Suspension experts needed :)
Discussion in 'Suspension' started by omac5, Jul 25, 2012.
  1. Jul 25, 2012 at 1:31 AM
    omac5
    omac5 [OP] Well-Known Member
    Marqus
    South Texas (MISSION)
    2011 4x4 SR5 Magnetic Gray
    SUSPENSION: icon front & rear icon UCA Toytec 2" AAL
    My current set up:
    I bought my icons about 3 months ago and unfortunately to get the ride height that i want, i had to crank up the coilovers, as u can see in d picture, resulting to somewhat of a stiffer ride. What are my options to be at my current ride height or higher (max 3 inch of lift) but putting my coilovers back to zero or just at 1 inch? I was doing research here and im really liking how d spindle lift looks but i unfortunately i have a 4x4 truck and it said spindles dont work with 4x4? Did i understand that right? Ultimately, i also want to add the Allpro 3in leaf pack for the rear, so any advice would be greatly appreciated! Thanks again
  2. Jul 25, 2012 at 2:05 AM
    Hiatt1991
    Hiatt1991 Well-Known Member
    Hiatt
    Ventura, CA
    2022 Toyota Tacoma SR5 DCSB 4x4
    4" Bodylift 20" Offroad shock spacers Turbo Encabulator
    Get a higher spring rate coil. You can lift with less preload.
  3. Jul 25, 2012 at 2:06 AM
    Casey05Taco
    Casey05Taco Well-Known Member
    Casey
    Penngrove, CA
    05 Tacoma Prerunner
    trd seat covers, bed mat, tinted windows, debadged, mud flaps removed, tinted tails, blacked out center console, Black Rims, 6000k HID in highs and fogs, blacked out front emblem, Pioneer AVH-4300DVD, Gauge Cluster, lower valence, retrofitted, audio system, Maxtrac Spindles, Billies
    Your correct about the spindles, they are for 4X2.
  4. Jul 25, 2012 at 2:13 AM
    omac5
    Marqus
    How do i go about doing that? U mean I change out my current coils to the higher spring rate coil. Can any shop swap d coils or i have to send it to icons. Thanks again
  5. Jul 25, 2012 at 5:04 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Call Downsouth Motorsports (or a local shop if you have a GOOD local off road shop). You can either get a higher rated coil or a taller coil (or both). That way you can get the lift you want without the preload. If you want a softer ride, I'd go for a taller coil at the same spring rate.
  6. Jul 25, 2012 at 11:07 AM
    omac5
    Marqus
    Thanks Man :) il give DSM a call then
  7. Jul 25, 2012 at 3:30 PM
    maxpower29
    maxpower29 Well-Known Member
    Jordan
    Nova Scotia, Canada
    2011 Tacoma 4x4 2.7 5 speed SWB
    All season mats, 2nd filter delete, DT header, Jardine cat-back, URD shifter, Bilstein 5100's all around at .85 front with Eibachs + .25 passenger/.5 drivers spacers and 1.5 AAL, 0w20 synthetic, Scanguage II, extra D rings, OEM backup camera+Mirror, bed mat, Extang Solid Fold, Popnlock 5300, Pro Comp 7089's 4.5bs 285/70/17 Revo 2s, De-badged
    What rims are you using in that pic? Like them
  8. Jul 25, 2012 at 4:24 PM
    omac5
    Marqus
    Thanks man, they are mickey thompson sidebiter 17x9
  9. Jul 25, 2012 at 5:25 PM
    maxpower29
    Jordan
    Nova Scotia, Canada
    nice, im guessing the tires are 285/70/17s too?
  10. Jul 25, 2012 at 5:31 PM
    Pugga
    Massachusetts
  11. Jul 25, 2012 at 8:18 PM
    Sublime
    Sublime Well-Known Member
    Phoenix, AZ
    08 TRD 4x4
    You'll have the same issue with any coilovers cranked too high......its for performance and minimal lift unfortunately. I lowered my icons to 2.5" and have AP's in the back....there's some rake but it looks good! Try lowering them 1/2" and see how they ride!
  12. Jul 25, 2012 at 8:34 PM
    omac5
    Marqus
    Thanks man and yah dats wat DSM said as well, either lower it or change it to a longer coil which is about $190 plus d install cost and might not even dat much of a difference to what i have now ride wise. U said u hav d allpro leafs in d back, do u have the 3inch? Thanks again
  13. Jul 25, 2012 at 8:41 PM
    omac5
    Marqus
    Sublime, u have more picks of ur truck with icons? I want to see difference with mine :) thanks
  14. Jul 25, 2012 at 8:52 PM
    Sublime
    Phoenix, AZ
    08 TRD 4x4
    I'll take pics in the am......how much thread do you have showing between the top and the collar? Are they ext travel?
  15. Jul 25, 2012 at 8:54 PM
    omac5
    Marqus
    Oh dont worry about it man, no rush. I have the pic on top of dis page. Is dat how urs look like?
  16. Jul 25, 2012 at 9:13 PM
    Sublime
    Phoenix, AZ
    08 TRD 4x4
    Lol....ya! I'm 38" up front from ground to fender with 285 km2's!
  17. Jul 25, 2012 at 9:24 PM
    omac5
    Marqus
    Yah mine are extended travel. I have 7" from top of tire to my fender i havnt measured from d ground to my fender. U dont hav a build thread so i can see ur truck stance?
  18. Jul 25, 2012 at 9:45 PM
    omac5
    Marqus
    Yup stock leafpack with the toytec 2" AAL
  19. Jul 26, 2012 at 8:13 PM
    Sublime
    Phoenix, AZ
    08 TRD 4x4
    Here you go man.....I'm on a slight incline so it's a little more raked than normal. I think 2.5" up front rides better, the rake is closer to factory and still looks good!
  20. Jul 26, 2012 at 8:22 PM
    omac5
    Marqus
    Thanks man, i think im jst gonna end lowering it a bit. One more question, do u have the 3" allpro leaf pack in d back or d 1.5"? Thanks again
