Leaf Springs shifting!
Old 07-22-2012, 10:55 PM   #1
kodiakkid [OP] kodiakkid is offline
kodiakkid is on a distinguished road
kodiakkid's Tacoma Gallery
Angry Leaf Springs shifting!
I have the Toytec Ultimate Lift Kit which includes the rear 2.5 inch add a leaf. Ever since i installed the kit i noticed that the rear add a leafs on both sides seem to shift. I think it is normal for the leaf springs to shift, but the add a leaf springs shift so much that the friction pads that are installed on them to prevent squeaking cant do their job. This causes an extreme squeak every time i hit a small bump or even start or stop. What i have been doing is every couple of days as i notice the squeak gets to much to handle, i will take a hammer and nock the add a leafs back in line with the others and they will be good to go and won't squeak for a couple of days.
My question is if anyone has had this issue before or has a solution. I know that toyota recommends U bolts be tightens to around 35lbs. I wonder if making them tighter will help keep my leaf springs in place! Any help would be great!
Old 07-22-2012, 10:58 PM   #2
cshade is one of the sharper tools in the shedcshade is one of the sharper tools in the shedcshade is one of the sharper tools in the shedcshade is one of the sharper tools in the shedcshade is one of the sharper tools in the shedcshade is one of the sharper tools in the shedcshade is one of the sharper tools in the shedcshade is one of the sharper tools in the shedcshade is one of the sharper tools in the shedcshade is one of the sharper tools in the shedcshade is one of the sharper tools in the shed
cshade's Avatar
cshade's Tacoma Gallery
i may be wrong but i think toytec has a retainer clip for them
edit:http://toyteclifts.com/index.php?pag...mart&Itemid=72
Old 07-22-2012, 10:58 PM   #3
nfs257 is one of the sharper tools in the shednfs257 is one of the sharper tools in the shednfs257 is one of the sharper tools in the shednfs257 is one of the sharper tools in the shednfs257 is one of the sharper tools in the shednfs257 is one of the sharper tools in the shednfs257 is one of the sharper tools in the shednfs257 is one of the sharper tools in the shednfs257 is one of the sharper tools in the shednfs257 is one of the sharper tools in the shednfs257 is one of the sharper tools in the shed
nfs257's Avatar
Navy: GSM1
nfs257's Tacoma Gallery
there are 2 threads referencing your KNOWN problems. Torque to 75# or so. And take 2 little pieces of flat iron and put bolts thru them to keep from shifting.
Old 07-22-2012, 11:01 PM   #6
nfs257's Avatar
Navy: GSM1
Old 07-22-2012, 11:02 PM   #7
nfs257's Avatar
Navy: GSM1
http://www.tacomaworld.com/forum/2nd...r-torqued.html
Old 07-23-2012, 12:46 PM   #8
BTO BTO is offline
BTO is a name known to allBTO is a name known to allBTO is a name known to allBTO is a name known to allBTO is a name known to allBTO is a name known to all
BTO's Avatar
Army: 3rd Infantry Division
BTO's Tacoma Gallery
The manual says 37 lbs but that's a typo. The correct torque spec is 73 lbs. That will make a world of a difference. It did for me.
Old 07-23-2012, 01:03 PM   #9
Pasti-Dip Free Since 1983
Pugga's Avatar
Pugga's Tacoma Gallery
Whoa... didn't realize the manual had it listed that low! Retorque the u-bolts, that should help out quite a bit.
Old 07-23-2012, 01:30 PM   #11
nfs257's Avatar
Navy: GSM1
Originally Posted by 4WD View Post
Looks like you guys got him in the right direction.....
Get back to work and lets get on the trail!
FS: TSB rear leaf springs with Toytec 1.5" add-a-leaf scotch 2nd Gen Tacoma Marketplace 4 05-22-2012 10:07 AM
WTB stock leaf springs w/ add a leaf 4x4 2007 access cab 07tacos 2nd Gen Tacoma Marketplace 0 07-25-2011 10:08 AM
WTT: 4 leaf TSB for your 3 leaf original leaf springs.... sincitytaco Buy / Sell / Trade 21 12-17-2010 10:26 AM
WTT: TSB rear leaf springs for non TSB leaf springs....... sincitytaco Buy / Sell / Trade 7 06-15-2010 03:23 AM
Toytec add-a-leaf shifting apart ?? Razorecko 2nd Gen. Tacomas 21 10-29-2009 11:16 AM
