final questions before I order my lift...
Discussion in 'Suspension' started by SAIRS, Mar 28, 2012.
  1. Mar 28, 2012 at 6:44 PM
    SAIRS
    SAIRS [OP] Well-Known Member
    Kelly
    Utah
    Super White 2012 Double Cab LB TRD SPORT
    Icon Extended Travel Stage 1, Total Chaos UCA's, Dakkar leaf pack, Beefed DCLB Sliders with extended kickout and custom BSP, Beefed Custom exo-rear tube bumper, Toyota bed mat, tailgate theft mod. Front mudflaps removed, Access LE soft tonneau cover, Weathertech digital floor mat, Weathertech window deflectors, Weathertech license plate frames. future plans = diamond plate tailgate mod, Venture Shield, TRD supercharger...the dream goes on and on....
    So I have a 2012 Double Cab Long Bed 4x4 Sport. I am ordering the Toytec ULK, with LR UCA's, and the Dakkar leaf pack. I am also ordering the carrier bearing drop. I am going with the XD Monsters 18x9 with the Nitto Trail Grapplers 285/65/18.
    I may end up installing the lift and put the stock wheels back on for a few days while I wait to have the tires and wheels show up at Discount. Will I run into problems not getting the stock wheels back on once the lift is installed without the wheel spacers? I plan on installing the lift, then adding the tires and wheels, maybe the same day. I dont want to get the lift installed and realize then I have a problem since I cant get the wheels back on...
    question that I have....it sounds like most frown on getting wheel spacers. from what I am seeing, spacers are needed when lifting and keeping the stock wheels on the truck. The wheels will have the 5 inch back space. the guys I have seen on this forum with these wheels do not have wheel spacers. I am assuming they are not necessary
    then there are the backspace questions...
    http://www.4wheelparts.com/Wheels/X...=18.00&Width_PQ=9.00&Bolt+Pattern_PQ=6+on+135
    4.53 inch backspacing
    5.71 inch backspacing
    people have said 5 inch back space. Well, I cant exactly average the backspacing here so....which one? the 5.71 or the 4.53?
    Even though I have 4wheel parts here, I am going through Discount Tire.
  2. Mar 28, 2012 at 6:48 PM
    Foihdzas
    Foihdzas VA7PTZ
    Danny
    B.C Canada
    2010 Dbl Cab 5' Box 6 Speed
    2010 Tacoma, sold...
    Your lift won't affect your ability to put on stock wheels. As far as I have researched, 4.5" backspacing is sufficient. Someone call me out on that please.
  3. Mar 28, 2012 at 6:53 PM
    SAIRS
    Kelly
    Utah
    I also forgot one more question. Will I need that trim pack to offset the taco lean? from what I am reading, it looks like the OME kit is what this is used for. should i still order it with the ULK?
  4. Mar 28, 2012 at 6:54 PM
    OZ-T You are going backwards
    That only works with the OME shocks
  5. Mar 28, 2012 at 6:56 PM
    especk
    especk Nothin' Special
    Erik
    Redding, CA
    2010 Tacoma Reg Cab 4x4
    3" OME lift with 885 coils on nitrocharger 90000 shocks with 5mm trim packer on driver's side, TC UCAs, Rear OME Dakar leafs with nitrocharger shocks, All-pro U-bolt flip kit and 3* Toytec shims, extended rear brakelines, 16" Raceline Rockcrusher 887 wheels with 3.6" backspacking, BFG KM2 305/70/16 tires, Doug Thorley header, Doug Thorley catback exhaust, Volant CAI with ram air, Weathertech floor mats, Kicker 12" sub, Kenwood 500W RMS amp, Relentless Fab front and rear bumpers, 4.88 gears, custom flatbed with swing out tire carrier
    definitely get the 4.53" backspacing.
    the ULK doesn't need a trim-packer spacer because they are adjustable. just crank the driver side up a little more
  6. Mar 28, 2012 at 6:56 PM
    Foihdzas
    Foihdzas VA7PTZ
    Danny
    B.C Canada
    No because the coilover is adjustable, and you can turn up the drivers side a little more than the passenger.
  7. Mar 28, 2012 at 7:03 PM
    SAIRS
    Kelly
    Utah
    Thanks guys, thats what I was thinking. that trim pack wont be in the cart!
    So with the 4.53 backspacing, the wheels and tires will be sticking out a bit more than the 5.71 if I understand back spacing correctly. it should have a wider stance, even though it is minimal. Am I correct on this?
  8. Mar 28, 2012 at 7:08 PM
    especk
    Erik
    Redding, CA
    yup. this will give u the least amount of rubbing
  9. Mar 29, 2012 at 8:54 PM
    SAIRS
    Kelly
    Utah
    So I called toytec today and the billie rear shocks for the ULK are on back order until May. They will substitute the OME shock for the rears if I go with the ULK. I can get a $500 credit for my stock tires if I trade them in to the tire store before 2000 miles and I am a few weeks away from that, so May wont work for me. I also dont want to have my truck look like someone who is wearing mismatching socks. I want to keep the shocks looking the same.
    It looks like I can get the extended travel ICON lift kit, with the diff drop, carrier bearing drop, shims, Dakkar leaf pack, u-bolts, LR UCA and anything else I'm forgetting shipped for about $2335 with the TW Discount. Unless someone gives me a good reason, I am going to order this kit tomorrow most likely. just trying to get my taxes wrapped up.
  10. Mar 29, 2012 at 8:55 PM
    Toy Yoda
    Toy Yoda gotta make sure Youtube comes down to tape this
    Garrett
    06 DCLB
    OME, ARB, Warn, Snugtop XV
