Need help baaaaaad n ASAP...
Discussion in 'Suspension' started by live4perfection, Mar 13, 2012.
  1. Mar 13, 2012 at 11:22 PM
    live4perfection
    live4perfection [OP] Well-Known Member
    Deep South Texas
    '12 TRD SPORT 4x4 LONG BED
    Just bought my 2012 DCLB TRD Sport 4x4 today...gonna lift it tomorrow...will probably get the RevTek 3"...is that an ok lift? $700 installed? I could never install anything by myself so paying someone else is my only option. Also....tire size? Rim size? 285 or 33's? Will they rub? Will I need to cut? I didnt find many examples to look at on the build threads. I need help baaaaaaaad...and quick...I'd really appreciate it. I'm new to the Tacoma World in general. Thanks in advance. Here's my truck and the wheel/tire I'm getting installed...
  2. Mar 13, 2012 at 11:47 PM
    Manwithoutaplan
    ID
    first of all congrats on the new wheels :D and welcome. You are going to rub and yes you are going to have to cut back some fender. YOu dont waste anytime lifting your truck, just be advised that some dealership i mean stealership wont accept warrenty work on a lift truck which is gay. Did you get the Add a leaf with the lift?? the wheel size you might want to look for 285/70/17.
  3. Mar 13, 2012 at 11:51 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    C'mon dude. put your big boy pants on & get out of the new members area, c'mon its safe..:p
    Plus you got a few questions but all I'll answer is if you offroad, dont get spacer lift & with 285's you'll have to cab chop & trim some plastic..:cool:;)
  4. Mar 13, 2012 at 11:55 PM
    Manwithoutaplan
    ID
    Agree. research it a little before you pull the trigger.
  5. Mar 14, 2012 at 12:00 AM
    SpeedBlueTaco0502
    SpeedBlueTaco0502 Well-Known Member
    Nick
    Fresno CA
    TRD Pre Runner
    Hankook Dynapro ATM RF10, Plasti Dip Inner Grille, Plasti Dip lower bumper. Bilstein 5100 1.75
    Congrats and GREAT CHOICE on the WHEELS! I'm buying those as well!
  6. Mar 14, 2012 at 12:06 AM
    Bishop2Queens6
    Bishop2Queens6 Well-Known Member
    SoCal
    2009 DCSB SR5 4x4
    Icon 2.5 RR/w CDCV 700# springs Front Shocks JBA UCA's Wheeler's Offroad Superbump Front Bump Stops Icon 2.5 RR/w CDCV 4"+ Rear Shocks AllPro Expo Rear Leaf Pack Timbren Rear Bump Stops ARB Front Bumper @Shmellmopwho Rock Sliders w/ Kickout RCI Aluminum Front Skid Plate Prinsu Roof Rack Roll-N-Lock Tonneau Cover CBI Ditch Light Brackets Cali-Raised LED Ditch Lights Cali-Raised Amber Fogs Cali-Raised Flush Mount LED Pods
    That Revtec spacer lift is a waste of money, and the dealership is def. ripping you off. What it does it severely pre-loads the stock spring and strut which are not designed to handle that amount of stress. Another member here had a space lift, went off roading , and it snapped his OEM strut.
    If you want a quality budget 3-in lift:
    Front strut: http://downsouthmotorsports.com/i-8...5100-series-front-ride-height-adjustable.html
    Front springs: (Even though they say 1.6 inch of lift, if you set the strut I posted at 0.85 in. w/ this spring it will give you close to 3 in)
    Rear shock:http://downsouthmotorsports.com/i-135588-bilstein-5125-series-performance-shocks.html
    Rear add-a-leaf:
    This would put you under $600 for a very very reliable life, and a much better ride quality than stock, this is assuming you do all the work yourself.
    Also, you're wheel and tire combo is good. The 285 will def rub if you don't do some trimming of the inner fender liner and chop the cab mount (they're bigger than they need to be anyways). Make sure you have enough back spacing to clear the Upper control arm and you'll be good to go.
  7. Mar 14, 2012 at 12:16 AM
    Derpy Derek
    Derpy Derek Well-Known Member
    Derek
    Brookings, OR
    2012 TRD Sport 4x4 DCSB
    ARB Bumper, Smittybilt X20, King suspension
    I wonder if wheel spacers would be necessary for his setup.. I would go with the Bilstein/Eibach setup like Bishop suggested if you can.
