3'' lift question
Discussion in 'Suspension' started by BackwoodsTaco, Nov 23, 2011.
  1. Nov 23, 2011 at 8:29 PM
    BackwoodsTaco
    BackwoodsTaco [OP] Well-Known Member
    Paul
    Stokes, NC (Eastern NC)
    Radiant Red 01 DC, 4X4, SR5, Supercharged
    TRD Supercharger, URD 7th injector kit, TRS RetroFit, Deck Plate Mod, No Chime Mod, Fog Light Mod, CB/ashtray Mod, 2.5" Spacer Lift, 1.25" Lift Shackles, 4 Tab Light Bar From Eddie209
    Hello everyone, I just bought my first Tacoma about a month ago :D and I absolutely love it but now I'm ready to lift it so I'm getting the Revtek 3'' lift and the website says i can fit 33's but i just wanted to make sure before i buy the tires that they will fit. If 33's won't fit then would you please tell me the biggest size i can run. btw they will be mounted on my stock 16's till i can find some i like, Thanks
    Here are some pictures of my baby the day i got her
  2. Nov 23, 2011 at 8:33 PM
    Maverick904
    Maverick904 Resident Fishing Expert
    Kameron
    Northeast Florida
    08 TRD Rugged Trail 4x4
    3" Procomp Lift, BDF Light Bar, Borla Stainless Cat-Back System, 2 10" Polk MM Subs, LED Interior Lighting, Pioneer Touch Screen, Kicker Speakers up front, Sonys in the back, Grillcraft grill, 20% tint, Weathertechs, Projector Retrofit Headlights. BHLM
    First off Welcome to TW.
    Click the link regarding suspensions in my signature, great great info there. Im pretty sure the revtek lift is a spacer lift if I remember correctly and most people shy away from those.
    There are some other ways to get the lift wanted without breaking the bank and not getting poor quality if you have not already bought the lift.
    Im not sure on tire sizes on first gens but somebody should chime in soon.
  3. Nov 23, 2011 at 8:46 PM
    Snowman
    Snowman I have a problem for your solution…
    Craig
    Somewhere in Canada
    Check out my build
    33's will probably rub the frame no matter what lift, mine do with 3" lift. I had to grind down the pinch weld too.
    Might depend on the 33's though. Mine are 285/75/16s but a 255/85/16 is a fair amount narrower so they might not touch the frame, but they are also slightly taller.
    I just ordered a new set of tires and went with 265/75/16s (32's) because I was annoyed by the rubbing and didnt want to go the spacer route for legal reasons.
  4. Nov 23, 2011 at 9:02 PM
    BackwoodsTaco
    Paul
    Thank you both the revtek kit is a spacer kit with blocks in the rear. it's not going to be up there long, just till summer, I'm gonna do a 6'' lift with 35's. just want some that will let me do some mild off-roading and get me around on the farm.
  5. Nov 23, 2011 at 9:06 PM
    Snowman
    Craig
    Somewhere in Canada
    Check out my build
    You should probably float around the 1st gen section of this forum before buying any spacers/blocks and research long and hard before trying to make a 6" lift. Most around here agree that a 6" lift on a 4x4 cannot be done properly unless you SAS the truck, which is big $$$.
    You would be better off staying stock than adding spacers and blocks if you want to offroad even a little. They will cause more damage in the long run.
  6. Nov 23, 2011 at 9:18 PM
    BackwoodsTaco
    Paul
    All right thanks buddy I'll check on that
