885X Coils from ToyTec
Discussion in 'Suspension' started by SNJTacoma11, Jul 27, 2012.
  1. Jul 27, 2012 at 9:21 AM
    SNJTacoma11
    SNJTacoma11 [OP] Well-Known Member
    Runnemede New Jersey
    2011 Tacoma Double Cab 4x4 Super White
    Rough Country 6" Lift 17" M/T Revolvers 35" Nitto Mud Terrain Cold Air Kit
    Hello,
    Thinking of buying 885X coils and using them in place of my stock SR5 coils with my bilstein 5100 shocks for my lift. setting them ofcourse to "0".
    My question is should i need the spacers (1/4") that you can add to make my truck sit level?
    It already has the Tacoma TSB rear leafs and Toytec's TSB add a leaf.
  2. Jul 28, 2012 at 10:07 AM
    Supra TT
    Supra TT Supercharged Lifter
    Eric
    Indiana
    2000 SAS D60 F/R Supercharged
    Supercharged on One Tons
    Most likely, the taco lean is absurd.
  3. Jul 28, 2012 at 10:09 AM
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
    885x coils , no top plate spacer got me 2 1/2" of front lift on my DCLB 4x4
  4. Jul 28, 2012 at 10:12 AM
    OZ-T
    Peter North
    British Columbia
    Measure the front and measure the rear , add 2 1/2" to the front , that's where you will end up , go from there
  5. Jul 28, 2012 at 10:15 AM
    OZ-T
    Peter North
    British Columbia
    Wait a minute , do you have the billies set for lift now with your stock coils ?
  6. Jul 29, 2012 at 11:29 AM
    SNJTacoma11
    Yes I do..... I'm going to lower the bilsteins to "0" and then use the 885x coils. I have the tacoma TSB in the rear and toytec 1.5" AAL as well. Should sit level then. As of now it doesnt. I think stock coils are going bad. Going to get rid of my 18" rims and nitto's and look for something in black....
  7. Jul 29, 2012 at 1:24 PM
    OZ-T
    Peter North
    British Columbia
    What are your billies set at now with the stock coils ? What is the hub to fender mearsurement up front now ?
  8. Jul 30, 2012 at 7:31 AM
    Bama_TACO
    Bama_TACO ROLL TIDE!!!!!!!
    Winfield, AL
    2006 PreRunner Double Cab TRD SPORT
    I have 885x and I have the 1/4" spacer on the driver's side along with 1/2" top plate spacers on both sides. Mine sits dead level now (side to side) and measures 24 3/4" from hub to fender. Rear is sitting at 26" if anyone is wondering.
  9. Jul 30, 2012 at 7:33 AM
    sfcadams
    sfcadams Retired Senior NCO
    Dan
    Elizabeth, Indiana
    2011 TRD Off Road DCSB Prerunner Skeewped
    Bama TACO,
    With your measurements at 24 3/4, isn't that close to 5 inches of lift over stock??
  10. Jul 30, 2012 at 7:53 AM
    Bama_TACO
    Winfield, AL
    I'm not sure. It had a spacer lift when I bought it so I'm not sure what it measured stock. I'm pretty sure I'm close to 4" if not a little over. In addition, I have measured several times because I keep questioning my own measurements. I'm measuring from the center of the hub to the edge of the fender, straight up.
  11. Jul 30, 2012 at 8:00 AM
    sfcadams
    Dan
    Elizabeth, Indiana
    Yea, sounds like you are measuring it right. I don't 100% remember what mine measured at stock (I want to say it was 20" from center of hub to fender). If that holds true, then that would put you at over 4" of lift. Are you running 5100s set on anything other than 0 by chance?
  12. Jul 30, 2012 at 8:02 AM
    OZ-T
    Peter North
    British Columbia
    At least 4 1/4"
  13. Jul 30, 2012 at 8:20 AM
    Bama_TACO
    Winfield, AL
    No, 5100s are on the Zero setting.
  14. Jul 31, 2012 at 6:15 AM
    sfcadams
    Dan
    Elizabeth, Indiana
    I give then....
  15. Sep 5, 2012 at 4:17 PM
    Brianstemm
    Brianstemm GM Convert
    Bryan
    Key Largo
    '17 White TRD Offroad
    Zero
    Kinda strange man... is your spring plate up side down? The plate that sits on the adjustable clip and under the coil. Just checking cause that would be bad, other than that I'm jealous. Hows it ride? I have eibachs set at .85 and my truck rides like sh!t..need a good balance maybe.
  16. Sep 5, 2012 at 4:22 PM
    OZ-T
    Peter North
    British Columbia
    Bama Taco has 885's , plus 1/2" spacers , plus another 1/4" spacer driver's side , plus it's a Prerunner
  17. Sep 5, 2012 at 4:29 PM
    sfcadams
    Dan
    Elizabeth, Indiana
    Mine is a prerunner too and I am running Maxtrac spindles with factory TRD shocks/coils up front and it sounds like he is sitting higher than I am. So those 885s provide almost 3 1/2 inch of lift then?
  18. Sep 5, 2012 at 4:46 PM
    OZ-T
    Peter North
    British Columbia
    885's can get a Prerunner up to 3" , plus 3/4" for his 1/2" spacers , plus another 1/2" for the 1/4" spacer
  19. Sep 5, 2012 at 6:26 PM
    Brianstemm
    Bryan
    Key Largo
    Zero
    Well the 1/4 spacer is just to get him up to par with the passenger side. I wouldn't add that to the lift dimensions....he's getting over 4" of lift with a set up that can yield at best 3.75". I still think the spring perch may be suspect. Worth a look, anyway.
  20. Sep 5, 2012 at 6:29 PM
    OZ-T
    Peter North
    British Columbia
    Worth a look agreed
