3" Lift Ride Quality
Old 08-10-2012, 07:16 AM   #1
JRod4928 [OP] JRod4928 is offline
JRod4928 is one of the sharper tools in the shedJRod4928 is one of the sharper tools in the shedJRod4928 is one of the sharper tools in the shedJRod4928 is one of the sharper tools in the shedJRod4928 is one of the sharper tools in the shedJRod4928 is one of the sharper tools in the shedJRod4928 is one of the sharper tools in the shedJRod4928 is one of the sharper tools in the shedJRod4928 is one of the sharper tools in the shedJRod4928 is one of the sharper tools in the shedJRod4928 is one of the sharper tools in the shed
JRod4928's Avatar
JRod4928's Tacoma Gallery
How good of a ride do you get with a 3" Pro Comp lift? I'm looking to spend no more than $500 on a suspension lift I can install myself.
I'd go with a body lift but I heard the ride quality is pretty poor.
I don't do much off-roading, mostly highway/city driving.
Suggestions?
Go
Old 08-10-2012, 07:37 AM   #2
sirsaechao is one of the sharper tools in the shedsirsaechao is one of the sharper tools in the shedsirsaechao is one of the sharper tools in the shedsirsaechao is one of the sharper tools in the shedsirsaechao is one of the sharper tools in the shedsirsaechao is one of the sharper tools in the shedsirsaechao is one of the sharper tools in the shedsirsaechao is one of the sharper tools in the shedsirsaechao is one of the sharper tools in the shedsirsaechao is one of the sharper tools in the shedsirsaechao is one of the sharper tools in the shed
sirsaechao's Avatar
sirsaechao's Tacoma Gallery
Meh I wouldn't go Pro Comp. I would do 5100's at 2.5" and AAL. I am sure at 3" you will need new UCA's if you can't get your alignment back to spec. What size tires are you planning on running?
Old 08-10-2012, 07:42 AM   #3
Namyo is one of the sharper tools in the shedNamyo is one of the sharper tools in the shedNamyo is one of the sharper tools in the shedNamyo is one of the sharper tools in the shedNamyo is one of the sharper tools in the shedNamyo is one of the sharper tools in the shedNamyo is one of the sharper tools in the shedNamyo is one of the sharper tools in the shedNamyo is one of the sharper tools in the shedNamyo is one of the sharper tools in the shedNamyo is one of the sharper tools in the shed
Namyo's Avatar
Namyo's Tacoma Gallery
x2
http://www.wheelersoffroad.com/05uptacoadjbils.htm
http://www.wheelersoffroad.com/05uptacoaal.htm
Old 08-10-2012, 07:49 AM   #4
JRod4928's Avatar
I'd like to run 265/70/17 or 265/75/17. no wider for gas mileage purposes.
Old 08-10-2012, 07:52 AM   #5
Namyo's Avatar
Old 08-10-2012, 08:02 AM   #6
sirsaechao's Avatar
I'd go with Bilstein 5100 front adjustable set at 2.5", longer AAL like Wheeler's or ToyTec and 5125's rear shocks.
Old 08-10-2012, 08:22 AM   #7
JRod4928's Avatar
What's the reason for your choices? I'm just starting to research this so I'm trying to learn as much as I can.
(star trek reference was sweet BTW)
Old 08-10-2012, 08:31 AM   #8
rab89 is one of the sharper tools in the shedrab89 is one of the sharper tools in the shedrab89 is one of the sharper tools in the shedrab89 is one of the sharper tools in the shedrab89 is one of the sharper tools in the shedrab89 is one of the sharper tools in the shedrab89 is one of the sharper tools in the shedrab89 is one of the sharper tools in the shedrab89 is one of the sharper tools in the shedrab89 is one of the sharper tools in the shedrab89 is one of the sharper tools in the shed
rab89's Avatar
rab89's Tacoma Gallery
I have a 3'' ready lift above coil spacer and a 1'' block. rides the same as stock. or get a 2'' block if you like some rake. I bought mine on the forum for under $100. or new they are around $250 I believe.
Old 08-10-2012, 08:32 AM   #9
sirsaechao's Avatar
You asked for ride quality. Bilstein are valved mono tube shocks, longer AAL rides better then the short Pro Comps or better then blocks. 2.5" vs 3" cause at 3" you will need to invest another $450 in new UCA's plus the size tires you are running. They already clear stock height so .5" difference isn't going to be major.
