3" not tall enough 6" a little to much... not sure!!!
Old 11-23-2011, 08:35 PM   #1
yodalove [OP] yodalove is offline
yodalove is on a distinguished road
yodalove's Tacoma Gallery
* 06 tacoma trd dbl cab 4.0L * ( wanted one since i was 16 )
Fisrt off i love the truck more than i thought i could. drives amazing with lots of power from that 4.0 liter. the problem im having is deciding what to do about lifts. i want a little more that 3" (i think) but i dont have the money to do everything that a 6 " lift and 35's requires. so i guess my question would be is there a combonation of blocks coils and shocks that would give me 4" or a little more without spending 1000 $ on the lift. not a serious wheeling truck but will go in the woods from time time so needs to be pretty functionable..
looking to put beefy 33 x 12.50 on it with enough gap to look aggresive...any advice or examples of set ups would be so very appriciated!!!!!! thanks guys
Old 11-23-2011, 08:38 PM   #2
Superior Member
707tothe907 is one of the sharper tools in the shed707tothe907 is one of the sharper tools in the shed707tothe907 is one of the sharper tools in the shed707tothe907 is one of the sharper tools in the shed707tothe907 is one of the sharper tools in the shed707tothe907 is one of the sharper tools in the shed707tothe907 is one of the sharper tools in the shed707tothe907 is one of the sharper tools in the shed707tothe907 is one of the sharper tools in the shed707tothe907 is one of the sharper tools in the shed707tothe907 is one of the sharper tools in the shed
707tothe907's Avatar
707tothe907's Tacoma Gallery
RCD 4.5 inch lift. It's kinda right in the middle of 3 and 6.
Old 11-23-2011, 08:59 PM   #3
that would be nice if it werent about a grand over my budget haha... i mean i know the standard 3" lifts are reasonable i was just hoping there was another option for a little bigger .. if not then i guess ill have to get over it ..
on a side note this is my first post and im stoked to get a reply that fast so thanks man..
Old 11-23-2011, 09:01 PM   #4
Banned
Just keep saving money. The RCD lift is a drop bracket lift though so you will have hanging metal.
Old 11-23-2011, 09:04 PM   #5
Pineapples on pizza Hawaiian does not it make.
Konaborne is one of the sharper tools in the shedKonaborne is one of the sharper tools in the shedKonaborne is one of the sharper tools in the shedKonaborne is one of the sharper tools in the shedKonaborne is one of the sharper tools in the shedKonaborne is one of the sharper tools in the shedKonaborne is one of the sharper tools in the shedKonaborne is one of the sharper tools in the shedKonaborne is one of the sharper tools in the shedKonaborne is one of the sharper tools in the shedKonaborne is one of the sharper tools in the shed
Konaborne's Avatar
Konaborne's Tacoma Gallery
Stacking lifts to go over 2.5-3" will kill your suspension, and put you in danger of serious damage.
Just take your time and save up the $$ and do some research...im fairly certain if you read into db lifts you'll stay with the 3"
Old 11-23-2011, 09:11 PM   #6
rmahoney2013 has a brilliant futurermahoney2013 has a brilliant futurermahoney2013 has a brilliant futurermahoney2013 has a brilliant futurermahoney2013 has a brilliant futurermahoney2013 has a brilliant futurermahoney2013 has a brilliant futurermahoney2013 has a brilliant futurermahoney2013 has a brilliant futurermahoney2013 has a brilliant futurermahoney2013 has a brilliant future
rmahoney2013's Tacoma Gallery
Go 3" and trim you could fit 35s. See what you want in person too. Could change your thoughts... Pictures look good but can be deceiving
Old 11-23-2011, 09:17 PM   #8
Plastidipped ma Hootus!
kmok is one of the sharper tools in the shedkmok is one of the sharper tools in the shedkmok is one of the sharper tools in the shedkmok is one of the sharper tools in the shedkmok is one of the sharper tools in the shedkmok is one of the sharper tools in the shedkmok is one of the sharper tools in the shedkmok is one of the sharper tools in the shedkmok is one of the sharper tools in the shedkmok is one of the sharper tools in the shedkmok is one of the sharper tools in the shed
kmok's Avatar
kmok's Tacoma Gallery
Since you are 4x4 the only way to go over 3" of lift would be a drop bracket lift. As far as I know the only company to make a 4.5" lift is RCD. Drop bracket lifts require cutting crossmembers and lose ground clearance versus a 3" lift. You can run 33/12.5 tires with a 3" lift and some minor trimming.
Old 11-23-2011, 09:20 PM   #9
i figured there was a reason so many people go with the three and the more i look the more it holds true... i have had a few jeeps that were 4" or more and had no drivetrain problems but i guess thats not this case with tacos... which is fine its the truck ive wanted for a long time. I dont want 35's anyways so i guess the question now is whats the best set up on the 3 " lift... factory feeling ride isnt the biggest concern.
