Mid-Travel vs OME
Discussion in 'Suspension' started by Blygy, Oct 14, 2012.
  1. Oct 14, 2012 at 6:57 PM
    Blygy
    Blygy [OP] Well-Known Member
    East of Edson
    Supercharged 2012 DCLB TRD Sport Trail Teams
    Trail Teams Edition Supercharger
    OK.. First of all I have tried searching and have done a bunch of reading but I couldn't find the answer I am seeking.
    I am looking for a definition of Mid-Travel suspension. Is there more compression travel or droop travel??
    How do they compare to an OME setup?? I understand OME isn't Mid-Travel but if the price difference isn't much more I might just get the Mid-Travel.
    Thanks in advance for all that help.
    Blygy
  2. Oct 15, 2012 at 5:59 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Mid-travel would be like the extended travel Icon shocks.
    OME and a Bilstein 5100 lift would be a stock travel lift since the travel range is unchanged from stock. You gain lift by sacrificing downtravel and gaining uptravel. Mid-travel would allow you to gain lift, gain uptravel and still have decent down travel as well. At least that's how I understand it...
  3. Oct 15, 2012 at 10:45 AM
    TexasTacoma37
    You should also pair extended travel shocks with a uniball uca to be true mid-travel. With only the extended travel shocks, your stock uca's will be the limiting factor on suspension down-travel.
  4. Oct 15, 2012 at 11:03 AM
    Blygy
    East of Edson
    So the UniBall UCA is what allows more droop??
    Getting 3 inches of lift while loosing 3 inches of down travel seems silly. How much down travel do I get back with a mid travel set up??
  5. Oct 15, 2012 at 11:13 AM
    TexasTacoma37
  6. Oct 15, 2012 at 11:30 AM
    Sublime
    Sublime Well-Known Member
    Phoenix, AZ
    08 TRD 4x4
    Yup, you've got it......to get 3" of lift you loose down travel and a speed bump will over extend the suspension causing a crappy ride......2-2.5" is ideal for this reason or ext travel shocks and uca gaining 1" of down travel back. Manufacturer's suggest at least 2" of downtravel for a decent ride.
    If you're 2wd you can get lift spindles which moves the hubs down achieving lift but not sacrificing any shock downtravel.
  7. Oct 15, 2012 at 11:35 AM
    Blacktacoma23
    Blacktacoma23 If your tires don't rub you can fit bigger tires
    CO
    2011 Mall Crawler/84'
    6" BDS DB, 37", Dirt King, Total chaos UCA's w/ Heims, Fox c/o's, 4-banger fenders, 37" Nittos, 4.88 w/ rear ARB, AP Expos, 17x9 Method beadlocks, cab mount relocation, "Insain fab" tub, 5% tint, 10" Rockford Fosgates, Magnaflow 18" custom catback exhaust, AFE intake, Trail Gear bumper, Crown brake lines F/R
    I hated 3" lifts
    Drop bracket :)
  8. Oct 15, 2012 at 1:26 PM
    Sublime
    Phoenix, AZ
    08 TRD 4x4
    Really? DB lifts typically don't have more than 1" of downtravel either. Was it for those big ass tires? I'll try to run 35's my next set!
  9. Oct 15, 2012 at 1:34 PM
    Delmarva
    Delmarva Mayor of TW
    Tucson, AZ
    :facepalm:
  10. Oct 15, 2012 at 6:35 PM
    Blacktacoma23
    CO
    Wasn't for the tires, DB only way for more than 3" with a 4x4 (and rides better:thumbsup:)
    Fox resis, TC uppers w/ Heims and no CV angles:D
    3" (SAW c/o's) with 315's
    6" BDS w/ 315's
    Haha think what you want about my rig :laugh:
  11. Oct 26, 2012 at 8:01 AM
    XREILLYX
    XREILLYX Well-Known Member
    Reilly
    okanogan
    07 white double cab
    blacked out taillights, White OME 885X's, Billy 5100's around, added 120v/aux charger, Browning sticker!
  12. Oct 26, 2012 at 3:07 PM
    Wishbone Runner
    Wishbone Runner Because 4R
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    That is off of Guanela, is that a trail or just a dirt road?
  13. Oct 26, 2012 at 5:45 PM
    Blacktacoma23
    CO
    This is a big switchback with a view, there is trail before and after where the pic was taken.
  14. Oct 26, 2012 at 6:00 PM
    Sublime
    Phoenix, AZ
    08 TRD 4x4
    Thats a beautiful pic!
  15. Jul 19, 2014 at 9:57 AM
    urban
    urban Well-Known Member
    Illinois/Michigan
    12 DCLB sport OME lift
    305/65r17's on 17x9.5 Rotiforms Cab mount chop 4.10 gears Detroit true track OME 885's Dakars Camburg UCA's Undercover SE Weathertech liners and visors Black headlight mod Debadged Rock Blokz mudflapps (oversized)
    How much down travel does the average ext. travel coil over offer? I am running the OME kit with 885's on a DCLB and have about 3" downtravel. I am thinking about getting some 888 coils which would raise the truck about .5" therefore reducing down travel to 2.5" Right now the thing rides great... Do you think a .5" reduction will make a noticeable difference? I mean honestly with a UCA and the right spacer you can probably get mid travel numberss... The limiting factor with the OME kit in the front seems to be that the shock never gets fully compressed before it hit the bump stops. OME front shocks have a length 16.26" - 21.38" so a difference of about 5.12". The ratio of shock to wheel movement is about a factor of 2 so that equates to almost 10" or actually usable travel with spacer and bump stop tuning. This is what I plan to do in the future to optimize the OME kit. In the back the big limiting factor is the extended length of the shocks that limits droop. The OME shocks are actually damn impressive for having 10" of travel with a compressed length of only about 13". If you look at bilstiens and even some of the high dollar components with remote res. will struggle to match that... Some bilstiens will make 10.1" travel but only if they are 16" +. the only problem is that you can run a shock with a compressed length of 15-16" (I would run 15" to keep a healthy margin so you don't collapse a shock) I actually emailed OME to see if they have a longer shock with the same valving for in the rear. I will let you know their response.
  16. Jul 19, 2014 at 11:43 AM
    urban
    Illinois/Michigan
    I actually went and did some research and the best coilover I saw, can't remember which one now, only offered potentially ~one inch more travel tops considering both are optimized to your setup. I don't even think the rest of the suspension can exceed 10" without longer A-arms anyways.
