Help on install!
Old 07-22-2012, 02:02 PM   #1
Pingo [OP] Pingo is offline
Pingo is a splendid one to beholdPingo is a splendid one to beholdPingo is a splendid one to beholdPingo is a splendid one to beholdPingo is a splendid one to beholdPingo is a splendid one to beholdPingo is a splendid one to behold
Pingo's Avatar
Pingo's Tacoma Gallery
Help on install!
Alright so I have my stock coil/strut assembly out and was attempting to compress and take them apart, however the upper strut retaining nut or whatever it's called ( the single nut holding everything together on top) refuses to come off. The problem is the upper half of the strut inside the coil is spinning. Any help is greatly appreciated as taking them to les schwab or goodyear or something to say screw it is out of the question as its sunday =/
Old 07-22-2012, 02:13 PM   #3
avidoffroad.com
McJosh is one of the sharper tools in the shedMcJosh is one of the sharper tools in the shedMcJosh is one of the sharper tools in the shedMcJosh is one of the sharper tools in the shedMcJosh is one of the sharper tools in the shedMcJosh is one of the sharper tools in the shedMcJosh is one of the sharper tools in the shedMcJosh is one of the sharper tools in the shedMcJosh is one of the sharper tools in the shedMcJosh is one of the sharper tools in the shedMcJosh is one of the sharper tools in the shed
McJosh's Avatar
McJosh's Tacoma Gallery
This:
Originally Posted by senor taco View Post
Use a cresent wrentch on the top of the shaft
Good luck
Old 07-22-2012, 02:26 PM   #4
Pingo's Avatar
Forgot to mention that our crescent wrench won't hold it... it is to small for enough leverage, however when I do get a good hold the crescent sort of strips off
Old 07-22-2012, 02:35 PM   #5
Custom User Title
Zac808 is one of the sharper tools in the shedZac808 is one of the sharper tools in the shedZac808 is one of the sharper tools in the shedZac808 is one of the sharper tools in the shedZac808 is one of the sharper tools in the shedZac808 is one of the sharper tools in the shedZac808 is one of the sharper tools in the shedZac808 is one of the sharper tools in the shedZac808 is one of the sharper tools in the shedZac808 is one of the sharper tools in the shedZac808 is one of the sharper tools in the shed
Zac808's Avatar
Air Force: CSAR
Zac808's Tacoma Gallery
Next best bet is vice grip pliers.
Old 07-22-2012, 02:38 PM   #6
TheOtherGuy is one of the sharper tools in the shedTheOtherGuy is one of the sharper tools in the shedTheOtherGuy is one of the sharper tools in the shedTheOtherGuy is one of the sharper tools in the shedTheOtherGuy is one of the sharper tools in the shedTheOtherGuy is one of the sharper tools in the shedTheOtherGuy is one of the sharper tools in the shedTheOtherGuy is one of the sharper tools in the shedTheOtherGuy is one of the sharper tools in the shedTheOtherGuy is one of the sharper tools in the shedTheOtherGuy is one of the sharper tools in the shed
Army: 63B
TheOtherGuy's Tacoma Gallery
I'd take it to a shop where they have the right tools. This can be a dangerous job with out the right tools. Those springs can screw you up pretty bad.
Old 07-22-2012, 02:46 PM   #7
Pingo's Avatar
I've done suspension work before, even though it might not sound like it I know what I'm doing and what can be dangerous ....
update : well I switched crescent wrenches to an old beefier one I forgot I had and used vice grips on the inside of the strut and struggled but eventually got it off. Thanks doods!
To install Diff drop kit or not to install? Scope3334 Suspension 16 05-20-2012 08:56 AM
= => 2009 Rear Back Up CAMERA Install on 2007? EASY INSTALL? <= = RAD 2nd Gen. Tacomas 33 04-25-2011 11:49 AM
5100's Install and AAL Install? xcmiler707 1st Gen. Tacomas 6 02-21-2011 10:37 PM
Cold Air Intake? To install, Or not to install. That is the Question. 4banger805 4 Cylinder 22 08-10-2010 01:36 PM
TRD S/C - Self-Install or Dealer Install? SManZ 2nd Gen. Tacomas 14 05-10-2010 11:20 PM
