5100 questions...
Old 09-26-2012, 08:12 PM   #1
05RedTaco [OP] 05RedTaco is offline
Nom Nom Nom
05RedTaco is one of the sharper tools in the shed05RedTaco is one of the sharper tools in the shed05RedTaco is one of the sharper tools in the shed05RedTaco is one of the sharper tools in the shed05RedTaco is one of the sharper tools in the shed05RedTaco is one of the sharper tools in the shed05RedTaco is one of the sharper tools in the shed05RedTaco is one of the sharper tools in the shed05RedTaco is one of the sharper tools in the shed05RedTaco is one of the sharper tools in the shed05RedTaco is one of the sharper tools in the shed
05RedTaco's Avatar
05RedTaco's Tacoma Gallery
5100 questions...
I got a front and rear set of Bilstein 5100's. Right now I have stock TRD Off Road shocks with 3" spacer up front and 2" AAL in the rear.
I am planning to install the 5100's in the front set at 2.5 with stock coil. What are disadvantages of that setup as opposed to run the 5100's with OME 885's?
Also will the 5100's set at 2.5 with OEM coils make my truck lower than it is now with the spacers?
Old 09-26-2012, 08:16 PM   #2
Chewie is my Co-pilot
YumaTRD is one of the sharper tools in the shedYumaTRD is one of the sharper tools in the shedYumaTRD is one of the sharper tools in the shedYumaTRD is one of the sharper tools in the shedYumaTRD is one of the sharper tools in the shedYumaTRD is one of the sharper tools in the shedYumaTRD is one of the sharper tools in the shedYumaTRD is one of the sharper tools in the shedYumaTRD is one of the sharper tools in the shedYumaTRD is one of the sharper tools in the shedYumaTRD is one of the sharper tools in the shed
YumaTRD's Avatar
YumaTRD's Tacoma Gallery
The advantage is that you may not need UCA's at 2.5 inches rather than a 3" lift.
Your truck should be lower. I first had a 3" spacer lift for 20k miles and it messed up my stock UCA's. I then went to the Billies and my alignment was better and no wear on the UCAs
Old 09-26-2012, 09:05 PM   #3
Nom Nom Nom
05RedTaco's Avatar
Thats good news, because even after I got my truck aligned my front tires are still slightly \ / ...
So in order to do 3" lift the right way I would need the 5100's with OME 885's and aftermarket UCA's correct?
Old 09-26-2012, 09:14 PM   #4
YumaTRD's Avatar
Correct
Old 09-26-2012, 09:14 PM   #5
TRUCK YEAH
Saskquatch11 is one of the sharper tools in the shedSaskquatch11 is one of the sharper tools in the shedSaskquatch11 is one of the sharper tools in the shedSaskquatch11 is one of the sharper tools in the shedSaskquatch11 is one of the sharper tools in the shedSaskquatch11 is one of the sharper tools in the shedSaskquatch11 is one of the sharper tools in the shedSaskquatch11 is one of the sharper tools in the shedSaskquatch11 is one of the sharper tools in the shedSaskquatch11 is one of the sharper tools in the shedSaskquatch11 is one of the sharper tools in the shed
Saskquatch11's Tacoma Gallery
I got 2.75" of lift with 5100s @ 2.5" (stock coils).
upgraded to 885x coils and LR UCAs (5100s @ 0"), which put me 1/8" higher compared to 5100s @ 2.5".
5100'S questions takamineman 1st Gen. Tacomas 21 01-21-2012 09:05 AM
more 5100 questions 928puddles 1st Gen. Tacomas 4 06-02-2011 12:08 AM
5100 questions? krisjw101 Suspension 5 01-24-2011 05:51 AM
5100 questions garrettski 2nd Gen. Tacomas 7 03-24-2009 08:55 PM
5100 questions.... garrettski 2nd Gen. Tacomas 21 02-03-2009 03:20 PM
