2011 tacoma leveling kit
Discussion in 'Suspension' started by Holyfather, Dec 21, 2011.
  1. Dec 21, 2011 at 10:26 PM
    Holyfather
    Holyfather [OP] Well-Known Member
    Arizona
    2011 TX Pro TRD
    Front Bilstein 5100s @ 1.75"
    Hey guys. I was looking at putting a leveling kit on my 2011 TX Pro TRD to bring the front end up a little bit. What would you guys suggest I put on so that I don't have to change the shocks or any other parts. I was looking to bring it up 2"-3".
  2. Dec 22, 2011 at 5:17 PM
    TexasTacoma37
  3. Dec 25, 2011 at 12:06 PM
    Holyfather
    Arizona
    2011 TX Pro TRD
    Alright after looking through the options I have decided to go with a spacer lift due to its simplicity and low cost. Are there kits that are better than others or ones to avoid?
  4. Dec 25, 2011 at 2:40 PM
    TexasTacoma37
    None of them are particularly good option. Bilstein 5100s would be not much more money and are a much better option as far as ride comfort, as well as wear and tear on your ball joints.
  5. Dec 25, 2011 at 3:37 PM
    BenH
    BenH Member
    Ben
    Cape Cod
    11 Tacoma Double cab extended bed
    i have the bilstein 5100s set at 1.75 and a 2 inch aal and it leveled out nicely
  6. Dec 25, 2011 at 8:07 PM
    Holyfather
    Arizona
    2011 TX Pro TRD
    I've looked at the adjustable bilstein 5100s and they are pretty affordable. How much stiffer if any do they make the truck opposed to the stock TRD shocks I currently have?
  7. Dec 27, 2011 at 8:45 AM
    TexasTacoma37
    They will definitely stiffen the ride because they preload the springs (just like a coil spacer leveling kit would), but the difference is that the 5100 shocks are valved to properly dampen the stiffer spring, and your stock shocks are not.
