Issue with front LCA
Old 11-30-2011, 03:07 PM   #1
tacoman_KC [OP] tacoman_KC is offline
Hurray for Zoidberg!
tacoman_KC has much to be proud oftacoman_KC has much to be proud oftacoman_KC has much to be proud oftacoman_KC has much to be proud oftacoman_KC has much to be proud oftacoman_KC has much to be proud oftacoman_KC has much to be proud oftacoman_KC has much to be proud of
tacoman_KC's Avatar
tacoman_KC's Tacoma Gallery
I'm hearing a clunk sound at low speeds and when turning..I've taken some pictures at different angles showing the LCA, to my untrained eye it doesn't look good at all.
Old 11-30-2011, 04:24 PM   #2
chris4x4's Avatar
chris4x4's Tacoma Gallery
Make sure its torqued propperly.
Old 11-30-2011, 07:55 PM   #3
Hellion
Deserted1 is one of the sharper tools in the shedDeserted1 is one of the sharper tools in the shedDeserted1 is one of the sharper tools in the shedDeserted1 is one of the sharper tools in the shedDeserted1 is one of the sharper tools in the shedDeserted1 is one of the sharper tools in the shedDeserted1 is one of the sharper tools in the shedDeserted1 is one of the sharper tools in the shedDeserted1 is one of the sharper tools in the shedDeserted1 is one of the sharper tools in the shedDeserted1 is one of the sharper tools in the shed
Deserted1's Tacoma Gallery
Send a message via AIM to Deserted1
looks to me like the tabs are bent but that shouldent be causing a clicking sound.
Old 12-01-2011, 09:33 AM   #4
tacoman_KC's Avatar
Do you think that this is something thats ok to drive on for a few days?
Old 12-01-2011, 05:40 PM   #5
Fabulous is one of the sharper tools in the shedFabulous is one of the sharper tools in the shedFabulous is one of the sharper tools in the shedFabulous is one of the sharper tools in the shedFabulous is one of the sharper tools in the shedFabulous is one of the sharper tools in the shedFabulous is one of the sharper tools in the shedFabulous is one of the sharper tools in the shedFabulous is one of the sharper tools in the shedFabulous is one of the sharper tools in the shedFabulous is one of the sharper tools in the shed
Fabulous's Avatar
Fabulous's Tacoma Gallery
I wonder if the bushings are seized allowing the whole assembly to move around, and bend the tab? It's pretty common that they seize as there is no anti seize added at the factory. Ask me how I know...
Old 12-01-2011, 05:54 PM   #6
Banned
XXXX is one of the sharper tools in the shedXXXX is one of the sharper tools in the shedXXXX is one of the sharper tools in the shedXXXX is one of the sharper tools in the shedXXXX is one of the sharper tools in the shedXXXX is one of the sharper tools in the shedXXXX is one of the sharper tools in the shedXXXX is one of the sharper tools in the shedXXXX is one of the sharper tools in the shedXXXX is one of the sharper tools in the shedXXXX is one of the sharper tools in the shed
XXXX's Tacoma Gallery
We spoke about this yesterday in the live thread. No one can tell whats wrong off that pic thus no one will assure you it's safe. Your ball joint could be ready to pop and flop your wheel off. Not trying to scare you, but you need to take the tire off and investigate or have a "qualified" mechanic look it over.
Did you check to see if your mount was in fact bent or if it was the picture angle?
The bushings themselves look fine.
here's a shot of new ones for comparison'
Front axles, sway bar, LCA, UCA, etc... For sale 04LTtacoma Buy / Sell / Trade 4 06-12-2010 03:13 PM
'06 Tacoma 4x4 front wheel bearing issue DB427 New Members 0 09-29-2009 05:30 PM
Front ABS issue on lifted toyota ritewayco 2nd Gen. Tacomas 12 09-29-2009 02:56 PM
Front diff vibrating issue Clgrytacoguy Suspension 9 01-30-2009 07:34 PM
front diff issue! ETaco23 Suspension 19 03-04-2008 08:18 PM
