35's scrubbing with 6" lift-
Discussion in 'Suspension' started by rutwad, Dec 5, 2008.
  1. Dec 5, 2008 at 3:48 PM
    rutwad
    rutwad [OP] Active Member
    Alabama
    I have a ProComp Stage II 6" lift on my '07 Dbl. Cab 4x4. The front tires scrub too often! I do not want to do any trimming.
    Is it possible to take the upper OEM shock mount "bushing" and put on top of the ProComp? I'm not looking for serious off-roading or a huge lift. I just would like to eliminate some scrubbing. Any Ideas?
    Thanks in advance!
  2. Dec 5, 2008 at 3:52 PM
    dabighi
    dabighi Well-Known Member
    i think your gonna have to do some trimming. wheres it rubbing? the uca, body mount?
  3. Dec 5, 2008 at 3:56 PM
    rutwad
    Alabama
    Bottom of fenders near the outer edge when I turn.
    I hate to, but I may just have to drop some $$$$$ on some 33's.
  4. Dec 5, 2008 at 6:27 PM
    rutwad
    Alabama
    I'm running Pro Comp Xtreme AT's now.
    I'll "play" with it tomorrow, but I hate to trim unless it's a last resort.
  5. Dec 5, 2008 at 6:28 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    15 Lariat Sport 5.0L
    ppl trim up for 33's on a 3" lift and barely trim anything after the flaps are removed...its not going to hurt anything
  6. Dec 5, 2008 at 6:38 PM
    rutwad
    Alabama
    Could someone post a pic where they have trimmed.
  7. Dec 5, 2008 at 7:08 PM
    Toy4Life
    Toy4Life 668: The Neighbor of the Beast
    Chad
    Slippery Rock, PA
    96 Subaru Outback 2.2 5mt
    92 4Runner SR5 3.0v6 4x4(sold) 02 Tacoma SR5 TRD Offroad 4x4 (sold)
    You're not gonna be trimming sheet metal or anything. It's not gonna be like butchering your fenders. It'll most likely be some plastic inside the fenderwell.
  8. Dec 5, 2008 at 11:46 PM
    Rippin101
    Rippin101 Well-Known Member
    John
    Jax Beach, FL
    2014 TRD Sport 4x4
    -Nitto G2 265/70/17 -Level 8 MK6 Wheels -Katzkin Leather Black on Black -BHLM -Weathertech -Extang Solid Fold -Bedlight LEDs -TRD Skid
    Its the tiniest bit ever, you won't even notice!
  9. Dec 6, 2008 at 4:52 AM
    rutwad
    Alabama
    The best I can remember is if I have the tires turned all the way to the right, then the inside of the front right tire rubs the front of the fender. And the outer rear of the tire will scrub as well.
    I don't think I am scrubbing any further to the inside. So I would have to trim the bottom of the fender flares like /o\ .
    I hope I am wrong. I'll check today. I don't mind trimming the inner fender if that's all it takes.
    Thanks.
  10. Dec 6, 2008 at 8:24 AM
    rutwad
    Alabama
    Would I be able to mount a top plate spacer up front. I've seen some that give about 3/4" lift. Would they work with my ProComp's?
  11. Dec 6, 2008 at 8:31 AM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    I'm getting my 3 inch lift put on Monday with some Dune Grappler 33's and I'm sure they will have to do some trimming. I don't want to take off my front mud guards but I'm sure they will have to come off.:mad:
  12. Dec 6, 2008 at 8:52 AM
    rutwad
    Alabama
    my mudguards are gone! It did not look good to me with a wide tire and narrow mudguard..:)
  13. Dec 6, 2008 at 10:30 AM
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    Hey Rippin101. Are you running 33's?
  14. Dec 6, 2008 at 11:09 AM
    blackout
    blackout Member
    05 TRD PreRunner | Debadged | Lifted
    Pro Comp 6" Pro Comp Wheels & Tires
    Stay with the 35's...
    Start with a new razor knife blade, steady hand, very easy to do.
    Passenger Side Photo
  15. Dec 6, 2008 at 11:09 AM
    blackout
    blackout Member
    Drivers Side Photo
  16. Dec 6, 2008 at 11:13 AM
    blackout
    blackout Member
    After trimming about 2" I have zero rubbing. If you notice I cut at slight angle to maintain the integrity of the inner fender liner... so it does not flap going down the road.
  17. Dec 6, 2008 at 11:51 AM
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    Hey blackout.....what size rims and tires are running? Also, do they have an offset on them?
  18. Dec 6, 2008 at 12:01 PM
    RelentlessFab
    Eric
    Sparks, NV
    rutwad- you have a procomp stage 2? well dont their coilovers have a threaded body to them that you can use to add a little bit more lift to the front and then do some minor trimming on the plastic inner fenders? i think that would be pretty easy and then you wouldnt be trimming too much if thats your concern.
  19. Dec 6, 2008 at 12:40 PM
    blackout
    blackout Member
    Wheels:
    Pro Comp Xtreme Alloy "Cast" Wheels 7023
    18x9.5 / 6 on 5.5 Bolt Pattern
    BackSpace 4.75 in.
    Max Load = 2200lbs
    Finish = Cast Blast
    Hub Centric = No
    Offset = -12 mm
    Tires:
    Pro Comp XTreame 35x12.50R18
    Lift:
    Pro Comp 6" w/Front MX-2.75 Coil Overs & Rear MX-6 Shocks
  20. Dec 6, 2008 at 12:43 PM
    rutwad
    Alabama
    Yes, stage 2 and it's adjusted all the way up.
    I went out and turned the wheel to the right. The rear of the right tire is super close to the body mount. The left front wheel will touch the inner fender.
    So trimming it is.....:eek:!
