Please don't get angry I tried the search - Lesser Lift Question
Discussion in 'Suspension' started by canyonchaser, Dec 5, 2011.
  1. Dec 5, 2011 at 10:48 AM
    canyonchaser
    canyonchaser [OP] Member Known Well
    Dave
    Utah
    LR TRD PRO MT
    So, really I tried the search and spent several hours looking for the answer myself, really I did.
    Current setup is stock with TSB on the rear.
    As you can see, it's pretty tight. I measured 20" at the front and 21.75" at the rear.
    But I really don't want a 3" lift, Half of that would be perfect. And I'd really rather have the rear sit higher because I load and tow.
    So far it sounds like the best way to achieve that is adjustable 5100's set at .85 (possibly 1.75") Dunno... And an 1.75" (or so) AAL. Am I correct so far?
    Second. with the 5100's do I use my own spring, should I get the aftermarket spring, or would the OME's with the say 885 springs be a better choice?
    A friend of mine did the ReadyLift at the front, it looks good, but seems kinda ghetto to me...
    If I do the 1.75" AAL, do I need longer rear shocks?
    Thanks, and I apologize in advance if this has been answered many times in the past.
    dp
  2. Dec 5, 2011 at 10:58 AM
    DreDog
    DreDog Well-Known Member
    Andrew
    The 5100s in front and aal will work. You could use your stock springs, I did. Unless your planning on a plate bumper. And I think you only need the ext length shocks in back if
    You have a 3 inch leaf pack. Check with dsm on that though.
    They wouldn't hurt, I have them with my all pro 3 inch leaf pack
  3. Dec 5, 2011 at 11:04 AM
    DreDog
    Andrew
    Tru dat ^^
  4. Dec 5, 2011 at 11:11 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    5100s all around, 0 setting on the front, Eibach coils for 1.6" of lift in the front and the Icon 3-leaf AAL for 1.5" lift in the rear (2" if you retain the factory overload leaf like I did). Here's a pic of that set-up with 265/70R17 tires.
  5. Dec 11, 2011 at 6:16 PM
    moulin6801
    moulin6801 Well-Known Member
    I did the TSB in the back and 5100 in the front with 1.75". Very happy with the front set up, no vibration, all good. The only thing is that the hear TSB is sinking, I guess from pulling my boat this summer (2010 TRDsport 4x4).
    Now I want to do something else with the hear to get more lift at the back.
    Cheers.
  6. Dec 11, 2011 at 6:19 PM
    Andrew H
    Andrew H What is this "search" you speak of?
    Dirty Tucson
    2017SSMDCSBTRDS
    sick picture man. i think the truck looks great as it is.
  7. Dec 12, 2011 at 4:20 AM
    UH60Hwkdrvr
    UH60Hwkdrvr Well-Known Member
    El Paso, TX
    2023 Tacoma Limited Nightshade 4x4
    Did any of you have to add a diff drop because of drive-line vibes? I did a small lift on my Wrangler and required a T-Case drop because it vibrated like crazy.
    m.a.c.
