Piggyback or Remote Reservoir??
Old 03-11-2012, 11:46 PM   #1
Rakso [OP] Rakso is offline
CeRaTi
Rakso is one of the sharper tools in the shedRakso is one of the sharper tools in the shedRakso is one of the sharper tools in the shedRakso is one of the sharper tools in the shedRakso is one of the sharper tools in the shedRakso is one of the sharper tools in the shedRakso is one of the sharper tools in the shedRakso is one of the sharper tools in the shedRakso is one of the sharper tools in the shedRakso is one of the sharper tools in the shedRakso is one of the sharper tools in the shed
Rakso's Avatar
Rakso's Tacoma Gallery
I got these sick Fox 2.0 rear shocks a couple of weeks ago from DSM, and after installing them I'm starting to wonder if I should leave them as piggys or get them Remote.
I've heard different opinions about both styles, some say oil flow is better on remotes and other say it's better on piggys.
Whats do you guys think?
Old 03-11-2012, 11:47 PM   #2
it's about the off-road miles
tacokid09 is one of the sharper tools in the shedtacokid09 is one of the sharper tools in the shedtacokid09 is one of the sharper tools in the shedtacokid09 is one of the sharper tools in the shedtacokid09 is one of the sharper tools in the shedtacokid09 is one of the sharper tools in the shedtacokid09 is one of the sharper tools in the shedtacokid09 is one of the sharper tools in the shedtacokid09 is one of the sharper tools in the shedtacokid09 is one of the sharper tools in the shedtacokid09 is one of the sharper tools in the shed
tacokid09's Tacoma Gallery
im interested for an answer as well.
Old 03-11-2012, 11:48 PM   #3
chris4x4's Avatar
chris4x4's Tacoma Gallery
I dont think it makes a difference.
Old 03-11-2012, 11:55 PM   #4
Superior Member
707tothe907 is one of the sharper tools in the shed707tothe907 is one of the sharper tools in the shed707tothe907 is one of the sharper tools in the shed707tothe907 is one of the sharper tools in the shed707tothe907 is one of the sharper tools in the shed707tothe907 is one of the sharper tools in the shed707tothe907 is one of the sharper tools in the shed707tothe907 is one of the sharper tools in the shed707tothe907 is one of the sharper tools in the shed707tothe907 is one of the sharper tools in the shed707tothe907 is one of the sharper tools in the shed
707tothe907's Avatar
707tothe907's Tacoma Gallery
I guess technically there's slightly more oil In a remote due to the longer hose length.
Also, you get to show off the resi which will make bro's flock to your truck.
Old 03-12-2012, 12:13 AM   #5
CeRaTi
Rakso's Avatar
From the www
"Fox Piggyback Shocks are a compact and good looking version of the remote reservoir model. They are a light duty shock best suited for the customer looking for a little extra "Bling, bling." Fox piggyback shocks feature a reservoir able to rotate 360 degrees around the body for fitment into many types of vehicles. One drawback that is less obvious of these shocks is that the oil flows less efficiently thru to and from the reservoir than the remote reservoir model. So for those who want maximum performance out of this type of damper we recommend the remote reservoir fox shocks."
From ttora
"Generally, a piggyback allows a higher flow rate through the connecting tube than through the hose on a remote reservoir. The main difference is really in attaching the reservoir near the seal, or near the top of the shock.
When the shock collapses, the shaft volume displaces fluid accordingly, moving the dividing piston.
With the connector at the top, the high pressure side of the piston (during compression) will be acting against the nitrogen charge as well as the interaction between shim stack/valve and fluid...so the nitrogen chamber will compress more than just what is required to accommodate the collapsing shaft volume--in other words, you're losing compression dampening.
With the connector at the bottom, the high pressure side of the piston is only pushing against fluid, and the dividing piston will still shift according to how much shaft volume is within the shock.
So, if you have room, get a piggyback with the connector near the seal"
Old 03-12-2012, 02:14 AM   #6
Sublime is one of the sharper tools in the shedSublime is one of the sharper tools in the shedSublime is one of the sharper tools in the shedSublime is one of the sharper tools in the shedSublime is one of the sharper tools in the shedSublime is one of the sharper tools in the shedSublime is one of the sharper tools in the shedSublime is one of the sharper tools in the shedSublime is one of the sharper tools in the shedSublime is one of the sharper tools in the shedSublime is one of the sharper tools in the shed
Sublime's Avatar
Sublime's Tacoma Gallery
How close does that resi get to your tire when stuffed? Looks pretty close!
Old 03-12-2012, 02:17 AM   #7
if you have to ask, u can't afford it
tacobo670 is one of the sharper tools in the shedtacobo670 is one of the sharper tools in the shedtacobo670 is one of the sharper tools in the shedtacobo670 is one of the sharper tools in the shedtacobo670 is one of the sharper tools in the shedtacobo670 is one of the sharper tools in the shedtacobo670 is one of the sharper tools in the shedtacobo670 is one of the sharper tools in the shedtacobo670 is one of the sharper tools in the shedtacobo670 is one of the sharper tools in the shedtacobo670 is one of the sharper tools in the shed
tacobo670's Avatar
tacobo670's Tacoma Gallery
idk i think its personal preference. piggy back looks "cleaner" but the remote resi offers variable mounting spots, so as not to look to clustered. also gives some space/clearance during wheel travel IMO.
Old 03-12-2012, 07:00 PM   #8
CeRaTi
Rakso's Avatar
I haven't measure but yeah it's pretty close, I'm afraid it will hit either the lift pack or the U bolt plate.
This is exactly why I'm debating between leaving them as they are or get them remote.
FS: Edelbrock remote reservoir shocks fastguy95 Buy / Sell / Trade 7 02-15-2011 11:19 PM
05+ Taco F/R Remote Reservoir Shocks wesj Buy / Sell / Trade 14 08-27-2010 05:48 PM
Fox 2.0 remote reservoir bracket? shockme Suspension 12 06-21-2010 03:09 PM
Icon remote reservoir rear shocks mounting question Tillers_Rule 2nd Gen. Tacomas 9 03-18-2010 02:17 PM
Icon Remote Reservoir Coilovers Pat Suspension 0 08-25-2008 11:30 AM
