2012 2.7 DC With Toytec Ultimate Lift...As well as UCA/Driveshaft angles.
Old 06-15-2012, 11:59 PM   #1
ryan4544 [OP] ryan4544 is offline
ryan4544 is on a distinguished road
ryan4544's Avatar
ryan4544's Tacoma Gallery
About a month ago I traded in my 07 FJ Cruiser for a Tacoma. I recently installed the Toytec Ultimate lift which includes bilstein adjustable coilovers and AAL's.
I have seen many posts with this set up or similar setups so for anyone seeing this it will be nothing extraordinary.
I enjoy this set up very much and I am satisfied with the resulting lift however I would like this post to give information to another person like me who wants to lift their tacoma and is concerned with possibly buying UCA's to correct alignment issues.
I researched the forums to learn what I could about the lift causing alignment issues and saw numerous posts about people saying some trucks will need the UCA's and some wont.
The kit I purchased included axle shims but I am not sure what degree they are or anything like that. They are just included in the Toytec ultimate lift kit.
I did purchase the OME carrier bearing drop down kit just in case the axle shims did not straighten out the drive shaft enough.
After all was said and done. I installed the axle shims but I did not install the carrier bearing drop down kit.
I took the truck to get it aligned and they were not able to get the caster aligned properly.
I do not have the alignment specs....
I ordered some TC UCA's hoping to correct the alignment issues.
I will attach pictures showing the following:
Drive line angles,UCA angles, and the lift itself.
Thanks! I had a lot of fun installing the lift!
2012 2.7 DC With Toytec Ultimate Lift...As well as UCA/Driveshaft angles.-img_20120613_120202.jpg   2012 2.7 DC With Toytec Ultimate Lift...As well as UCA/Driveshaft angles.-img_20120613_120215.jpg   2012 2.7 DC With Toytec Ultimate Lift...As well as UCA/Driveshaft angles.-img_20120613_120738.jpg   2012 2.7 DC With Toytec Ultimate Lift...As well as UCA/Driveshaft angles.-c360_2012-06-15-13-12-50.jpg   2012 2.7 DC With Toytec Ultimate Lift...As well as UCA/Driveshaft angles.-c360_2012-06-15-13-11-18.jpg
2012 2.7 DC With Toytec Ultimate Lift...As well as UCA/Driveshaft angles.-c360_2012-06-03-15-33-16.jpg   2012 2.7 DC With Toytec Ultimate Lift...As well as UCA/Driveshaft angles.-c360_2012-06-15-13-11-28.jpg
WTB: Toytec Ultimate/ UCA's usmcmax 2nd Gen Tacoma Marketplace 1 06-07-2011 10:33 AM
What are the cons to the Toytec Ultimate Lift on a DC 4x4? gtdad66 2nd Gen. Tacomas 13 03-08-2011 04:51 PM
Toytec ultimate lift kit w/TC UCA's??? Hawksdenn2 Suspension 7 01-01-2011 04:12 PM
toytec coilovers/LR UCA's/CV angles/ pics of some flex 907taco Suspension 20 10-23-2010 04:34 PM
toytec ultimate lift...need uca's???? socal19 Suspension 3 01-04-2010 07:50 PM
