How To Convert 2.5x6” Coilovers for OEM Replacement Use (2nd Gen Tacomas)
Old 08-07-2012, 08:56 PM   #41
wo ai ni bao bei ^_^
blackhawke88 is one of the sharper tools in the shedblackhawke88 is one of the sharper tools in the shedblackhawke88 is one of the sharper tools in the shedblackhawke88 is one of the sharper tools in the shedblackhawke88 is one of the sharper tools in the shedblackhawke88 is one of the sharper tools in the shedblackhawke88 is one of the sharper tools in the shedblackhawke88 is one of the sharper tools in the shedblackhawke88 is one of the sharper tools in the shedblackhawke88 is one of the sharper tools in the shedblackhawke88 is one of the sharper tools in the shed
blackhawke88's Avatar
blackhawke88's Tacoma Gallery
Originally Posted by straycat241 View Post
going spring under is the best
I texted you. Jen has 14" 600lb and wants to go 700lb. Trade?
Old 08-07-2012, 08:59 PM   #42
anthony250f is one of the sharper tools in the shedanthony250f is one of the sharper tools in the shedanthony250f is one of the sharper tools in the shedanthony250f is one of the sharper tools in the shedanthony250f is one of the sharper tools in the shedanthony250f is one of the sharper tools in the shedanthony250f is one of the sharper tools in the shedanthony250f is one of the sharper tools in the shedanthony250f is one of the sharper tools in the shedanthony250f is one of the sharper tools in the shedanthony250f is one of the sharper tools in the shed
anthony250f's Avatar
anthony250f's Tacoma Gallery
going spring under is the best did 40 miles last time i went out and there was no problems
i want to do the defined kit with the engage bed saver cage and 16" king rr smooth bodies!
Old 08-10-2012, 03:26 PM   #43
updated the first post.
the 1.5" bearing/misalignment spacers are for the lower shock mount ONLY. The Tacoma stock lower control arm lower shock mount spacing between the two tabs is 1.5"
The TOP plate adapter is most likely 1.25" spacing, which is the most common misalignment spacer on most shocks. CONFIRM this with the company you are buying the top plate spacers from first BEFORE buying the misalignment spacers for the top shock mount.
Old 08-11-2012, 10:28 AM   #44
haha i found that out the hard way ^^ lol
the resi didnt work here
Old 01-24-2013, 07:10 PM   #45
GNAR Member
EVE Designs will become famous soon enoughEVE Designs will become famous soon enough
EVE Designs's Avatar
EVE Designs's Tacoma Gallery
I'm pretty interested in running a set up just like this, but I have a couple of questions if someone is willing to help solidify my decision:
Does this set up still provide the lift that an Extended Travel Coil Over (Icon, King, Etc.) does?
Is there a predefined valving spec that the shock should run or is the normal valving straight from king nice? Or is it a matter of personal preference?
Do Engage, Camburg, or TC still offer the Coil Bucket Adapters for this application?
Does the suspension still bottom out on the Bumps or does it bottom on the shock?
Old 01-28-2013, 10:44 PM   #46
GNAR Member
Bumppp^^
Old 01-28-2013, 10:50 PM   #47
yes you can buy a top plate from engage or camburg...i bought for for like 100 from camburg...if you need one pm me...mine was used for like 1 hour and i dont need it anymore and was trying to sell it.
Old 04-15-2013, 01:06 PM   #48
kbauman92 is one of the sharper tools in the shedkbauman92 is one of the sharper tools in the shedkbauman92 is one of the sharper tools in the shedkbauman92 is one of the sharper tools in the shedkbauman92 is one of the sharper tools in the shedkbauman92 is one of the sharper tools in the shedkbauman92 is one of the sharper tools in the shedkbauman92 is one of the sharper tools in the shedkbauman92 is one of the sharper tools in the shedkbauman92 is one of the sharper tools in the shedkbauman92 is one of the sharper tools in the shed
kbauman92's Avatar
kbauman92's Tacoma Gallery
Would you these be able to work for a first gen also?
Edit: or are there different adapters to make it work
Old 08-10-2014, 03:58 PM   #49
TMACTacoma is on a distinguished road
TMACTacoma's Tacoma Gallery
Would I be able to use 2.0's for this same application?
FS: 2nd Gen Super White OEM Rear Bumper, OEM Tow Hitch, OEM Fog Lights WhiteWiddow 2nd Gen Tacoma Marketplace 11 04-19-2012 01:07 PM
are the 2nd gen Tacomas garbage? chaosbound 2nd Gen. Tacomas 127 02-28-2012 11:14 AM
2nd Gen Tacomas are good for you and your looks! GoDeacsWFU23 2nd Gen. Tacomas 28 02-18-2012 09:53 PM
Parting out 2 2nd Gen Tacomas User123 Buy / Sell / Trade 1 01-16-2010 06:27 PM
Best Color for 2nd Gen Tacomas BLU06TACO Salty 2nd Gen. Tacomas 51 11-03-2009 01:31 PM
