2* axle shims....
Old 12-22-2011, 08:34 PM   #1
ETaco23 [OP] ETaco23 is offline
ETaco23 is one of the sharper tools in the shedETaco23 is one of the sharper tools in the shedETaco23 is one of the sharper tools in the shedETaco23 is one of the sharper tools in the shedETaco23 is one of the sharper tools in the shedETaco23 is one of the sharper tools in the shedETaco23 is one of the sharper tools in the shedETaco23 is one of the sharper tools in the shedETaco23 is one of the sharper tools in the shedETaco23 is one of the sharper tools in the shedETaco23 is one of the sharper tools in the shed
ETaco23's Avatar
ETaco23's Tacoma Gallery
2* axle shims....
Im trying to find some 2* degree shims, bc I have a take off shudder that im trying to cure...
Ive tryed everything! even 3* degree shims, but no luck..
Ive even tryed BT 1-1/2" CB Drop bracket! didnt help...
Im ganna trry to take out the CB drop from toytec out and just use a 2* shim to see if that helps....
where's a good place buy from?
Thanks!
Old 12-22-2011, 08:39 PM   #2
Sunner is one of the sharper tools in the shedSunner is one of the sharper tools in the shedSunner is one of the sharper tools in the shedSunner is one of the sharper tools in the shedSunner is one of the sharper tools in the shedSunner is one of the sharper tools in the shedSunner is one of the sharper tools in the shedSunner is one of the sharper tools in the shedSunner is one of the sharper tools in the shedSunner is one of the sharper tools in the shedSunner is one of the sharper tools in the shed
Sunner's Avatar
Sunner's Tacoma Gallery
EEEsssshhh, Hope I dont have to go through all that when I lift, subbed to find out as well
Old 12-22-2011, 08:50 PM   #3
ETaco23's Avatar
My vibe isnt too bad.. I only feal it sometimes, I just want to get rid of it..
anyone?
Old 12-22-2011, 09:03 PM   #4
wolfdog2314 is one of the sharper tools in the shedwolfdog2314 is one of the sharper tools in the shedwolfdog2314 is one of the sharper tools in the shedwolfdog2314 is one of the sharper tools in the shedwolfdog2314 is one of the sharper tools in the shedwolfdog2314 is one of the sharper tools in the shedwolfdog2314 is one of the sharper tools in the shedwolfdog2314 is one of the sharper tools in the shedwolfdog2314 is one of the sharper tools in the shedwolfdog2314 is one of the sharper tools in the shedwolfdog2314 is one of the sharper tools in the shed
wolfdog2314's Tacoma Gallery
Beuller?
Old 12-22-2011, 09:27 PM   #6
Bullwinkle J. Moose
bjmoose is one of the sharper tools in the shedbjmoose is one of the sharper tools in the shedbjmoose is one of the sharper tools in the shedbjmoose is one of the sharper tools in the shedbjmoose is one of the sharper tools in the shedbjmoose is one of the sharper tools in the shedbjmoose is one of the sharper tools in the shedbjmoose is one of the sharper tools in the shedbjmoose is one of the sharper tools in the shedbjmoose is one of the sharper tools in the shedbjmoose is one of the sharper tools in the shed
bjmoose's Avatar
bjmoose's Tacoma Gallery
Here you go
http://www.4crawler.com/4x4/ForSale/Shims.shtml
Old 12-23-2011, 05:52 PM   #7
ETaco23's Avatar
cool! I may have to check it out! thanks!
Old 12-23-2011, 07:40 PM   #9
Sprink669 is one of the sharper tools in the shedSprink669 is one of the sharper tools in the shedSprink669 is one of the sharper tools in the shedSprink669 is one of the sharper tools in the shedSprink669 is one of the sharper tools in the shedSprink669 is one of the sharper tools in the shedSprink669 is one of the sharper tools in the shedSprink669 is one of the sharper tools in the shedSprink669 is one of the sharper tools in the shedSprink669 is one of the sharper tools in the shedSprink669 is one of the sharper tools in the shed
Sprink669's Tacoma Gallery
summit racing has every * you need
Old 12-23-2011, 10:34 PM   #10
ETaco23's Avatar
Originally Posted by OZ-T View Post
OP , are you going to sell the Beefed drop ?
thaught about it.... you want it?
Old 12-23-2011, 10:35 PM   #11
ETaco23's Avatar
Awsome! thanks
Old 12-23-2011, 10:40 PM   #12
ETaco23's Avatar
how wide do the shims need to be again? 2"?
Thanks!
Old 12-24-2011, 09:53 AM   #13
ETaco23's Avatar
haha! I was waiting for that reply...
Im too lazy...
Old 12-24-2011, 10:01 AM   #14
i got mine from summit, the only thing i had to do was drill out the hole a little bigger. i picked them up for like 9 bucks
Old 12-24-2011, 10:18 AM   #15
ETaco23's Avatar
Which ones did you get? Im looking at getting the Rough Country ones, that come with new center pins...
Old 12-24-2011, 10:30 AM   #16
jflan is one of the sharper tools in the shedjflan is one of the sharper tools in the shedjflan is one of the sharper tools in the shedjflan is one of the sharper tools in the shedjflan is one of the sharper tools in the shedjflan is one of the sharper tools in the shedjflan is one of the sharper tools in the shedjflan is one of the sharper tools in the shedjflan is one of the sharper tools in the shedjflan is one of the sharper tools in the shedjflan is one of the sharper tools in the shed
jflan's Avatar
Gender: Tranny
jflan's Tacoma Gallery
Thanks!
If you are close to Portland, OAS will custom cut steel shims. Quoted me $15 each.
http://www.spring-man.com/
Which way are you facing the shims ?
Old 12-24-2011, 04:35 PM   #17
ETaco23's Avatar
the right way... flap down, fat end to the rear.
I ganna try the ones from summitracing, thanks again!
Old 02-20-2012, 10:27 AM   #18
AZtacoma05 is one of the sharper tools in the shedAZtacoma05 is one of the sharper tools in the shedAZtacoma05 is one of the sharper tools in the shedAZtacoma05 is one of the sharper tools in the shedAZtacoma05 is one of the sharper tools in the shedAZtacoma05 is one of the sharper tools in the shedAZtacoma05 is one of the sharper tools in the shedAZtacoma05 is one of the sharper tools in the shedAZtacoma05 is one of the sharper tools in the shedAZtacoma05 is one of the sharper tools in the shedAZtacoma05 is one of the sharper tools in the shed
AZtacoma05's Tacoma Gallery
Did you get your problem fixed? what width did you end up going with for the plates? Just tried to measure mine and looked like 2 1/4".
Old 02-20-2012, 12:23 PM   #19
ETaco23's Avatar
I tryed the shims but it made it worse. The thing that got rid of most of my take off vibes was taking out the shims and just lowering the carrier bearing until the drive shaft is almost straight. Or until both shafts are within 1 degree of each other.
axle shims PPD934 Suspension 36 09-02-2013 01:59 PM
Axle shims Mickdizzle Suspension 26 05-25-2012 07:31 AM
3* Axle Shims jnoley07 Buy / Sell / Trade 6 06-29-2011 06:28 PM
AXLE SHIMS crawldad 2nd Gen Tacoma Marketplace 6 03-20-2011 08:48 AM
Axle Shims??? badguybuster 2nd Gen. Tacomas 11 03-01-2010 10:04 AM