Old 08-10-2012, 08:35 AM   #10
BETTER BEAVIS
TeamSarcasm is one of the sharper tools in the shedTeamSarcasm is one of the sharper tools in the shedTeamSarcasm is one of the sharper tools in the shedTeamSarcasm is one of the sharper tools in the shedTeamSarcasm is one of the sharper tools in the shedTeamSarcasm is one of the sharper tools in the shedTeamSarcasm is one of the sharper tools in the shedTeamSarcasm is one of the sharper tools in the shedTeamSarcasm is one of the sharper tools in the shedTeamSarcasm is one of the sharper tools in the shedTeamSarcasm is one of the sharper tools in the shed
TeamSarcasm's Avatar
TeamSarcasm's Tacoma Gallery
People just don't like procomp because they heard its a rough ride until it breaks in. Usually they have no actual experience with it haha.
But the 5100/5125 shocks and the aal are recommended because they give a good ride. But you won't get 3inches out of them.
If you want a full 3inch lift go with procomp I say. I have no experience with it, but I've read from people who actually have it the ride is not all that bad.
Old 08-10-2012, 09:49 AM   #11
JRod4928's Avatar
2.5" vs 3" is virtually nothing. I can make that up in tire size if I was concerned over 1/2" (not very).
if i get significantly better ride quality out of a 2.5" lift, i'd just go with that. Is there a kit that I can buy or do I need to piece it together?
Also, are there any maintenance issues with putting on a suspension lift vs. body lift (such as wearing stuff out faster because of the different geometry - like ball joints, axles, drive shaft, etc. ). Ideally I'd like to get a lift that has good ride quality and that won't stress and wear out/break other parts of the truck faster over time.
Old 08-10-2012, 09:54 AM   #12
BETTER BEAVIS
I think you have to piece it together. Some places may sell the shocks together. Shop around for a good price or maybe start a group buy since people are always wanting to buy this set up.
Old 08-10-2012, 09:55 AM   #13
Namyo's Avatar
See the links I dropped below, and shouldn't have problems under 3"
Old 08-10-2012, 09:57 AM   #14
newertoy is one of the sharper tools in the shednewertoy is one of the sharper tools in the shednewertoy is one of the sharper tools in the shednewertoy is one of the sharper tools in the shednewertoy is one of the sharper tools in the shednewertoy is one of the sharper tools in the shednewertoy is one of the sharper tools in the shednewertoy is one of the sharper tools in the shednewertoy is one of the sharper tools in the shednewertoy is one of the sharper tools in the shednewertoy is one of the sharper tools in the shed
newertoy's Avatar
Coast Guard: electronics tech
newertoy's Tacoma Gallery
I am very pleased w/my 1st gen bils and aal--Call TOYTEC--Good guys--or do it online--they have a member HERE at TW.
There is also a DISCOUNT CODE for toy tec-5% i think--do a search
Old 08-10-2012, 09:58 AM   #15
JRod4928's Avatar
Did you post the link in 0.02 font, or did you just forget?
Old 08-10-2012, 11:00 AM   #16
JRod4928's Avatar
so I was looking at this: http://www.toyteclifts.com/index.php...mart&Itemid=72
with diff. drop.
I'd run it at 2.5" so i dont have to get UCA's. are 5160 shocks worth the money? (see the option at the bottom of the link)
Old 08-10-2012, 11:00 AM   #17
JRod4928's Avatar
pumped about the lift though, can't wait - thanks for the info!
Old 08-15-2012, 08:26 AM   #18
rab89's Avatar
thats a good lift. but don't get the diff drop spacer. search the forum for more info on that
Thinking of Lift (Eibach's w/ 5100's at 0.85", ToyTec AAL) - RIDE QUALITY???? gilliamjc Suspension 32 03-12-2012 09:09 PM
Lift kit ride quality help?? FriscoTacoma Suspension 12 04-22-2011 10:17 AM
3" and 6" lift ride quality poll hookedontronics 2nd Gen. Tacomas 23 07-25-2010 06:42 PM
Ride Quality with your lift jpsweet Suspension 46 04-04-2010 04:31 PM
How much will the lift affect ride quality? Oh_Six_Taco_4x4 Suspension 15 08-11-2008 07:05 PM
