5100 at 2.5
Discussion in 'Suspension' started by TACWUT, Jan 14, 2012.
  1. Jan 14, 2012 at 5:20 PM
    TACWUT
    TACWUT [OP] Well-Known Member
    San Diego
    12 prerunner DC
    Flowmaster turndown, 5100 up front/5150 rear, maxtrac spindles, 2" tuff country add a leaf+TSB.
    I did research and haven't found much or enough to satisfy my nerves.
    With that being said, im getting my lift on monday and am going to get 5100 @ the 2.5 setting while running stock coils and maybe a 1 inch add a leaf in the back. My concern is that it was commented that at the 2.5 setting my ride would be stiff any comments from those with a similar set up would be appreciated. Thanks in advance.
  2. Jan 14, 2012 at 6:06 PM
    Sublime
    Sublime Well-Known Member
    Phoenix, AZ
    08 TRD 4x4
    Def will want new coils. Basically, it'll ride similar to a spacer as its compressing the stock coil which isnt designed for the added stiffness. An after market coil is designed to be longer and has the ability to keep up with the heaftier shock. I think most dudes run the eibach coils and set the shock at .85 and it rides pretty smooth. Not sure on the spec but the OME coils do the job too!
    PS - Just saw you were in San Diego.......for the trails you have out there, you're be way better off with a higher quality coilover! 5100s won't keep up with the dudes with Icon, Fox, King. Just pick a color/price that works for you!
  3. Jan 14, 2012 at 6:19 PM
    mako86
    mako86 Member
    Nova Scotia
    09 trd sport 4x4 dclb
    I had a 3" spacer lift and then 5100's at 2.5 and now 5100's at .85 with a top spacer which gives about 1.75 to 2" of lift. I know people will disagree with this but I believe that it's not preloading the coil spring that give a stiff ride but the angle of the control arms. The steeper the angle (the more lift) the more impact is transmitted through the frame rather then the suspension. That being said I won't sett them higher than 1.75. Anything higher regardless of the type lift other than a drop bracket lift will make the ride noticeably harsher.
  4. Jan 14, 2012 at 6:27 PM
    TACWUT
    San Diego
    12 prerunner DC
    Thnx a ton guys. Keep those opinions coming.
  5. Jan 14, 2012 at 6:42 PM
    LUSETACO
    LUSETACO Here for the Taco Pron
    Dennis
    South Central Pee A
    2005 PIMP MOBILE
    Yes
    I've got mine set at 2.5....no regrets.
  6. Jan 14, 2012 at 7:08 PM
    TACWUT
    San Diego
    12 prerunner DC
    Nice. Is it stiffer than stock n r u running stock coils?
  7. Jan 14, 2012 at 7:30 PM
    LUSETACO
    Dennis
    South Central Pee A
    2005 PIMP MOBILE
    Yes
    Yes it is stiffer but nothing I would call harsh. And yes thats with stock coils.
  8. Jan 14, 2012 at 7:31 PM
    TACWUT
    San Diego
    12 prerunner DC
    Cool man
  9. Jan 14, 2012 at 9:20 PM
    toyo freak
    toyo freak Another Toyota Enthusiast
    David
    Mobile, Alabama
    2010 V6 D-Cab 4x4
    5100s at 2.5, Wheeler 3 leaf progressive AAL, Weathertech liners, yellow wire mod, toyota OEM bed mat, cup holder mod, afe pro dry s air filter, UWS low pro toolbox, Escort radar detector
    I have the same setup with 1" block in rear. Rides fine little stiff on bumps but overall very impressed. Now I just want to raise it more
  10. Jan 14, 2012 at 9:57 PM
    TACWUT
    San Diego
    12 prerunner DC
    Exactly y i want to go 2.5! Lol
  11. Jan 14, 2012 at 10:28 PM
    TACWUT
    San Diego
    12 prerunner DC
    Im def. Getting the leaf. No spacers or blocks here but thats mainly cause my car is new with 1k miles on it. Want to do it right but I try n b frugal.
    No offense toyo freak
  12. Jan 14, 2012 at 10:31 PM
    m_yota
    m_yota Well-Known Member
    Paradise
    08 4x4 dbl cab
    K&N airfilter, HID conversion for headlights/fogs. Wet Okole Seat covers, Kove Aphex processor Kenwood comp 6.5" and 6.5"coaxial 5100 billy shocks 2.5", 1.5" fabtech AAL,Epicenter and MTX Sub, debadged, tinted, kenwood dnx812, black mesh grill, led ext/int.
    I 2nd that!!
  13. Jan 14, 2012 at 11:00 PM
    TACWUT
    San Diego
    12 prerunner DC
    So better than stock u would say?
  14. Jan 14, 2012 at 11:15 PM
    bhh2000
    bhh2000 Well-Known Member
    Ben
    Santa Rosa
    2016 DCLB TRD 4X4
    would 5100's at 2.5 with stock coils and an aal be stiffer then my worn out first gen shocks? I want to do the same thing as the OP but for ride and lift.... if not what are the cheapest coil's that would ride well?
    Not to thread jack.....
  15. Jan 14, 2012 at 11:17 PM
    TACWUT
    San Diego
    12 prerunner DC
    Dude, either ome or eibach r about 30 bucks apart from what i have seen.
  16. Jan 14, 2012 at 11:30 PM
    TACWUT
    San Diego
    12 prerunner DC
    Fawk! Should i add ome coils to this equation?
  17. Jan 14, 2012 at 11:37 PM
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
    OME 885's got me exactly 2 1/2" up front on my DCLB , you could run those with 5100's at 0
  18. Jan 14, 2012 at 11:48 PM
    TACWUT
    San Diego
    12 prerunner DC
    Very well my wife says the same. Im by no means cheap or poor just frugal. Just saying. Thank you so much guys keep opinions and experienced comments coming.
  19. Jan 15, 2012 at 12:03 AM
    TACWUT
    San Diego
    12 prerunner DC
    Lol isn't that the truth?
  20. Jan 15, 2012 at 7:48 AM
    toyo freak
    David
    Mobile, Alabama
    2010 V6 D-Cab 4x4
    None taken honestly I don't think you have to worry about the issues that everyone complains about with the block if you only have a 1" block. Now a 4" block could cause problems but I'm not too worried about the 1" doing any real harm. That being said after everything settled I got a near level setup. Just my humble opinion