Old 11-23-2011, 09:23 PM   #10
Resident Fishing Expert
Maverick904 is one of the sharper tools in the shedMaverick904 is one of the sharper tools in the shedMaverick904 is one of the sharper tools in the shedMaverick904 is one of the sharper tools in the shedMaverick904 is one of the sharper tools in the shedMaverick904 is one of the sharper tools in the shedMaverick904 is one of the sharper tools in the shedMaverick904 is one of the sharper tools in the shedMaverick904 is one of the sharper tools in the shedMaverick904 is one of the sharper tools in the shedMaverick904 is one of the sharper tools in the shed
Maverick904's Avatar
Maverick904's Tacoma Gallery
You sir just asked the right question.
Take a look at the "Lift" link in my signature. Tons of good info there. You can build a quality 3" lift many different ways. It all depends on your budget.
Old 11-23-2011, 09:28 PM   #11
kmok's Avatar
How much are you willing to spend? I would check out the OME lift setups and look into getting new ucas as well. Stay away from blocks and spacers.
Old 11-23-2011, 09:30 PM   #12
Originally Posted by Blacktacoma23 View Post
I had 4" of lift at one point and wasnt to smooth haha.
so i scanned through your build pics and the one after you said you went to 295's.. are you still on the 3" pro comp lift only or had you done something else at that point... nice srh sticker btw!
Old 11-23-2011, 09:33 PM   #13
yeah i had no plans for either ... honeslty i was hoping to have around 1500 in the lift tires and wheels ... if thats not even in the ball park i guess i'll have to bite a bullet or two haha.. and thanks for the link and all the help
Old 11-23-2011, 09:36 PM   #14
worthywads is one of the sharper tools in the shedworthywads is one of the sharper tools in the shedworthywads is one of the sharper tools in the shedworthywads is one of the sharper tools in the shedworthywads is one of the sharper tools in the shedworthywads is one of the sharper tools in the shedworthywads is one of the sharper tools in the shedworthywads is one of the sharper tools in the shedworthywads is one of the sharper tools in the shedworthywads is one of the sharper tools in the shedworthywads is one of the sharper tools in the shed
worthywads's Avatar
worthywads's Tacoma Gallery
Just don't post asking how to get your mpg back up once you done the lift and tires, because you can't, it will tank.
Old 11-23-2011, 09:39 PM   #15
ill deal with it lol. that thread on lifts is amazing btw ...
Old 11-23-2011, 09:42 PM   #16
The Dank Tank
Blacktacoma23 is one of the sharper tools in the shedBlacktacoma23 is one of the sharper tools in the shedBlacktacoma23 is one of the sharper tools in the shedBlacktacoma23 is one of the sharper tools in the shedBlacktacoma23 is one of the sharper tools in the shedBlacktacoma23 is one of the sharper tools in the shedBlacktacoma23 is one of the sharper tools in the shedBlacktacoma23 is one of the sharper tools in the shedBlacktacoma23 is one of the sharper tools in the shedBlacktacoma23 is one of the sharper tools in the shedBlacktacoma23 is one of the sharper tools in the shed
Blacktacoma23's Avatar
Blacktacoma23's Tacoma Gallery
Yeah I still had the pro comp lift, and I still run the rear part of the kit.
Old 11-23-2011, 11:15 PM   #17
Go home if you don't like guns liquor and whores.
maxamillion2345 is one of the sharper tools in the shedmaxamillion2345 is one of the sharper tools in the shedmaxamillion2345 is one of the sharper tools in the shedmaxamillion2345 is one of the sharper tools in the shedmaxamillion2345 is one of the sharper tools in the shedmaxamillion2345 is one of the sharper tools in the shedmaxamillion2345 is one of the sharper tools in the shedmaxamillion2345 is one of the sharper tools in the shedmaxamillion2345 is one of the sharper tools in the shedmaxamillion2345 is one of the sharper tools in the shedmaxamillion2345 is one of the sharper tools in the shed
maxamillion2345's Avatar
maxamillion2345's Tacoma Gallery
OME 885, top spacers. OME shocks. AAL kit.
Best all purpose general set up. Throw in some UCAs and you're set.
1st Gen. "DIY" and "How To" Thread: Compiled list of helpful links StAndrew 1st Gen. Tacomas 230 04-17-2015 10:11 AM
"honk" or the Toyota "beep" when locking/unlocking doors? TheOtherGuy 2nd Gen. Tacomas 10 10-03-2014 11:08 PM
New Large & In Charge "TOYOTA" FJ Land Cruiser Emblem 4 "SATOSHI" RAD Buy / Sell / Trade 47 11-14-2013 07:45 AM
Anyone have a truck "cap" "topper" "shell" hoist? Madtown Taco 2nd Gen. Tacomas 37 11-09-2013 07:57 PM
265 or 275 tire that is 33" tall? yoyak Wheels & Tires 1 02-14-2012 06:11 PM
