ICON 3 Leaf Progressive AAL ordered...
Old 09-12-2012, 10:13 AM   #1
Pegeezy [OP] Pegeezy is offline
Pegeezy is on a distinguished road
Air Force: 136th AW
Pegeezy's Tacoma Gallery
Ordered the ICON 3 Leaf Progressive AAL yesterday from DSM. Should be here this Friday or on Monday. I'll get it installed ASAP. Currently I am running 5100s at 1.75 in the front with stock coils. I am hoping my rig will be sitting level post-install...you can see for yourself the bro lean I got going right now...
If all goes well, next up will be some some 265s...although I may ride these factorys out until they are bald. No use in spending the money on a new set of tires if you dont NEED them....comments/thoughts are appreciated.
Old 09-12-2012, 10:36 AM   #2
Wizard Sleeve Master
Amo-cat3 is one of the sharper tools in the shedAmo-cat3 is one of the sharper tools in the shedAmo-cat3 is one of the sharper tools in the shedAmo-cat3 is one of the sharper tools in the shedAmo-cat3 is one of the sharper tools in the shedAmo-cat3 is one of the sharper tools in the shedAmo-cat3 is one of the sharper tools in the shedAmo-cat3 is one of the sharper tools in the shedAmo-cat3 is one of the sharper tools in the shedAmo-cat3 is one of the sharper tools in the shedAmo-cat3 is one of the sharper tools in the shed
Amo-cat3's Tacoma Gallery
I've been reading up on these too. I've been running the single Alcan AAL for the last few years and the ride is pretty stiff and kicks out when hitting bumps in the road on turns. I ended up ordering the Wheelers version of the 3 pack which is pretty much identical to Icons. In fact just put the order in about 5 minutes ago
I'm going to keep my overload leaf in because I do haul some heavy loads here and there, but overall just looking for a little more stable/softer ride for daily driving.
Old 09-12-2012, 10:37 AM   #3
Pasti-Dip Free Since 1983
Pugga's Avatar
Pugga's Tacoma Gallery
That looks like you gained a lot more than 1.75" up front. Could just be the angle of the picture or the camera but that really jacked the nose up quite a bit. Are you sure you used the 1.75 setting and not the 2.5 (or that the coil seat is right-side-up?
You're going to love the Icon AAL. I've had mine in for over a year and it's holding up great and still rides like it did on day 1.
Old 09-12-2012, 10:39 AM   #4
chris4x4's Avatar
chris4x4's Tacoma Gallery
Originally Posted by Amo-cat3 View Post
....and kicks out when hitting bumps in the road on turns.
That could be due to the shocks, rather the springs. What rear shocks are you running?
Old 09-12-2012, 11:13 AM   #6
Air Force: 136th AW
Yea bro I made sure if was at 1.75 prior to install..It's probably the angle of the photo although I did get some significant lift in the front...thanks for posting both pics like that.
Old 09-12-2012, 11:20 AM   #7
:POOPCORN:
98tacoma27's Avatar
Marines:
98tacoma27's Tacoma Gallery
Just did the same thing only the Tundy versions. I put them on this past Sunday. Mine was also kicking out too. It did stop that. I also noticed my upper shock mounts were loose on both sides (Billie 5100's). I'm debating on replacing them with 5150's.
Sorry for the thread jack OP. NICE TRUCK!!!!
Old 09-12-2012, 11:20 AM   #8
Pugga's Avatar
Cool, just making sure. It certainly wouldn't be the first time it happened on TW! Are you leaving the overload in place with the AAL or no?
Old 09-12-2012, 11:26 AM   #9
chris4x4's Avatar
Just the stock shocks in rear. I have Icons up front (rebuilt Leepers), any suggestions to match up the rear with my front coilovers. Good ol' Bilsteins?
Icon makes a nice rear shock too.
Old 09-12-2012, 01:49 PM   #11
A-TRAC Equipped
speedydave is one of the sharper tools in the shedspeedydave is one of the sharper tools in the shedspeedydave is one of the sharper tools in the shedspeedydave is one of the sharper tools in the shedspeedydave is one of the sharper tools in the shedspeedydave is one of the sharper tools in the shedspeedydave is one of the sharper tools in the shedspeedydave is one of the sharper tools in the shedspeedydave is one of the sharper tools in the shedspeedydave is one of the sharper tools in the shedspeedydave is one of the sharper tools in the shed
speedydave's Tacoma Gallery
I have the Icon's along with the 5100's at 1.75. Check my gallery for pics. I like the leaf pack.
Old 09-12-2012, 02:58 PM   #12
Air Force: 136th AW
Cool
Well I was going to to but the dude I talked to at DSM this morning (Sonny I think) said that he wouldn't recommend running it like that even though a lot of people on here do...I wouldn't mind the extra lift but ride quality means more to me than anything...plus I don't wanna have any rake.
Icon/Wheelers 3 Leaf Progressive AAL Hdeuce22 Suspension 5 07-05-2012 12:45 PM
Need clarification: icon progressive aal Joehs Suspension 3 03-18-2011 08:43 PM
Icon 3 leaf progressive AAL badguybuster Suspension 5 06-14-2009 05:58 AM
