Need help putting front shocks back on, not lining up
Discussion in 'Suspension' started by white toy taco, Apr 26, 2012.
  1. Apr 26, 2012 at 9:11 AM
    white toy taco
    white toy taco [OP] 505 Member
    Albuquerque, NM
    '06 OR and '02 OR (sold)
    So i switched out my front shocks and I can't seem to get them back on. The bottom is not lining up right. It's lined up right in the "left" and "right" direction but I need the shock to go up so I can get the bolt through.
    No matter what I try, I cannot seem to get it lined up. I do have the daystar 2.5 inch spacer on top but it shouldn't make much of a difference, right? ill try and post some pics this afternoon.
    EDIT: pics are posted a few replies down
  2. Apr 26, 2012 at 9:42 AM
    white toy taco
    Albuquerque, NM
    Yea the suspension is at full droop. I feel like it shouldn't be this difficult...
  3. Apr 26, 2012 at 9:51 AM
    98tacoma27
    Ben
    Not Beech Creek
    Try disconnecting the sway bar. That will alloy you to push the LCA down further.
  4. Apr 26, 2012 at 11:57 AM
    white toy taco
    Albuquerque, NM
    i havent had my sway bar on for months....
  5. Apr 26, 2012 at 11:59 AM
    white toy taco
    Albuquerque, NM
    ok heres some pics of this stupid thing
  6. Apr 26, 2012 at 12:01 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    As mentioned, Push down on the Control arm, and use a screw driver to aid in lining up the hole. Then start the bolt.
  7. Apr 26, 2012 at 12:14 PM
    98tacoma27
    Ben
    Not Beech Creek
    Yep, gonna need to push down. I've used long bars to leverage the LCA down and a spud bar to align the holes.
  8. Apr 26, 2012 at 12:18 PM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    Prybar between the bottom of the coilover and the LCA. Large pin punch to align the hole. Push bolt through when aligned.
    Oh yea...patience, beer, and NO screwdrivers. They have a tendancy to slip and gouge.
    ^beat me to it.
  9. Apr 26, 2012 at 12:20 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    LED Headlights, Volant CAI, 32" Duratracs
    Alternatively you can draw matchmarks on the LCA cam bolts, then loosen the bolts a little. The LCA will then swing down a bit more. It's easier than prying if you don't have an assistant.
  10. Apr 26, 2012 at 12:24 PM
    Manwithoutaplan
    ID
    do you have extra jack ?? if so jack up the lca a little.
  11. Apr 26, 2012 at 12:26 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    that's not full droop dude, get the bottle jack and jack the UCA down against the fender well.
  12. Apr 26, 2012 at 3:29 PM
    dmb
    dmb Well-Known Member
    Boise, ID
    This
  13. Apr 26, 2012 at 3:32 PM
    medic2230
    Murph
    Bama! Roll Tide
    ^^ YUP! Works on 2nd gen's too. :D Try the pry bar too to get the LCA lower if needed.
  14. Apr 26, 2012 at 5:45 PM
    Alexb03
    Alexb03 Well-Known Member
    Alex
    New Mexico
    06 Tacoma Double cab
    3" lift, 285/75/16, navigation,
    ive used a spring compressor too and that will give you a little play
  15. Apr 26, 2012 at 5:48 PM
    blackhawke88
    blackhawke88 wo ai ni bao bei ^_^
    SGV, CA
    07 TRD Offroad
    just take off the two upside down bolts holding your spindle to the LCA and then you can push your LCA down til it hits the ground, easiest solution
  16. Apr 26, 2012 at 9:05 PM
    white toy taco
    Albuquerque, NM
    it finally worked after using these two methods. i put the coil compressor on the bottom of the shock and the top of the UCA and it gave it enough to line up.
    thanks for your help guys!
  17. Apr 26, 2012 at 9:08 PM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    for future reference you can loosen the cam bolt which will allow the LCA to extend further down
  18. Apr 26, 2012 at 9:14 PM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    96' X-Cab 4x4 TRD Off Road Clusterfuck
    JVC Deck, 10" sub mountd in rear seat cubby, 2 LED off road lights mounted in grille, amber raptor style grille lights, LED rock lights, square led bed light, custom made fuse block tray, 12 blade Blue Sea fuse block, 100a marine circuit breaker, black plasti dipped full grille, tinted tail lights + third, Uniden 520 with 4' firestik, Bilstein 5100s with 620lb Eibach coils, Diff drop, Chevy 63 leaf swap, TG creeper joints, 14" triangulated biletein 5125s, 8" extended steel braided brake line, TG Rock Sliders, CBI Moab 1.0 front bumper, custom fabbed bed rack, full TRD E-Locker axle swap and matching re-gear with custom stand alone wiring circuit, 29 spline pinion flange from an 06 wishbone runner, tubbed for 35x12.5" general grabbers on Ultra type 181 wheels, crush sleeve eliminator, Mini ARB compressor, front ARB locker, garage fab aluminum front skid plate, custom built high clearence rear bumper, removable mothafuckin doors
    spacers:rolleyes:
  19. Apr 26, 2012 at 9:22 PM
    Forster46
    Forster46 Very nice how much?
    Nick
    Mount Vernon, WA
    The doritos locos taco
    6000k HID's, AUX Reverse Lights, 3" Rough Country Suspension Lift, Pioneer AVH-P4200 Double Din, Underglow and footwell Lights, Camo Seat Covers, Duralast Tool Box, Blacked Out Badges, Grill, Front Emblem, Midland CB Radio, Amber Strobes, POWER REAR WINDOW, cup holder LED's, Firestik 3' in bed, console divider, Ultragauge.
    This^
    I went through the same thing as the op. Basically had my entire weight on a six foot breaker bar trying to get the bastard in. Never thought about loosening the lca.
    Everyone does something wrong.
  20. Apr 27, 2012 at 12:38 AM
    white toy taco
    Albuquerque, NM
    haha yea, yea. ill be making a good money this summer and ill get some coilovers :D
