2012 levelling questions.
Old 09-27-2012, 07:01 PM   #1
jermoids [OP] jermoids is offline
jermoids is a splendid one to beholdjermoids is a splendid one to beholdjermoids is a splendid one to beholdjermoids is a splendid one to beholdjermoids is a splendid one to beholdjermoids is a splendid one to beholdjermoids is a splendid one to behold
jermoids's Avatar
Royal Canadian Air Force: aerospace control operator
jermoids's Tacoma Gallery
hey everyone, im new on here, lots of good info! i have searched through a ton of threads about levelling and lifts but it's hard to find certain answers when you're scanning through pages and pages.
all i want to do is level the front of my 2012 tacoma.
How much does it need to be raised to make it level?
i have read all the good and bad, mostly bad by the looks of it, with the levelling kits and also a lot about the bilstein 5100s.
what would be better for my truck in the long run, the bilsteins up front with the stock springs or a spacer?
also, with the bilsteins, will they raise the front a bit without adjusting them? or do they have to be raised up to .85/1.75 etc?
im a little worried about having issues that will affect my warranty if i do too much of a lift.
im only putting 265/70/17 duratracs on so i don't need much of a lift.
plus i don't plan on doing any 4x4ing other then getting around in the winter.
any help or advice would be great, and i know there are a ton of threads about this but like i said, it's hard to find certain answers when you are looking through some many posts.
and im not a mechanic, so sorry if i sound like i don't have a clue.
thanks,
jeremy
Old 09-27-2012, 07:06 PM   #2
4banger09 has a brilliant future4banger09 has a brilliant future4banger09 has a brilliant future4banger09 has a brilliant future4banger09 has a brilliant future4banger09 has a brilliant future4banger09 has a brilliant future4banger09 has a brilliant future4banger09 has a brilliant future4banger09 has a brilliant future4banger09 has a brilliant future
4banger09's Avatar
4banger09's Tacoma Gallery
Depending on your cab 5100s set at 1.75 should level it
Old 09-27-2012, 07:11 PM   #3
jermoids's Avatar
thanks for the quick reply,
it's a double cab.
will i be ok with everything stock at that setting? and im assuming you are saying that is the better option?
Old 09-27-2012, 07:23 PM   #4
4banger09's Avatar
Better then spacers yes, ya that may still leave you a bit of rake but the 2.5 setting will be too high for sure
Old 09-27-2012, 07:26 PM   #5
Jareds Toyota is one of the sharper tools in the shedJareds Toyota is one of the sharper tools in the shedJareds Toyota is one of the sharper tools in the shedJareds Toyota is one of the sharper tools in the shedJareds Toyota is one of the sharper tools in the shedJareds Toyota is one of the sharper tools in the shedJareds Toyota is one of the sharper tools in the shedJareds Toyota is one of the sharper tools in the shedJareds Toyota is one of the sharper tools in the shedJareds Toyota is one of the sharper tools in the shedJareds Toyota is one of the sharper tools in the shed
Jareds Toyota's Tacoma Gallery
i would set to 1.75 but think you should get a rear tsb. I have 265/70/17 duratracs with no lift and it fits fine.
Old 09-27-2012, 07:33 PM   #6
jermoids's Avatar
thanks guys!
tsb? quick search shows it to be something with the leaf springs.
can you explain what exactly that is, why i would need them and what could happen if i don't?
thanks.
Old 09-27-2012, 07:37 PM   #7
jermoids's Avatar
hey jared, you wouldn't happen to have a pic of your truck with those tires would you?
Old 09-27-2012, 08:44 PM   #8
4banger09's Avatar
Originally Posted by jermoids View Post
thanks guys!
thanks.
You have a 2012 so you may have the "tsb" springs already. All they are is a 4 leaf pack rather then a 3, for the 2005+ trucks people would find a harsh ride or bottoming out with the leaf springs so Toyota put out a tsb (Toyota service bulletin) for them to fix the problem with "tsb" springs. You should have the 4 leaf pack.
People with the 3 leaf pack usually get them because they add a little extra height due to an extra leaf.
Old 09-27-2012, 08:57 PM   #9
jermoids's Avatar
thank you,
just checked and you are correct, i have the 4 leaf pack.
after some more searching around, it looks like a pretty good setup to do the 5100s all around with the fronts set to 1.75
Old 09-27-2012, 09:12 PM   #10
4banger09's Avatar
Ya it's a popular choice
Old 09-28-2012, 10:08 PM   #11
Unhappy
Oh shoot. Sorry my bad
Old 09-28-2012, 10:11 PM   #12
Here she is.. Procomp 7005s and duratracs
Old 09-29-2012, 05:42 AM   #13
Primo 95 is one of the sharper tools in the shedPrimo 95 is one of the sharper tools in the shedPrimo 95 is one of the sharper tools in the shedPrimo 95 is one of the sharper tools in the shedPrimo 95 is one of the sharper tools in the shedPrimo 95 is one of the sharper tools in the shedPrimo 95 is one of the sharper tools in the shedPrimo 95 is one of the sharper tools in the shedPrimo 95 is one of the sharper tools in the shedPrimo 95 is one of the sharper tools in the shedPrimo 95 is one of the sharper tools in the shed
Primo 95's Avatar
Primo 95's Tacoma Gallery
Most likely the front needs to be raised 1.75". Measure your center hub to fender on both the front and back. The distance in the rear should be about 2" more. So raising the front 1.75" will make it perfectly level. 2.5" will be too much and look stupid.
I my opinion, just 5100s with the fronts raised 1.75"
They must be set to raise, if you leave then at 0, they will not raise the front
Will not impact your warranty. Just have it aligned after you put your 5100s.
See my write up on the same topic on my truck
http://www.tacomaworld.com/forum/sus...ml#post5711649
Old 09-29-2012, 06:39 AM   #14
jermoids's Avatar
thanks jared, looks good!
Old 09-29-2012, 06:43 AM   #15
jermoids's Avatar
thanks! your truck looks great. all you have done is the 5100s on stock springs with the fronts set at 1.75?
that's my plan, with duratrac 265/70/17 tires and mayhem riot 8010's 17x8 matte black.
Old 09-29-2012, 07:24 AM   #17
jermoids's Avatar
Originally Posted by 757 Taco View Post
check out my build. running billys in the front @ 1.75". sits level, looks great, rides very close to stock. also im running 265/75/16 Duratracs on Procomp 7089's
looks awesome, the exact look im going for, thanks!
Old 10-02-2012, 03:24 PM   #18
jermoids's Avatar
has anyone experienced any issues with re-alignment having the 5100's set and 1.75?
Old 10-02-2012, 06:27 PM   #20
jermoids's Avatar
i told the guy at the shop i had my setup mounted and balanced to give it an alignment and when i came back he told me that he honestly didnt think it needed one. my tires are wearing nice and even and it rides very straight so i guess he was right.
cool, thanks.
levelling lit installation time? XREILLYX 2nd Gen. Tacomas 9 09-22-2012 12:00 PM
2012 Gear Ratio questions/buying questions and a lot of blabbing. Vantage 2nd Gen. Tacomas 8 07-18-2012 11:05 PM
Levelling the rear RyanK1 Suspension 9 02-06-2012 05:29 PM
Levelling kits? jillryan Suspension 10 06-30-2011 09:43 AM
levelling a Toytec ULK Thesilversurfer Suspension 16 06-29-2011 01:41 PM
