2009 Taco Lift Options
Old 12-17-2008, 03:34 PM   #1
STLTaco09 [OP] STLTaco09 is offline
STLTaco09 has a spectacular aura aboutSTLTaco09 has a spectacular aura aboutSTLTaco09 has a spectacular aura about
STLTaco09's Tacoma Gallery
Hello all, new member here. 2009 DC TRD Sport.
I bought this truck with every intention of lifting it, probably 3". I've researched plenty, and I am aware of my options. The more I read though, the more hesitant I am. People are having drive line vibrations, front diff problems, CV problems, etc - even with lifts as small as Bilstien 5100s set at 1.75" with the rear TSB. Is there any sure-fire way of getting a minor lift without having these issues? Are these issues a result of a poor install (i.e. would a professional installation result in no issues).
Lastly, if I am concerned with factory warranty, am I better off just putting the whole idea on hold until the warranty expires? I'd rather not battle a dealership 2 years down the road about front diff problems that would have occurred even without the lift...
I posted this over in TN as well, I'm sure some of you are members at both places. Hopefully nobody minds posting the same question in both forums.
Thanks for any insight - lots of good info here. Hopefully I'll be able to contribute at some point.
Old 12-17-2008, 05:52 PM   #2
Piss off
jhodge83's Avatar
jhodge83's Tacoma Gallery
if u want a good 3" setup w/ no issues, get 3" coilovers w/ a diff drop (if 4x4) and new UCA's. the rear would be good w/ 1.5" NEW leaf packs
Old 12-18-2008, 03:16 PM   #3
cdnbanker is on a distinguished road
cdnbanker's Tacoma Gallery
do the 09's need the new leaf packs too?
frig, i will have to get them done.
Old 12-18-2008, 03:22 PM   #4
mjp2's Avatar
mjp2's Tacoma Gallery
Skip the diff drop. On the new trucks it doesn't have as much of an effect as it did on the older models. I have one in my truck and would have been happier without it.
Driveline vibrations can be helped by installing a center support bearing drop kit on the rear driveshaft to reduce U-joint angles.
http://toyteclifts.com/index.php?pag...mart&Itemid=53
Good luck and post pictures!
Old 12-18-2008, 03:59 PM   #5
Piss off
jhodge83's Avatar
well if u want the rear to be level w/ the front after 3" in the front....then u'll need a 1.5" leaf pack.
and as for the diff drop, $15-20 is worth the extra piece of mind
Old 12-18-2008, 04:04 PM   #6
Piss off
jhodge83's Avatar
Originally Posted by silverback07 View Post
But you can't install BB skids over it without serious fab work.
i installed my allpro over mine w/ no probs
Old 12-18-2008, 04:18 PM   #7
Can you pass the bailout please?
LonghornTaco is one of the sharper tools in the shedLonghornTaco is one of the sharper tools in the shedLonghornTaco is one of the sharper tools in the shedLonghornTaco is one of the sharper tools in the shedLonghornTaco is one of the sharper tools in the shedLonghornTaco is one of the sharper tools in the shedLonghornTaco is one of the sharper tools in the shedLonghornTaco is one of the sharper tools in the shedLonghornTaco is one of the sharper tools in the shedLonghornTaco is one of the sharper tools in the shedLonghornTaco is one of the sharper tools in the shed
LonghornTaco's Avatar
LonghornTaco's Tacoma Gallery
+1.
mjp2 had issues installing his BB's over them, had to modify the skids. I have BB's in the garage awaiting install. I threw out these two crossmember braces when I had the All Pro skids on (AP's didn't use them) and didn't think I would need them .. DOH! Anyhow, they should be here early next week and I'll be putting them on. I might try to see if I can make them work with the DD. Worst case I loose an hour or so. But I don't think its really needed, my CV angles are fine. I figure I destroyed my AllPro skids in less than a year, I'd much rather have BB skids and no diff drop than AllPro skids and a diff drop.
Very good point, but if you have no plans to install Bud Built skids, then do the diff drop. Then you can take it off later if you DO get the BB skids...
Old 12-18-2008, 04:54 PM   #9
Nor*Cal
norcalbb11 has a spectacular aura aboutnorcalbb11 has a spectacular aura about
norcalbb11's Avatar
norcalbb11's Tacoma Gallery
Send a message via AIM to norcalbb11 Send a message via Yahoo to norcalbb11
wow so how much was everyones lifts here?
Old 12-18-2008, 05:10 PM   #11
Nor*Cal
norcalbb11's Avatar
wow so got to put down a good amount of money to get a good lift huh
Old 12-18-2008, 05:14 PM   #13
Nor*Cal
norcalbb11's Avatar
yeah i know what you mean, i want to do it right the first time for sure
Old 12-18-2008, 05:16 PM   #15
Nor*Cal
norcalbb11's Avatar
so do i get the 5100's with this as well as the toytec or no
Old 12-18-2008, 05:20 PM   #17
Nor*Cal
norcalbb11's Avatar
and the coilovers is the lift? and you have the 5100 set at stock right
Old 12-18-2008, 05:28 PM   #19
Nor*Cal
norcalbb11's Avatar
thanks, sorry i kinda took over this guys thread but i also have a 2009 so figured why not ask questions as well haha
options for my taco rockostaco Technical Chat 3 03-12-2011 10:39 AM
3" Lift Tire/Wheel lift options. dman597 Wheels & Tires 17 09-21-2010 03:14 PM
2009 guys, seat cover options white91formula 2nd Gen. Tacomas 25 01-16-2010 08:35 AM
2009 Driving Light options mcgiiver 2nd Gen. Tacomas 4 05-17-2009 08:52 PM
2009 tacoma options??? bisdak10 2nd Gen. Tacomas 0 12-27-2008 06:51 AM
