the sharper tools in the shedDelmarva is one of the sharper tools in the shedDelmarva is one of the sharper tools in the shedDelmarva is one of the sharper tools in the shedDelmarva is one of the sharper tools in the shedDelmarva is one of the sharper tools in the shedDelmarva is one of the sharper tools in the shed
Delmarva's Avatar
Army: Vet
Delmarva's Tacoma Gallery
to help solve any confusion on whether these will work on a 4x4 or not...
direct from the TC website:
Originally Posted by TC
3.5” 05+ Tacoma Prerunner/06+ FJ Cruiser 4x2/03-07 4Runner 4x2 - Lift Spindles
**THESE WILL NOT WORK ON 4WD VEHCILES**
Finally a race inspired bolt on lift spindle for your 2005+ Tacoma Prerunner, 06+ FJ 4x2 and 03-07 4Runner 4x2. TOTAL CHAOS spindles are designed to add an additional 3.5” of lift and can be installed with existing aftermarket mid travel upper control arm and coil over shock packages. These systems combined provide 6”+ of lift and maximum cross member ground clearance, allowing you to Install up to a 35” tire. Our tubular tower and plate design features internal gussets along with overlay plates to add strength and reinforcement to proven weak areas. The tower includes a tapered bung that offers a pocket to access the aftermarket uniball conversion nut or thefactory ball joint. The CNC machined billet hub includes a one piece bearing carrier, and caliper mounts that are integrated into the boxed main body. To maximize strength, TC’s spindle was designed to not retain the factory sway bar. With the heavier spring rates of aftermarket coil over shocks and the increased track width provided by the spindles (3/4” per side), the sway bar removal is not noticeable. Removing the sway bar also allows for maximum wheel travel and articulation which will greatly improve the vehicles off road handling and performance. TOTAL CHAOS lift spindles come powder coated black and include a pair of D.O.T. approved stainless extended brake lines. Lift spindles that are intended to be installed with TC long travel systems must be specified at time of purchase. ABS wire tabs and brake line tabs are included to aid in routing the lines away from contact areas to prevent damage to these components.
Old 11-13-2008, 04:20 PM   #15
mjp2's Avatar
Probably closer to $1000. They're expensive for several reasons:
1. Development time
2. Cost of manufacturing & materials
3. They're a critical component so a lot of the above goes into them
Look at the prices of upper control arms and you'll wonder the same thing about the price, but all you have to do is break once and you'll find the expense is worth it.
But even after upgrading it's important to remember that nothing is unbreakable.
(not my truck, but he mangled his Allied spindles on the same trip I broke my UCA)
Old 02-27-2009, 01:19 PM   #16
06Bluez's Avatar
I bet that was expensive.
Old 02-27-2009, 01:31 PM   #17
mjp2's Avatar
That was a costly day, but a hell of a lot of fun!
Going from coilovers to spindles? cluck024 Suspension 15 11-05-2011 08:05 AM
Total Chaos spindles & Icon coilovers installed bermise Suspension 41 06-03-2010 09:10 AM
spindles and coilovers..?? sandman427 Suspension 64 09-13-2009 02:39 PM
T/C Spindles + Icon Coilovers set at 0" arkane Suspension 16 08-11-2009 09:50 PM
What lift to run? spacers, Uca, Coilovers, Spindles. hockeypoor Suspension 10 10-24-2008 04:48 PM
