4" Front Suspension lift?
Old 11-15-2011, 05:25 PM   #1
HoffmanDesigned is a name known to allHoffmanDesigned is a name known to allHoffmanDesigned is a name known to allHoffmanDesigned is a name known to allHoffmanDesigned is a name known to allHoffmanDesigned is a name known to all
HoffmanDesigned's Tacoma Gallery
Is there a 4" front suspension lift available for a 2007 Doublecab 4WD?
Why 4"? I started out with a Toytec 3" lift with their add-a-leaf in the rear. Then Toyota installed the TSB so now there's 5 leaves in the rear. Then I installed airbags because I routinely carry two motorcycles and gear in the back for long trips.
Now I have a truck that has a downward rake (front low) and I'd like to level it out.
To answer the obvious questions:
Why don't you remove either the Toytec add-a-leaf or Toyota's TSB?
- Perfectly reasonable options. However, instead of lowering the back to match the front, I'd like to explore options for raising the front to match the rear.
Why don't you remove the airbags?
- As mentioned, I do carry two street motorcycles in the back at least two weekends out of a month, sometimes more. Even with 5 leaves in the back, without the airbags it sagged significantly.
Why do you want a level truck? Trucks are supposed to be raked to account for when loaded.
- Aesthetics, mostly. I just prefer the level truck look. With ~1200 pounds in the back the airbags are more than capable of leveling the truck, and then some.
Are you married to 4 inches?
- No, not at all. I actually think a 5 would level it, but a 6" might be too much. I should measure. I'm currently at about 23" wheel center to fender. I may be naively assuming that a 4" front lift would be less intrusive than a 6" lift. I'm probably wrong.Anyways, let me know what you guys think. I've tried googling, but the only thing that came up was the spindle lift for 2WD.
Justus
Old 11-15-2011, 05:26 PM   #2
Max's Canadian Twin
theduck911 is one of the sharper tools in the shedtheduck911 is one of the sharper tools in the shedtheduck911 is one of the sharper tools in the shedtheduck911 is one of the sharper tools in the shedtheduck911 is one of the sharper tools in the shedtheduck911 is one of the sharper tools in the shedtheduck911 is one of the sharper tools in the shedtheduck911 is one of the sharper tools in the shedtheduck911 is one of the sharper tools in the shedtheduck911 is one of the sharper tools in the shedtheduck911 is one of the sharper tools in the shed
theduck911's Avatar
theduck911's Tacoma Gallery
RCD makes a DB lift for 4.5"
Old 11-15-2011, 05:27 PM   #3
Banned
RCD. It is a drop bracket lift so it reduces ground clearance a bit and you have to cut the front crossmember out to install it.
Old 11-15-2011, 05:30 PM   #4
Pineapples on pizza Hawaiian does not it make.
Konaborne is one of the sharper tools in the shedKonaborne is one of the sharper tools in the shedKonaborne is one of the sharper tools in the shedKonaborne is one of the sharper tools in the shedKonaborne is one of the sharper tools in the shedKonaborne is one of the sharper tools in the shedKonaborne is one of the sharper tools in the shedKonaborne is one of the sharper tools in the shedKonaborne is one of the sharper tools in the shedKonaborne is one of the sharper tools in the shedKonaborne is one of the sharper tools in the shed
Konaborne's Avatar
Konaborne's Tacoma Gallery
Those.
But of you're okay with a DB lift, and don't offroad as much, go for it.
Any lift past 3" is going to need to be a drop bracket, or you'll destroy your suspension
Old 11-15-2011, 05:38 PM   #5
Originally Posted by Konaborne View Post
Those.
I believe this is what you're talking about. And if I understand it correctly, I won't need upper control arms, because the spindles correct that.
Awesome! Thanks everyone.
Old 11-15-2011, 05:49 PM   #6
Yikes! Am I correct in reading that it is $2300?!?!
Let me see your DC's with 265 duratracs on 2.5" front lift with 2" rear lift BenWA 2nd Gen. Tacomas 8 11-08-2013 01:55 PM
Poll "Spacer lift vs. Suspension Lift" JoeyTacoma Suspension 81 03-19-2012 04:03 PM
Can I add a 2" body lift to my 3" suspension lift and not have problems with the VSC blue86gt 2nd Gen. Tacomas 17 08-10-2011 11:14 PM
Toytec 3" Spacer Lift w/ AAL or the Pro Comp 3" Suspension Lift hawaiian_fantasy Suspension 1 04-12-2010 04:30 PM
front suspension lift 09silvertaco Suspension 4 11-07-2008 05:38 PM
