Is the 5100/AAL route as easy as it seems?
Old 07-01-2012, 10:35 PM   #1
762NateOh [OP] 762NateOh is offline
762NateOh is on a distinguished road
762NateOh's Tacoma Gallery
Looking to get a mild lift, and the 5100/AAL seems to be a pretty attractive option.
Is it as cheap/easy as it sounds?
I'd probably do....2.5" in the front, and ??? in the rear. 1.75? 2? (recommendations plz )
Truck is used as a daily, 90% street, not hauling heavy loads
It seems to be about $250 in parts, reasonably easy install, and an alignment and I'm GTG?
I'm a little bit naive on truck suspension. I've done a handful of car stuff.
Will I need extended brake lines?
Will I be murdering my CV joints?
Also plan on 265/75/16 tires... Would the next size up be doable? Worth it? Mainly just don't want it to look dinky, but I bet those would fill it up pretty well.
Old 07-01-2012, 10:59 PM   #2
Banned
acdronin is one of the sharper tools in the shedacdronin is one of the sharper tools in the shedacdronin is one of the sharper tools in the shedacdronin is one of the sharper tools in the shedacdronin is one of the sharper tools in the shedacdronin is one of the sharper tools in the shedacdronin is one of the sharper tools in the shedacdronin is one of the sharper tools in the shedacdronin is one of the sharper tools in the shedacdronin is one of the sharper tools in the shedacdronin is one of the sharper tools in the shed
acdronin's Tacoma Gallery
only the front shocks are adjustable, not the rears. 2.5 in the front may cause you problems with your alignment, some trucks can go that high with no problem, some can't, 1.75 in the front is not going to cause you problems but you should get it aligned at a shop that does 4x4 trucks.
depends on how high you want the front compared to the back, you can get an aal 1.5 or 2 inch, measure from the center of the hub to the bottom of the wheel well to figure out how much higher you want to go.
You do not need to get an alignment if you are only doing the rears.
1.5 or 2 inch no you don't need to.
the higher you go may cause a vibration with the front suspension, once again, 1.75 in the front should not be an issue, i did that and had a hum for a while and it's since gone away.
rear
there's a billion threads on this topic, 265's are fine, 275's may rub at full lock, search and you can spend a week reading all the threads about this.
Old 07-02-2012, 07:53 AM   #3
sirsaechao is one of the sharper tools in the shedsirsaechao is one of the sharper tools in the shedsirsaechao is one of the sharper tools in the shedsirsaechao is one of the sharper tools in the shedsirsaechao is one of the sharper tools in the shedsirsaechao is one of the sharper tools in the shedsirsaechao is one of the sharper tools in the shedsirsaechao is one of the sharper tools in the shedsirsaechao is one of the sharper tools in the shedsirsaechao is one of the sharper tools in the shedsirsaechao is one of the sharper tools in the shed
sirsaechao's Avatar
sirsaechao's Tacoma Gallery
You have a prerunner so no CV to worry about. 2.5" won't be a problem for you. Anything larger then 265/75R16 you will have to trim or do a pinch weld mod.
Old 07-02-2012, 10:30 AM   #4
Doh
Thanks guys
Old 07-02-2012, 09:34 PM   #5
Badger12 is on a distinguished road
Badger12's Tacoma Gallery
5100's and a three lief pack work better than the single AAL.
Fronts set at 2.5
Tires are 255/85/16
Yes, it works.
Old 07-03-2012, 06:30 PM   #6
Fronts set at 2.5
Tires are 255/85/16
Yes, it works.
So like this
"1.5" Lift 3 Leaf Progressive Add A Leaf Kit:149.95 A 3 leaf progressive racing style Add A Leaf set. Works with or without your factory overload leaf. Comes with longer U-bolts."
from wheelers?
Old 07-03-2012, 06:41 PM   #7
sirsaechao's Avatar
Yes or even Icon has a 3 leaf AAL.
Old 07-04-2012, 02:01 AM   #8
Banned
So like this
from wheelers?
I had a good experience with Wheeler's I would recommend them
Old 07-04-2012, 10:43 AM   #9
Yes, I bought everything from Wheelers. Very helpful people and they steered my right.
Billstein 5100 easy install method Holyfather Suspension 224 12-24-2014 07:48 PM
5100's @ 1.75 w/ TSB & 5100's @ .85/Eibach coils w/ TSB springs and TSB AAL huntark03 Suspension 0 09-27-2011 02:50 PM
5100's @ 2.5 vs Eibach & 5100's @ .85/TSB w/ 1.5 AAL for TSB vs. Dakar Leaf Pack huntark03 Suspension 56 08-14-2011 06:22 AM
Bilstein 5100/Toytec AAL/Fabtech AAL - Black Sand Pearl Satoshi benk0 2nd Gen Tacoma Marketplace 10 05-18-2011 01:59 PM
5100 with what AAL? matt86 Suspension 21 02-06-2010 07:26 PM
