Rear Suspension Setup Advice
Old 06-25-2012, 09:29 PM   #1
RubberTank [OP] RubberTank is offline
RubberTank is on a distinguished road
RubberTank's Avatar
RubberTank's Tacoma Gallery
So I really need to get new leafs, but I also wanted to get some new rear shocks with the new leafs, what would you guys recommend for a new leaf/shock setup? I can spend up to about 800$
Old 06-25-2012, 09:50 PM   #3
Custom User Title
Zac808 is one of the sharper tools in the shedZac808 is one of the sharper tools in the shedZac808 is one of the sharper tools in the shedZac808 is one of the sharper tools in the shedZac808 is one of the sharper tools in the shedZac808 is one of the sharper tools in the shedZac808 is one of the sharper tools in the shedZac808 is one of the sharper tools in the shedZac808 is one of the sharper tools in the shedZac808 is one of the sharper tools in the shedZac808 is one of the sharper tools in the shed
Zac808's Avatar
Air Force: CSAR
Zac808's Tacoma Gallery
What do u have up.front?
Old 06-25-2012, 09:57 PM   #4
MadTaco461 is one of the sharper tools in the shedMadTaco461 is one of the sharper tools in the shedMadTaco461 is one of the sharper tools in the shedMadTaco461 is one of the sharper tools in the shedMadTaco461 is one of the sharper tools in the shedMadTaco461 is one of the sharper tools in the shedMadTaco461 is one of the sharper tools in the shedMadTaco461 is one of the sharper tools in the shedMadTaco461 is one of the sharper tools in the shedMadTaco461 is one of the sharper tools in the shedMadTaco461 is one of the sharper tools in the shed
MadTaco461's Avatar
MadTaco461's Tacoma Gallery
Do an add a leaf pack like icon and spend the rest on 2.5" rebuildable shocks. do 2.0 if the 2.5's are too much. If you change your stock bumps to softer foam bumps you can take some harder hits. Think daystar makes them. That set up can do really well
Old 06-25-2012, 10:00 PM   #6
Taqoma is one of the sharper tools in the shedTaqoma is one of the sharper tools in the shedTaqoma is one of the sharper tools in the shedTaqoma is one of the sharper tools in the shedTaqoma is one of the sharper tools in the shedTaqoma is one of the sharper tools in the shedTaqoma is one of the sharper tools in the shedTaqoma is one of the sharper tools in the shedTaqoma is one of the sharper tools in the shedTaqoma is one of the sharper tools in the shedTaqoma is one of the sharper tools in the shed
Taqoma's Avatar
Taqoma's Tacoma Gallery
I was wondering the same thing....if you're not going for a lift I just took off my Toyota TRD Bilsteins and brand new 3leaf pack that has probably 1,000mi., shocks have 11k mi.
I took my truck in to get the TSB leafs done at my 10k mi service but they gave me a new 3pack instead. I now have just over 11k mi and replaced them with Deavers two days ago so the leafs are really new, shocks fairly new at 11k mi.
$100? OBO...I'm in LA if you're interested, they're taking up space in my living room
(front coilovers available too if you need...not sure what you have now)
Old 06-25-2012, 10:23 PM   #7
RubberTank's Avatar
sounds like an awesome deal, but Im going more for better performance off road.
I right now have 5100's w/Eibach springs set a 0, Ive been looking at the All Pro rear package withe the expedition leafs and fox shocks..... just a little bit more, but seems worth it. Should I go for it if I can?
Old 06-25-2012, 10:31 PM   #8
MadTaco461's Avatar
I'd do that. The guys in the dez do well with that. All about good shock power that's revalvable. Plus look into foam bump stops. The super soft red ones. Makes the truck buck less
Old 06-25-2012, 10:45 PM   #9
MadTaco461's Avatar
These guys is what I was talking about. Just got to cut that top bump off.
Old 06-25-2012, 11:00 PM   #11
MadTaco461's Avatar
They are like 60 bucks now at jegs. 3 years ago they were half that. Im shocked seeing that. Might find them on Amazon for cheaper
Old 06-26-2012, 07:20 AM   #12
Custom User Title
Zac808's Avatar
Air Force: CSAR
If u leave the front set at zero and install the AP expos your ass end is gonna be really high. And from what others have said on here expos ride stiff unless you have some weight in the rear.
Old 06-26-2012, 07:25 AM   #13
Pasti-Dip Free Since 1983
Pugga's Avatar
Pugga's Tacoma Gallery
x2. Unless you plan on jacking the front up a little more, I wouldn't go with Expos or even the All Pro Standard pack. If you want to stay around 1.5 - 2" of rear lift, you're looking at an AAL or a custom leaf pack. For AAL's, Wheeler's or Icon's 3-leaf progressive AAL's are a good choice. For custom leaf packs, check out Alcan or Wheeler's sells a Deaver leaf pack that they advertise gives you about 2" of lift. Says its designed for desert use so might not be the best for load carrying.
Old 06-26-2012, 06:24 PM   #14
DevL's Tacoma Gallery
Im not seeing how these fit on a 2nd gen.
Old 06-26-2012, 07:06 PM   #15
MadTaco461's Avatar
Cut the stock bumps flat and bolt to the frame. Basically copy a first Gen.
Old 06-27-2012, 06:11 AM   #16
Sublime is one of the sharper tools in the shedSublime is one of the sharper tools in the shedSublime is one of the sharper tools in the shedSublime is one of the sharper tools in the shedSublime is one of the sharper tools in the shedSublime is one of the sharper tools in the shedSublime is one of the sharper tools in the shedSublime is one of the sharper tools in the shedSublime is one of the sharper tools in the shedSublime is one of the sharper tools in the shedSublime is one of the sharper tools in the shed
Sublime's Avatar
Sublime's Tacoma Gallery
The red are softer than the black? I can't even find the red one's anymore!
Old 06-27-2012, 08:35 PM   #17
MadTaco461's Avatar
Ya the red is pretty soft. I can dent them in a quarter inch with my finger. Ill look for the link.
If I setup my rear suspension like this... 04LTtacoma Suspension 11 05-01-2011 10:33 AM
NEED REAR SUSPENSION ADVICE Airun Suspension 9 08-31-2010 08:12 PM
Rear suspension Setup ideas! LuckeyTRD Suspension 1 06-13-2010 04:08 PM
FS: BNIB All PRO/FoX REAR SUSPENSION SETUP!!!!MUST SEEE!!!! seemobooty Buy / Sell / Trade 9 04-20-2010 02:36 AM
Billy suspension setup advice??? krisjw101 Suspension 12 01-03-2010 02:15 PM
