Camburg Ball Joint UCA QUESTION
Old 07-15-2012, 11:15 AM   #1
TacomaChris has a spectacular aura aboutTacomaChris has a spectacular aura about
TacomaChris's Avatar
TacomaChris's Tacoma Gallery
Question for those of you with Camburg Ball Joint UCAs or those with a similar setup.
I'm ready to pull the trigger but with the added 2 degrees of caster I know this may push my front tires a bit closer to the rear of my wheel-well. DID YOU HAVE TO TRIM???
I'm currently running 285s with stock mudflaps. THANKS!!!
Old 07-15-2012, 11:36 AM   #2
chris4x4's Avatar
chris4x4's Tacoma Gallery
You might have to remove the mud flaps.
Old 07-15-2012, 12:49 PM   #3
Yeah...I can live with removing the front mud flaps but I'm torn on trimming any further than that. I may just have to suck it up...especially if I go with larger tires in the future
I found this pic online (it's a Tundra ball joint UCA) but it compares it to stock. You can see where the ball joint sits further back.
Thanks for the tip
Camburg BALL JOINT UCA nvdeserted Suspension 41 05-15-2014 09:11 AM
camburg ball joint uca's DAN_FPC Suspension 5 04-28-2011 09:30 PM
camburg ball joint UCA's 68vert Suspension 1 01-13-2011 06:31 AM
Camburg ball joint UCA Duff Man Technical Chat 0 12-28-2010 09:42 PM
camburg ball joint uca's Beast 2nd Gen. Tacomas 0 08-07-2010 07:04 PM
