5100 settings without rear spring TSB
Old 03-01-2012, 05:09 PM   #1
Trent [OP] Trent is offline
Trent is one of the sharper tools in the shedTrent is one of the sharper tools in the shedTrent is one of the sharper tools in the shedTrent is one of the sharper tools in the shedTrent is one of the sharper tools in the shedTrent is one of the sharper tools in the shedTrent is one of the sharper tools in the shedTrent is one of the sharper tools in the shedTrent is one of the sharper tools in the shedTrent is one of the sharper tools in the shedTrent is one of the sharper tools in the shed
Trent's Tacoma Gallery
My 2007 is no longer eligible for the TSB. My rear springs are a bit saggy. I have Firestone Ride-Rites for towing/hauling. Currently running some 16" steel wheels with 265/75/16 Duratracs with no issues.
My stock shocks are toast. Tons of body roll and a very jouncy ride.
I want to replace my shocks with the end result being increased ride comfort primarily and maybe a lift/level if it can be done without impacting ride comfort. I drive 20,000 miles a year.
Would 5100s all around with the fronts set at .85 do it? Should I leave them at zero?
I seem to remember someone on here saying that the rear 5100's are designed for a lift in mind and don't perform well at stock height. Any validity to that?
Thanks,
Trent
Old 03-01-2012, 05:17 PM   #2
chris4x4's Avatar
chris4x4's Tacoma Gallery
Measure teh rear, and see how much higher it is than the front. If its 1" or more, the .85" setting would be fine.
Old 03-01-2012, 05:24 PM   #3
"Rumors of Bob, but never Bob. It is Bob, right?"
Bobbb is one of the sharper tools in the shedBobbb is one of the sharper tools in the shedBobbb is one of the sharper tools in the shedBobbb is one of the sharper tools in the shedBobbb is one of the sharper tools in the shedBobbb is one of the sharper tools in the shedBobbb is one of the sharper tools in the shedBobbb is one of the sharper tools in the shedBobbb is one of the sharper tools in the shedBobbb is one of the sharper tools in the shedBobbb is one of the sharper tools in the shed
Bobbb's Avatar
Bobbb's Tacoma Gallery
Dunno about leaving the 5100's at zero, but when I had them at 1.75 w/o the rear TSB, I had a 3/4" negative rake. I concur with Chris on the .85 setting.
Bilstein 5100 settings w/o TSB? Motorjock 721 2nd Gen. Tacomas 10 08-29-2013 06:22 AM
Billstein 5100's @ 1.75" Rear Spring TSB and 265/70/R17 Tires NC15TRD Suspension 20 01-30-2011 02:49 PM
Bilstein 5100 settings without rear TSB taco dawg Suspension 8 05-20-2010 04:06 PM
Canada TSB rear spring tsb 2010 skichiiwa 2nd Gen. Tacomas 5 02-23-2010 10:29 AM
Bilstein 5100 Settings for non-TSB rear suspension lift? FloridaFeMan Suspension 9 12-30-2009 03:21 PM
