Smaller UCAs?
Discussion in 'Suspension' started by First Tacoma 2011, Feb 27, 2012.
  1. Feb 27, 2012 at 6:25 AM
    First Tacoma 2011
    First Tacoma 2011 [OP] Well-Known Member
    Bruce
    Maryland
    2011 TRD Sport Tacoma
    Toytec 3'' Lift 2'' AAL Bed Light Mod Westin Step Sides
    I have been looking around the forum for an answer and haven't found anything yet...
    I put my 3'' Toytec Lift on this weekend and had my 285 BFGs mounted on my 2011 DC Tacoma 4X4. Now the tires are rubbing on the UCA when making turns. Does anyone know of a aftermarket UCA that’s not as wide as the stock UCA? I rather not do wheel spacers unless I have no other choice. Any input would be great.
  2. Feb 27, 2012 at 6:26 AM
    Dromlace
    Dromlace Well-Known Member
    Michael
    Montgomery, AL
    2006 Tacoma TRD Sport
    any aftermarket UCA will fix the problem. it's not about width. If i remember correctly it's about the built in caster.
  3. Feb 27, 2012 at 6:30 AM
    First Tacoma 2011
    Bruce
    Maryland
    Thanks! I think I will give toytec a call and see what they have in stock. Unless you know of another vendor that will be a little cheaper.
  4. Feb 27, 2012 at 6:35 AM
    johnnym
    johnnym Well-Known Member
    john
    NH
    87 4Runner Chevy 1500
    Sas 4.7tranfer case gears 5.29s Locked front/rear
    downsouth motorsports
  5. Feb 27, 2012 at 6:36 AM
    MadToy
    MadToy Well-Known Member
    Nick
    Huntersville, NC
    07 Midnight Blue TRD
    OME 886, Dakar leafs, LR UCA's, 16x8.5 Level 8 ZX, 315 MTR Kevlar, All-Pro sliders, BudBuilt skids, Undercoverhwms winch mount, Warn M8000 with synthetic rope, ATO Hi-Lift bed mounts, Diff locker override, Hitch harness relocated to bumper, Undercover bed cover, Gromm Aux adapter, Grillcraft grill, DT pipe bombs, Custom Magnaflow exhaust, Brute Force HC bumper, TRD Supercharger
  6. Feb 27, 2012 at 6:38 AM
    Dromlace
    Michael
    Montgomery, AL
  7. Feb 27, 2012 at 6:42 AM
    First Tacoma 2011
    Bruce
    Maryland
    Thanks guys!
  8. Feb 27, 2012 at 6:46 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    You just missed a group buy on the Light Racing UCA's through Metaltech but regardless, LR will be the cheapest option. Some of the Uniball UCA's do have better clearance, google images the Total Chaos vs. the Light Racing or stock UCA and you'll see what I mean. I believe Toytec carries Light Racing.
    Check out the 2nd Gen Marketplace, there was a used set of LR UCA's for sale for around $300.
  9. Feb 27, 2012 at 6:56 AM
    wrmathis
    wrmathis Dark Lord of the Sith
    Bonaire, GA
    2006 Tacoma TRD OR 4x4
    parts and stuff
    Icon Tubulars UCA's are cheaper at wheelersoffroad than the total chaos
  10. Feb 27, 2012 at 11:31 AM
    First Tacoma 2011
    Bruce
    Maryland
    Well I called Wheeler's during lunch and he recommended Camburg UCAs for my problem. Is anyone running those? They look like they are a bit cheaper than LR.
  11. Feb 27, 2012 at 12:37 PM
    MadToy
    Nick
    Huntersville, NC
    LR's are $375 from Fatbobs......
  12. Feb 27, 2012 at 1:02 PM
    First Tacoma 2011
    Bruce
    Maryland
    So do you guys think that a pair of LR UCAs and a set of 1.25'' spacers will solve the issue?
  13. Feb 27, 2012 at 1:04 PM
    Pugga
    Massachusetts
    It might move your problem to a different location meaning you'll be chopping your cab mount and fender next.
  14. Feb 27, 2012 at 1:06 PM
    First Tacoma 2011
    Bruce
    Maryland
    I can live with that. I know I will be doing some fender cutting.
  15. Feb 27, 2012 at 2:00 PM
    SDHQ OFFROAD
    SDHQ OFFROAD Cuz Stock Sucks! Vendor
    SALES
    Gilbert AZ
    what wheels are you running? and are you having alignment issues?
  16. Feb 27, 2012 at 4:07 PM
    First Tacoma 2011
    Bruce
    Maryland
    Yeah just a little bit. So I will replace the UCAs to try to correct that issue. I have 285/70/17 BFG ATs
  17. Feb 27, 2012 at 4:59 PM
    wrmathis
    Bonaire, GA
    parts and stuff
    the camburgs that are cheaper than the LR's use a ball joint. if you going to upgrade the arms, might as well upgrade to either a better ball joint (LR's) or go to a uniball set up
  18. Feb 27, 2012 at 5:52 PM
    cnew
    cnew Well-Known Member
    Goodyear AZ
    11 DC 4x4 Sport
    So are the 1.25 spacers a must as well or will the new uppers take care of the issue??
  19. Feb 27, 2012 at 8:57 PM
    DNG
    DNG Well-Known Member
    Orange County, CA
    White 01 DC PreRunner
    I didn't know Camburg made a ball joint UCA - thought they were all uniball
  20. Feb 28, 2012 at 4:55 AM
    First Tacoma 2011
    Bruce
    Maryland
