alighment issues w/ ICON C/O, Camburg UCA & spindles?
Discussion in 'Suspension' started by HAWAIICALIVEGAZ, May 29, 2012.
  1. May 29, 2012 at 7:21 PM
    HAWAIICALIVEGAZ
    HAWAIICALIVEGAZ [OP] Desert Warrior
    SHANE
    LAS VEGAS NV
    2005 TRD Pre Runner
    Dr Coilovers; Camburg UCAs; Sway bar Relocation block; Deaver J66 Leafs; ProComp extended travel rear shocks 6K HIDs & 13" antenna
    Quick question, And I don't see why I'd have any problems getting it aligned BUT...
    Right now I currently have Dr/ICON coilovers (maxed out pretty much) and Camburg UCA's. The plan is to add the spindles and take the coilovers down to NO preload.
    Question is: Will I have any issues aligning the front end at all?
    Thanks!
    Shane
    EDIT:
    in post #15
    "He explained that because the Camburg UCAs are longer, the're designed to compensate for the "droop" that's created when you use coilovers to lift the truck. So when I add the spindles and "lower" the coilovers back to ZERO PRELOAD (stock height), i'll end up with positive camber due to the longer UCAs sitting level instead of pointing downward.
    Does that make sense? it does since he went over it again with me LOL So guess now the only way to get what i'm looking for (4" of lift and good alignment) is to go back to stock UCAs or stock length UCAs then install the Spindles... "
  2. May 29, 2012 at 7:23 PM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    no you wont, you should get a amazing alignment
  3. May 29, 2012 at 7:23 PM
    TexasTacoma37
    The spindles will not make getting an alignment any more difficult.
  4. May 29, 2012 at 7:37 PM
    HAWAIICALIVEGAZ
    SHANE
    LAS VEGAS NV
    2005 TRD Pre Runner
    ^^^ I didn't think so but for some reason... My buddy told me that I might have issues with camber.. I said everything should align like stock but the wheels be pushed down 4". I'm right... Right?
  5. May 29, 2012 at 7:39 PM
    TexasTacoma37
    You are right
  6. May 29, 2012 at 7:44 PM
    nfs257
    nfs257 Well-Known Member
    DFW
    She gone
    Im having problems with the alignment... I hope its just the shop...
  7. May 29, 2012 at 7:51 PM
    HAWAIICALIVEGAZ
    SHANE
    LAS VEGAS NV
    2005 TRD Pre Runner
    ^^^ What's your setup?
  8. May 29, 2012 at 8:06 PM
    anthony250f
    Anthony
    San Diego, CA
    i had a perfect talignment before a offroading trip.....no the shop cant get me above -1.7 camber........my wheels look like ( / \ )
  9. May 29, 2012 at 8:13 PM
    Rakso
    Rakso CeRaTi
    OsKaR
    Cali
    09 PreRunner
    LSK LT in Progress, custom bed cage, DMZ SUA kit with 2.5 kings triple bypass, kings bump stops, baja bumper, rear custom tube bumper, glass all around, Weather Tech Liners, wet okole seat covers, Cluster LED Swap, HU LED Swap, hood LEDs, bed LEDs, etc etc etc
    You wont have issue. I have Icons, Built right and Camburg. No issues at all.
  10. May 29, 2012 at 8:57 PM
    nfs257
    DFW
    She gone
    Toytec coilovers ( eibach springs and 5100's) and total chaos UCA'S ....
    Edit: and maxtrac Spindles.
  11. Jun 1, 2012 at 12:44 PM
    HAWAIICALIVEGAZ
    SHANE
    LAS VEGAS NV
    2005 TRD Pre Runner
    think the spindles is what's causing it?
  12. Jun 1, 2012 at 12:48 PM
    nfs257
    DFW
    She gone
    I took the truck into an alignment shop and they said they are ok and shouldn't prematurely wear the tires...
  13. Jun 1, 2012 at 5:38 PM
    anthony250f
    Anthony
    San Diego, CA
    well yours look worse than mine......but my numbers are worse :eek: im going to replace the lca
  14. Jun 1, 2012 at 10:05 PM
    TacoLife08
    TacoLife08 Well-Known Member
    GA
    08 DC PreRunner TRD Rugged Trail SR5
    Camburg 4' Spindles, top plate spacers, 2" AAL, 285/75R/16 Terra Grapplers, Tinted Windows, Black Riveted Grille, Black Spyder Halo Healights/Tailights, FlowMaster 40 Exhaust, NFab Side Steps, Blacked out Skid Plate.
    I'm running Camburg spindles with stock UCA's and stock coilovers. Was able to reach 0 Camber .03 toe and 2.2 Castor
  15. Jun 25, 2012 at 9:51 AM
    HAWAIICALIVEGAZ
    SHANE
    LAS VEGAS NV
    2005 TRD Pre Runner
    ^^^ Ok I spoke to my buddy again.. he explained it a little better... I'm guessing the reason why you were able to reach 0 camber was because of your UCAs and them being stock.
    Does that make sense? it does since he went over it again with me LOL So guess now the only way to get what i'm looking for (4" of lift and good alignment) is to go back to stock UCAs or stock length UCAs then install the Spindles... :(
  16. Jun 25, 2012 at 9:58 AM
    allmotorrex
    allmotorrex Grove St. Fab
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    NWF crawlbox, 5.29s, rear Detriot, front Harrop, 37" SXIIs, 17x9" KMC Grenade Crawl beadlocks, Dirt King 3.5" LT kit with King shocks, Fox 12" smooth body RR, BAMF shock kit, AP 3" springs, ext. brake lines, custom 1 piece driveshaft with .135 wall tubeing, GSF front rock crawling bumper, GSF rear bumper, Relentless Fab ifs skid, BAMF k/o sliders, X2O 10K comp. winch, TP glass fenders, OKled 20"bar, EBS dimpled/slotted rotors, EBS green pads, custom K&N CAI, LCE headers, FM Super 44 w/h turn down, URD MAF, Spec clutch, LCE heavy flywheel, URD short shifter, TMPer M1 Abrams shift knob, Amsoil oil, Cobra 75wxst w/h 4' firestix, Grillcraft, FXR TRS, T1 eyelids, custom ADV Monster 60 lights, bed lights, speedo light mod, Glow Shift volt/oil pres gauges, Glow shift 2g column pod, Optima yellow tops dual battery setup w/h IBS system, Pioneer DEH-P7200HD head unit, Pioneer 600W 4ch & 350w 2ch amps for doors and sub, Wet Oakle covers
    U should end up adding negative camber by lowering the coils and giving u back more adjustment
  17. Jun 25, 2012 at 11:08 AM
    HAWAIICALIVEGAZ
    SHANE
    LAS VEGAS NV
    2005 TRD Pre Runner
    wouldn't I end up with positive camber due to the longer uppers?
  18. Jun 25, 2012 at 11:21 AM
    anthony250f
    Anthony
    San Diego, CA
  19. Jun 25, 2012 at 12:58 PM
    HAWAIICALIVEGAZ
    SHANE
    LAS VEGAS NV
    2005 TRD Pre Runner
    I just called Camburg and they said that the lowest i'd be able to take the coilovers down to would be 1" and that I should still be good to get it aligned... that would still put me up at around 5" of lift.. :/
  20. Jun 25, 2012 at 1:01 PM
    anthony250f
    Anthony
    San Diego, CA
    rcfreak has the camburg spindles and camburg uca....he has like zero preload in the front......didnt look like he had mega posotive camber:cool:
