Pre-order lift kit questions
Old 03-30-2012, 06:44 AM   #1
kevlar119 [OP] kevlar119 is offline
kevlar119 is on a distinguished road
Coast Guard: WMEC 617
kevlar119's Tacoma Gallery
Hi, I am about order a Toytec kit and still have questions after reading other messages on here. Just when I think I have it right, I see another thread that changes it. I'm also still not sure if I need spacers or not. Any guidance will be greatly appreciated. Thanks in advance!
Vehicle - 2005 Tacoma Access Cab SR5 TRD 4x4 - I will not be using it for off-roading - - I am adding a truck cap and then having the vehicle wrapped for business advertising - -I just wanted a better looking stance.
Here is what I am leaning towards: (Toytec was unable to assist - said they don't answer tire/wheel questions)
Toytec Ultimate lift package with Radflo front coilovers:
  • 2.0" diameter shock body Radflo coilovers
  • front diff drop kit for 4x4s
  • Rear OME CS047R Dakar Leaf Springs
  • Bilstein rear 5100s
V-Tec Offroad 326 Wheels (pics below -sorry for sizing - couldn't reduce)
  • black
  • 17x8.5
  • offset +18mm
  • Centerbore 106.2mm
BFG All Terrain KO Tires 285/70/17
No new upper arms (unless I need them)
Spacers?
Will eventually be adding new (heavier) front and rear bumpers
Old 03-30-2012, 06:09 PM   #2
KPT KPT is offline
sees what you did there.
KPT's Avatar
KPT's Tacoma Gallery
You will need wheel spacers. I'd find a different wheel with better specs.
Old 03-30-2012, 08:06 PM   #3
What specs would I need and what spacers? Thanks!
Old 03-30-2012, 08:34 PM   #4
Bullwinkle J. Moose
bjmoose is one of the sharper tools in the shedbjmoose is one of the sharper tools in the shedbjmoose is one of the sharper tools in the shedbjmoose is one of the sharper tools in the shedbjmoose is one of the sharper tools in the shedbjmoose is one of the sharper tools in the shedbjmoose is one of the sharper tools in the shedbjmoose is one of the sharper tools in the shedbjmoose is one of the sharper tools in the shedbjmoose is one of the sharper tools in the shedbjmoose is one of the sharper tools in the shed
bjmoose's Avatar
bjmoose's Tacoma Gallery
On a 17x8.5 rim, you'd want backspacing around -6mm (as opposed to +18mm)
That's a full inch less backspacing on a rim of identical width.
about to place my order for OME lift kit ross123 ToyTec Lifts 20 01-12-2013 11:13 AM
final questions before I order my lift... SAIRS Suspension 9 03-29-2012 08:55 PM
Pre-lift worries and questions Nonfatwater7 2nd Gen. Tacomas 2 12-30-2010 06:54 PM
Pre-Order the New 2011 tarheelfan_08 2nd Gen. Tacomas 4 07-14-2010 06:09 AM
Windows 7 Pre-Order $50 lsocoee Technology 31 07-19-2009 03:02 AM