    Glad to see you got those rims.. They look amazing; especially when they're wrapped in those Nittos. :drool:
  8. Mar 14, 2012 at 12:30 AM
    BulletToothTony
    BulletToothTony You’ll have that on these big jobs.
    You can call me Susan if it makes you happy.
    Stay away from revtek do a quality lift ie: billy 5100's, OME, or coilovers nice truck and tire wheel combo too
    Edit: is that the actual wheel and tire you have right now didnt see that they were 305's you will have to cab mount chop for sure and trim your fender like crazy
  9. Mar 14, 2012 at 12:41 AM
    live4perfection
    Deep South Texas
    First off thanks for the info everyone...im used to having lifts on all my trucks so walking up to my stock truck at the moment just doesnt feel right. I wont feel comfortable till its lifted, etc. So...I was adding all these items to my cart...but ran into waaaay to many options in the valving/travel order form for the Bilstein 5125 series...need help on that.
  10. Mar 14, 2012 at 12:46 AM
    live4perfection
    Deep South Texas
    I'll definitely order all these items instead...and that pic is not the actual tire sz I'm getting...shooting for 285-75-18...sound about right?
  11. Mar 14, 2012 at 12:48 AM
    BulletToothTony
    i think it would be 285/60/18 or 65 something like that... And if you have some of the basic tools you can install the lift yourself and save all that money.... If you were closer i would help but good luck....
  12. Mar 14, 2012 at 12:49 AM
    2008taco
    2008taco Well-Known Member
    chris
    san diego
    They are legally required to prove that you lift, or other mods caused what ever it is being fixed under warranty. You may have to fight them occasionally, but you can get it done. If you get the spacer lift however, it would be easier for them to say the lift caused any damage to the suspension.
    Edit: Your tire choice, as said, will require additional work to fit without rubbing
  13. Mar 15, 2012 at 11:31 AM
    tacoteacher
    tacoteacher Well-Known Member
    socal
    05 SR5 access cab 4wd
    Stock for now
    Welcome rom SoCal!
  14. Mar 15, 2012 at 11:43 AM
    FoundOffRoadDead
    FoundOffRoadDead whiptastic handling
    Shamus
    Walnut
    Ford
    Few Questions for you.. Are you going to be off-roading in this truck or not?
    If so where? If your going to lift it don't. Save the money that your going to lift it with and buy suspension instead of a lift. You will love it in the long run. Breaking $700 lift while off-roading is not fun.. Look at some of these guy's builds.. To get an idea of what you want.
    -Show truck or off-road truck-
  15. Mar 15, 2012 at 11:45 AM
    FoundOffRoadDead
    Shamus
    Walnut
    Ford
    It might be. Would add a cool look to the truck.
  16. Mar 15, 2012 at 11:46 AM
    brny67
    brny67 Well-Known Member
    Bill
    Moyock NC
    08 TRD Sport A/C
    welcome,and that rim& tire combo is pretty killer pics when all said and done plse
  17. Mar 20, 2012 at 9:22 PM
    live4perfection
    Deep South Texas
  18. Mar 20, 2012 at 9:24 PM
    LAoffroadin
    LAoffroadin BURY ME WITH MY TACO!!
    Joshua
    Northwest
    2012 offroad 4x4
    ICON stage 5 coilers w/ ICON ucas, dakar leaf pack with Fox rears, k&n cai, LED cab light, raceline 16 inch wheels , toyo m/t 33",painted front yota emblem gloss white, retrofit headlights with mirrimoto 3 " lenses running the 6k headlights. Bhlm, bestopper, wet okole seat covers (max 4), weather tech mats,winch with piaa fogs. All pro apex front bumper. Sliders etc
    this isnt true.... new law states that the dealership has to prove that the aftermarket part you had placed on the vehicle is or was the main cause or a contributing factor of the damage..
  19. Mar 20, 2012 at 9:32 PM
    TrdSurgie
    TrdSurgie revised
    Oahu
    Nice looking truck
  20. Mar 20, 2012 at 9:40 PM
    jammdogg
    jammdogg Well-Known Member
    James
    Hillsboro, OR
    13 Spruce Mica DCLB
    6" ProComp lift on 35 MT's. ARB Bumper.
    Well done OP. The SuperWhite taco with those rims looks good.
    Which lift did you go with?
    J
