Drive shaft binding because of lift?
Discussion in 'Suspension' started by kayakred, Jul 23, 2012.
  1. Jul 23, 2012 at 6:02 PM
    kayakred
    kayakred [OP] Member
    Cody Scott
    New Orleans
    04 TRD Off Road
    Sky Jacker 2.5in Lift
    Hey All,
    I'm new to the forum. Just bought a '04 TRD Off Road w/ 24k miles on it. Crazy low I know. I'm concerned because when I take off there seems to be what feels like binding in the drive shaft. A buddy of mine drove it and came to this conclusion so we might be way off base.
    An way it has a Skyjacker 2.5in Suspension Lift and we thought that might be the cause? Has anyone heard/encountered this before?
    Thanks!
  2. Jul 24, 2012 at 12:38 PM
    Supra TT
    Supra TT Supercharged Lifter
    Eric
    Indiana
    2000 SAS D60 F/R Supercharged
    Supercharged on One Tons
    Does it vibrate when accelerating? Never heard of a driveshaft binding on our trucks.. I have over 9" of lift and no problems with my DS
  3. Jul 24, 2012 at 12:41 PM
    mjp2
    Milton Juevo Portimous II
    NJ
    Do the pre-05 trucks have driveshaft carrier bearings? Yours could simply be worn out and in need of replacement.
  4. Jul 25, 2012 at 6:51 PM
    kayakred
    Cody Scott
    New Orleans
    04 TRD Off Road
    Thanks for the replies.
    @supra tt- yes it vibrates when taking off from a stop, then it smooths out.
    @mjp2- I'm not sure about drive shaft carrier bearings. I just got it on Tuesday so I'll look it that.
    @whippersnapper02- As far as I know my rear locker is unlocked, the button is "out" and light is off. I tried pushing the button and driving it, the light for my rear locker was flashing but the shudder was the same. Put it in 4 high and the same thing.
    Any other ideas? Thanks guys!
  5. Jul 25, 2012 at 7:02 PM
    90YotaPU
    90YotaPU The Messiah
    Union County, NJ
    1990 Toyota 4x4 (Pre-Taco)
    Aftermarket Stereo, Spidertrax Wheel Spacers, HF Air Horns, 3" Lift
    Try greasing up the zerks. Could just be dry. It should have a carrier bearing. Mine '99 did.
  6. Jul 26, 2012 at 11:43 AM
    kayakred
    Cody Scott
    New Orleans
    04 TRD Off Road
    Ok, at the risk of sounding like a noob, what's the official name for the "zerks"?
  7. Jul 26, 2012 at 11:56 AM
    4Wheelin4Banger
    4Wheelin4Banger Supercharged Toyman
    Randy
    Ferntucky, NV Halfway between Reno & Falabama
    2011 4x4 Access Cab Supercharged Silver State Edition 245WHP
    3" OME lift 885s & Dakars riding on 33" KM2s
    I think that is the official name :notsure:
    They are the nipples you attach the grease gun to when you lube parts.
    [​IMG][​IMG]
  8. Jul 26, 2012 at 12:03 PM
    stunt man hans
    stunt man hans DISPLACED VIKING LIVING IN WYOMING
    Hans
    LIVE FREE OR DIE
    2015 AEV RAM 3500
    FULL AEV PROSPECTOR KIT++
    where are these fittings under my 2nd gen regular cab? i want to keep everything lubed up lol
  9. Jul 26, 2012 at 6:46 PM
    kayakred
    Cody Scott
    New Orleans
    04 TRD Off Road
    Ah, I think I've always called them grease gun fittings, lol. So the zerks have been lubed.
    A buddy of mine called in a favor and got a shop to look at it today. They removed the DS and noticed it binding at the constant velocity joint, and that the rear portion needed to be replaced. So, they said that they could get me one for around $350 parts and labor.
    Also, something I noticed that they confirmed was that the hanger bracket had been replaced at some point. Dunno.
    But it's all lubed up now so I'll drive it around this weekend and see if that helps. If not I may take them up on the new one. Unless there's an aftermarket upgrade out there?
  10. Jul 26, 2012 at 7:39 PM
    kayakred
    Cody Scott
    New Orleans
    04 TRD Off Road
    Here's pic of the new hanger bracket:
  11. Jul 27, 2012 at 5:35 AM
    DevL
    DevL Well-Known Member
    That is a pic of your carrier bearing. You need a drop in it to get better angles on your drive shaft at ride height if you are lifted.
  12. Aug 2, 2012 at 10:39 AM
    kayakred
    Cody Scott
    New Orleans
    04 TRD Off Road
    Thanks DevL, sorry for the delay in response. So is this drop in my carrier barrier something I could do with longer bolts and spacers, or would I need to buy a new one with the drop built in.
    Also, I'm running a 2.5 in lift, is there a length of drop you could recommend or point me in the direction of that answer?
    Lastly, could the incorrect angles, caused by the lack of drop, be causing the "shudder" I'm feeling on take off?
  13. Aug 7, 2012 at 1:13 PM
    kayakred
    Cody Scott
    New Orleans
    04 TRD Off Road
    So I took the truck in to my local 4x4 shop. They looked it over to make sure the lift was installed correctly and check out my shudder.
    They found a couple things to tighten on the lift but other than that its all good.
    As for the shudder they threw in some spacers to drop my carrier bearing down about 1/2 an inch. This helped to reduce the length of time the DS shuddered but made it more intense.
    Dunno, I'll keep digging..
