5100 Purchase
Old 07-10-2012, 07:25 PM   #1
ccurtis0805 will become famous soon enoughccurtis0805 will become famous soon enough
ccurtis0805's Tacoma Gallery
5100 Purchase
Just ordered the billy 5100s for all four corners. Stoked!
Question 1: kind of dumb to ask now (always been trigger happy), but if I were to want to do a 3" lift down the road will I be able to use the 5100s.
Question 2: will I be sacrificing ride quality if I set the fronts at 1.75? 1.75 is the setting to level out the truck, right?
Old 07-10-2012, 07:28 PM   #2
Yeti Hunter
Bennett707 is one of the sharper tools in the shedBennett707 is one of the sharper tools in the shedBennett707 is one of the sharper tools in the shedBennett707 is one of the sharper tools in the shedBennett707 is one of the sharper tools in the shedBennett707 is one of the sharper tools in the shedBennett707 is one of the sharper tools in the shedBennett707 is one of the sharper tools in the shedBennett707 is one of the sharper tools in the shedBennett707 is one of the sharper tools in the shedBennett707 is one of the sharper tools in the shed
Bennett707's Avatar
Bennett707's Tacoma Gallery
yes
yes from my understanding but not sure how much or if its measurable.
if you did your 3" lift you would need to set your 5100's at 0. you also would need a source of lift in the rear.
Old 07-11-2012, 08:50 PM   #3
Alby22 is on a distinguished road
Alby22's Tacoma Gallery
I'm looking to buy the 5100's for my 2007 4x4 double cab sport. If you don't mind me asking, where is the best place to buy them from, and how much did you pay for them?
Old 07-11-2012, 08:50 PM   #4
Yeti Hunter
Bennett707's Avatar
down south motor sports.
use (iirc) DSM5 as a coupon code or w/e for 5% off
Old 07-11-2012, 10:50 PM   #6
Yep
buzzard1992 is one of the sharper tools in the shedbuzzard1992 is one of the sharper tools in the shedbuzzard1992 is one of the sharper tools in the shedbuzzard1992 is one of the sharper tools in the shedbuzzard1992 is one of the sharper tools in the shedbuzzard1992 is one of the sharper tools in the shedbuzzard1992 is one of the sharper tools in the shedbuzzard1992 is one of the sharper tools in the shedbuzzard1992 is one of the sharper tools in the shedbuzzard1992 is one of the sharper tools in the shedbuzzard1992 is one of the sharper tools in the shed
buzzard1992's Avatar
buzzard1992's Tacoma Gallery
No it can be. I just used it today. Came out to 175
Old 07-11-2012, 10:58 PM   #7
Yeti Hunter
Bennett707's Avatar
edit im a derp
Old 07-17-2012, 12:52 PM   #8
Just got the UPS text message that my billies have arrived!
Old 07-17-2012, 01:18 PM   #9
Yep
Mine will be here tomorrow! Can you adjust the settin on the 5100s without takin them all the way back off?
Old 07-17-2012, 01:23 PM   #10
Yeti Hunter
Bennett707's Avatar
you can adjust before install, but not while they have a spring on them.
Old 07-17-2012, 01:24 PM   #11
bjhn83 is a jewel in the roughbjhn83 is a jewel in the roughbjhn83 is a jewel in the rough
bjhn83's Avatar
bjhn83's Tacoma Gallery
Nope its a ring around the piston that has to be moved. Springs have to be decompressed and removed. Far more adjustable than new shocks though
Old 07-17-2012, 01:27 PM   #12
Yep
Haha well dang. I'm just worried if I set them at 2.5 inches I'm not gonna like the way my truck looks with only 265/75/16s
Old 07-17-2012, 01:31 PM   #13
Yeti Hunter
Bennett707's Avatar
1. buy bigger tires.
2. remove and set it at a lower setting.
Old 07-17-2012, 02:34 PM   #14
Yep
Well Ill have to wait a little but before I get new tires. I can't justify buyin new ones when my bfgs still have goo tread
Old 07-17-2012, 10:42 PM   #15
Kylie's dad
WilsonTheDog is one of the sharper tools in the shedWilsonTheDog is one of the sharper tools in the shedWilsonTheDog is one of the sharper tools in the shedWilsonTheDog is one of the sharper tools in the shedWilsonTheDog is one of the sharper tools in the shedWilsonTheDog is one of the sharper tools in the shedWilsonTheDog is one of the sharper tools in the shedWilsonTheDog is one of the sharper tools in the shedWilsonTheDog is one of the sharper tools in the shedWilsonTheDog is one of the sharper tools in the shedWilsonTheDog is one of the sharper tools in the shed
WilsonTheDog's Avatar
WilsonTheDog's Tacoma Gallery
The bigger issue is whether or not you can get it aligned right at 2.5". I could not.
Old 07-18-2012, 05:11 AM   #16
So, I took out the shocks to inspect and prepare for my install. Is there a special tool that is needed to adjust the shocks to the different lengths (.85, 1.75) or does that piece just slide down, turn, and set in place?
Old 07-18-2012, 07:36 AM   #17
Yep
Mine are supposed to be at my house by 12. I've been wondering the same thing. Also I wanna put mine on tonight but because of work I won't be able to get an alignment till Saturday. Will I be fine to drive on it till then?
Old 07-18-2012, 08:20 AM   #18
Yeti Hunter
Bennett707's Avatar
yesh
Old 07-18-2012, 09:47 AM   #19
KPT KPT is offline
sees what you did there.
KPT's Avatar
KPT's Tacoma Gallery
It just snaps into whatever height you want. No tools needed for that part.
Make sure you don't install the spring perch upside down, it's very common. If installed correctly, the perch should look like a bell shape.
Old 07-18-2012, 09:52 AM   #20
Thanks! Is there any problem running the 5100s with the stock sr5 coils?
Where to purchase Bilstein 5100 Adjustable Fr. shock set hardtaco 2nd Gen. Tacomas 7 03-21-2012 01:14 PM
Ride height, 5100 at .85 or eibach/5100 at 0 lj973gm Suspension 3 12-05-2011 06:44 PM
Bilstein 5100 Part # for 3" of rear lift??? Longer than standard 5100 Deathbeard Suspension 3 01-24-2011 05:49 PM
885 + 5100 > 5100 at 2.5" Metallikatz3 2nd Gen. Tacomas 60 01-27-2010 07:23 PM
