3" Suspension Lift With 1.5 Body Lift Tire Size?
Old 12-11-2011, 12:42 PM   #1
05Wheeler [OP] 05Wheeler is offline
05Wheeler is on a distinguished road
05Wheeler's Tacoma Gallery
I am wanting to do a 3" suspension lift on my 05 toyota tacoma. The recommended tire size is 31". So my question is if i put an 1.5 body lift in will i be able to fit 33's or 35's?
Old 12-11-2011, 12:43 PM   #2
Almost there
08pretaco is one of the sharper tools in the shed08pretaco is one of the sharper tools in the shed08pretaco is one of the sharper tools in the shed08pretaco is one of the sharper tools in the shed08pretaco is one of the sharper tools in the shed08pretaco is one of the sharper tools in the shed08pretaco is one of the sharper tools in the shed08pretaco is one of the sharper tools in the shed08pretaco is one of the sharper tools in the shed08pretaco is one of the sharper tools in the shed08pretaco is one of the sharper tools in the shed
08pretaco's Avatar
08pretaco's Tacoma Gallery
5 or 6 lug? with a 6 lug and 3" 285's fit with trimming
Old 12-11-2011, 12:45 PM   #3
6 lug
Old 12-11-2011, 12:47 PM   #4
Almost there
08pretaco's Avatar
you should be fine running a 285/75/16 with a 6 lug 3" lift. You will have to do some trimming and possibly a cab mount chop if you wheel the truck.
which company says a 31" will fit on their 3" suspension lift btw?
oh and mind you if wanting to run a full 3" lift you will more than likely have to get new upper control arms to allow for caster change. you will also need to either get wheels spacers for stock wheels or get proper backspaced aftermarket wheels to prevent rubbing and allow proper fitment.
Old 12-11-2011, 12:53 PM   #5
ok sweet thankyou....rough country is saying that for the recommended tire size. If i want to go with 20's will the same apply?
Old 12-11-2011, 01:00 PM   #6
Almost there
08pretaco's Avatar
may I ask why you are looking at rough country? 1st kit you came across/price?? there are a lot better quality lift out there.
Instand being you want to stay away from spacers. I would recommend going with 5100 bilsteins all the way around. Set the front shocks to 2.5" and get the toytec top plate spacers to get you to the 3". You will be a lot happier with that is my guess. Wheelers sells rear add a leaf kits.
Front and rear shocks ~275
top plate spacer ~ 42-52
AAl 1.5 or 2" ~ 75
Upper control arms ~420-600
Old 12-11-2011, 01:05 PM   #7
Glamour Shot
ajohnson is one of the sharper tools in the shedajohnson is one of the sharper tools in the shedajohnson is one of the sharper tools in the shedajohnson is one of the sharper tools in the shedajohnson is one of the sharper tools in the shedajohnson is one of the sharper tools in the shedajohnson is one of the sharper tools in the shedajohnson is one of the sharper tools in the shedajohnson is one of the sharper tools in the shedajohnson is one of the sharper tools in the shedajohnson is one of the sharper tools in the shed
ajohnson's Avatar
ajohnson's Tacoma Gallery
AAl 1.5 or 2" ~ 75
I agree, you should be really happy with this set up.
Old 05-01-2012, 12:36 PM   #8
jockfro is on a distinguished road
jockfro's Tacoma Gallery
3" Suspension Lift With 1.5" Body Lift Tire Size?
I would like to do the same thing here. I posted this on the 1" BL thread. I am currently running 285/70/17s on my 07 DC Long Bed 4x4 with Dick Cepek DC1s 4.5" backspacing with 3" of lift. The reason I want to do this is because I want to run a true 33/12.50 or possibly a 33.5. I have VERY minimal rubbing on plastic now after trimming, so it seems to me if I go up 1.5" and go with a 33/12.50 or even a 33.5 I should be ok. I read somewhere to watch the rubbing on the frame. Can anyone speak about this? Don't want to go full 6" lift. I personally think 33s look a little small on a 6" lift. By the way, I'm looking to go with Mickey Thompson MTZs or possibly Toyo open country MT. There is one that measures 33.5, not sure of the actual measurements. Thanks for any help...
2in body lift on top of 3in suspension lift....any suggestions ?? tmalley93 2nd Gen. Tacomas 18 04-11-2012 01:41 PM
Can I add a 2" body lift to my 3" suspension lift and not have problems with the VSC blue86gt 2nd Gen. Tacomas 17 08-10-2011 10:14 PM
anyone have a 3" suspension lift and a small body lift? RDAY Suspension 4 03-24-2011 12:56 PM
3" suspension, 1" body lift? 33's? Max-4_Yota Wheels & Tires 8 12-12-2009 07:48 PM
Tire Size on a 3" lift-- Help... bajaracer Wheels & Tires 3 04-11-2009 02:21 PM
