5100/Eibach Lift - Rear???
Old 07-09-2012, 09:36 AM   #1
Hdeuce22 [OP] Hdeuce22 is offline
Hdeuce22 is on a distinguished road
Hdeuce22's Tacoma Gallery
Ok,as my truck sits now,my rear is exactly 2" higher than the front without the TSB. My plans are to put 5100's on all 4 corners and set the fronts at the .85 mark. In theory,this should get my front approximately .5" higher than the rear,however I want the truck to sit level. What do you all suggest me doing with the rear to compensate for that .5"? Does the 1.5" 3 leaf progressives give you a true 1.5" more than what I have now which is 3 leaf without the TSB? If so then that would put me back to 1" higher in the rear. I suppose that is better than the 2" I'm at now but just prefer the leveled out look. Thanks!
Old 07-09-2012, 09:38 AM   #2
Pasti-Dip Free Since 1983
Pugga's Avatar
Pugga's Tacoma Gallery
1/2" block. Any AAL will give you more lift than you want if you measured correctly.
Old 07-09-2012, 09:40 AM   #3
Ugh @ blocks! Isn't that what most say to stay away from Pugga? I guess it's either that or just live with the 1" higher in the rear that AAL will give me huh? Sighhh
BTW,I measured from hub center.
Old 07-09-2012, 09:41 AM   #4
More Cowbell!
VooDoo is one of the sharper tools in the shedVooDoo is one of the sharper tools in the shedVooDoo is one of the sharper tools in the shedVooDoo is one of the sharper tools in the shedVooDoo is one of the sharper tools in the shedVooDoo is one of the sharper tools in the shedVooDoo is one of the sharper tools in the shedVooDoo is one of the sharper tools in the shedVooDoo is one of the sharper tools in the shedVooDoo is one of the sharper tools in the shedVooDoo is one of the sharper tools in the shed
VooDoo's Avatar
VooDoo's Tacoma Gallery
If you want to get Eibachs...set the 5100's to .85 and throw a 2" AAL on the back. My truck sits with factory rake with this set up:
Old 07-09-2012, 09:43 AM   #5
Pugga's Avatar
I'm usually one of the people telling people to stay away from blocks but one as short as 1/2" won't do any harm. You end up with axle wrap from the tall 2 - 3" blocks.
If I were you, I'd get the front installed, see how it sits, then determine how much lift you want to give the rear.
To answer your original question, you will gain 1.5" over your current stance with the 3-leaf AAL. You can gain 2" if you keep the factory overload in place.
Possible Lift Part Out Eibach/5100/Icon... lundy 2nd Gen Tacoma Marketplace 8 12-13-2011 03:54 PM
Eibach, 5100's and rear?- help with the rear D13 Suspension 36 10-12-2011 08:05 AM
5100 @ 0 eibach coils and rear aal. Gavinfritz101 1st Gen. Tacomas 10 08-27-2011 04:21 PM
FS: ToyTec/Eibach lift coils w/ 5100's RecklessTaco 2nd Gen Tacoma Marketplace 13 05-12-2011 09:15 AM
Airbag Lift, Eibach Springs with 5100 Krewblink Suspension 2 10-05-2010 07:49 AM
