Is this normal for a factory UCA ball joint?
Discussion in 'Suspension' started by Crom, Jul 24, 2012.
  1. Jul 24, 2012 at 4:23 PM
    Crom
    Crom [OP] Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    I was wondering if you think this is normal for the factory suspension? I was concerned about the light coat of grease/oil that appears to be emanating from the upper control arm ball joint / steering knuckle?
    There appears to be no serviceable (grease-able) parts here?
  2. Jul 24, 2012 at 4:35 PM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    your ball joint is fine.
    it looks like its coming from somewhere else. if you look closely where the oil/grease/whatever is starts at, it stops right before going behind the brake rotor.. just something i noticed.
  3. Jul 25, 2012 at 9:04 AM
    Crom
    Nick
    San Diego, CA
    Millions
    Thanks. I will look at again this weekend. Anyone else have any ideas?
  4. Jul 25, 2012 at 9:08 AM
    92LandCruiser
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    Degreaser and pressure washer, or brake clean. Clean all that shit off. See if it comes back and where it's coming from.
    By the looks of it I wouldn't be concerned but if you really want to know ^
    It probably is from the BJ but that's nothing to worry about.
  5. Jul 25, 2012 at 9:11 AM
    jandrews
    '09 FourDubDee TRD OR
    Meh, good excuse to upgrade to uniball arms.
    Or, if you just want it fixed, a press should make short work of it.
  6. Jul 25, 2012 at 9:25 AM
    Crom
    Nick
    San Diego, CA
    Millions
    I will clean it up and recheck. It must be coming from the ball joint... Perhaps that rubber boot has a leak. Factory suspension is not covered by powertrain warranty so I'll keep an eye on it. I do plan to upgrade to OME suspension but not for two more years.
    Thanks for taking a look.
  7. Jul 25, 2012 at 9:33 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Good advice about cleaning and seeing where the oil starts to come back from.
    Hate it when BJs get messy... :rolleyes:
  8. Jul 25, 2012 at 5:59 PM
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    lol
    Even if it is a leaking BJ, doesn't mean it's bad, going bad, or that it will soon. Just keep an eye on it.
