Suspension ?????
Discussion in 'Suspension' started by GreyGhost, Oct 15, 2012.
  1. Oct 15, 2012 at 8:50 PM
    GreyGhost
    GreyGhost [OP] Well-Known Member
    Eli
    Placentia, Ca.
    2020 TRD Sport
    I'm new to the lifted truck scene. I don't do any off roading. I just like the look of the truck. The front has Icon coil overs set at 2.5 inches. The rear is stock. I want to lift the rear to make it level. What is the easiest way to accomplish this. I was gonna go the lifting block route since its only for looks. Should I also replace the rear shocks. If so what shocks are recommended. Also would a 2inch block make it level. Thanks for any info.
  2. Oct 16, 2012 at 11:07 AM
    blazer190
    blazer190 Active Member
    Walker Louisiana
    TRD offroad 4X4
    One inch
  3. Oct 16, 2012 at 11:39 AM
    JRod4928
    JRod4928 Well-Known Member
    Pittsburgh
    '12 Tacoma SR5
    Extang Trifecta Tonneau WeatherTech Floor Liners Pop & Lock Tailgate Lock Antenna X Black Mesh Grillcraft with Tacoma Badge (Upper) and Cross (Lower) 18" BMF Wheels / Cooper 31.5" Tires 2" Leveling Kit
    What he said.
    Leveled is 1.75 or 2 (every truck is a little different). So 1" is plenty. And as far as using blocks goes, I wouldn't want to use anythign larger than 1" or else you'll run into more problems. If you're concerned - go with AAL.
  4. Oct 16, 2012 at 11:43 AM
    JRod4928
    Pittsburgh
    '12 Tacoma SR5
    That is some crazy amount of rake - maybe its just the picture :confused:
    Measure vertically from the Center of the hub to the bottom of the fender on all 4 wheels. The difference is how thick the block needs to be. Based on a 2.5" lifted front, you should only need a 1" block, but by the looks of the picture - I'd guess your difference is larger than 1", which doesn't seem right... Maybe the leafs have settled a bit in which case you're best bet is a new Dakar leaf pack.
  5. Oct 16, 2012 at 11:54 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    I'd go with an AAL. I've got the Icon 3-leaf AAL and am happy with it. You've got such a nice setup in the front, why go with the crappy lift for the rear? I understand that it's not for off roading but you still want it to handle and drive nice.
  6. Oct 16, 2012 at 4:47 PM
    GreyGhost
    Eli
    Placentia, Ca.
    2020 TRD Sport
    I will measure all four locations and post back the results. Maybe then we can have a more definite answer. Although 1" lift seems to be the favorite. What about shocks. Will those be necessary. Whether its the blocks or leaf springs. Thanks guys
  7. Oct 19, 2012 at 10:43 AM
    JRod4928
    Pittsburgh
    '12 Tacoma SR5
    take any measurements?
    new shocks will depend on your measurements. you can buy Bilstein shocks for a cheap price if you're concerned with your stock shock's travel. I have no experience with it, but i've seen people on here run stock shocks with a 1" block or AAL without any issues - depends on your application though.
  8. Oct 19, 2012 at 1:16 PM
    GreyGhost
    Eli
    Placentia, Ca.
    2020 TRD Sport
    ok so finally got some measurements. Here they are:
    Left Front - 23 3/4
    Right Front - 24
    Left Rear - 22
    Right Rear - 22
    So would a 1" block do the trick to level it out or would i need a 2" block. What about shocks. Will they be necessary.
  9. Oct 19, 2012 at 1:35 PM
    Pugga
    Massachusetts
    Looks like you need to raise the rear about 2" so I'd go with a 2" AAL if it were me or the Icon AAL and leave the overload in place. If you don't off road, stock length shocks will be fine although the stock shocks might not do a great job dampening the stiffer leaf pack. I went with the Icon leaf pack and left the overload leaf in place for a total lift of 2". It rides great and I'd definitely recommend the product.
  10. Oct 19, 2012 at 5:13 PM
    Sublime
    Sublime Well-Known Member
    Phoenix, AZ
    08 TRD 4x4
    Lower the coilovers until it's level! You don't need to do anything to the rear! :smack:
  11. Oct 19, 2012 at 5:20 PM
    aphex
    aphex Well-Known Member
    Pittsburgh, PA
    11 DC TRD OR
    Undercover Classic Tonneau, EGR Aerowrap Bug Deflector, Consolevault Custom Safe, Britax Boulevard 70 Baby Seat!, Retro TRD Shift Knob, Factory Bed Mat, Rear Leaf TSB, 265/75-16 BFG All-Terrain KO's, KMC Enduro Wheels, Front Bilstein 5100's set @ 0" w/ Toytec/Eibach Springs, Rear 5100's, TRD Grille Emblem, OEM Roof Rack, AntennaX 14" Billet Antenna
    holy crap man.
  12. Oct 19, 2012 at 5:25 PM
    The Traveler
    The Traveler Desert Chief
    SoCal
    1991 Toyota Pickup 4x4 Prerunner
    2" AAL from Toytec gave me a .5-1" rake. Should level you out nicely.
    Before
    After
  13. Oct 19, 2012 at 6:38 PM
    GreyGhost
    Eli
    Placentia, Ca.
    2020 TRD Sport
    yea man...It looks bad in this pic but in real life its not like that.
  14. Oct 19, 2012 at 6:40 PM
    GreyGhost
    Eli
    Placentia, Ca.
    2020 TRD Sport
    Well i like the lift in the front and want the rear to be lifted and level.
  15. Oct 19, 2012 at 6:45 PM
    aphex
    Pittsburgh, PA
    11 DC TRD OR
    Sall good. It will look sweet when you're done.
  16. Oct 19, 2012 at 6:48 PM
    GreyGhost
    Eli
    Placentia, Ca.
    2020 TRD Sport
    I want to use the lifting block method so my questions is this:
    So with the measurements i have will a 1" block or a 2" block level the rear. And would i need to replace the shocks.
  17. Oct 19, 2012 at 9:13 PM
    JRod4928
    Pittsburgh
    '12 Tacoma SR5
    by the way do you get any weird vibrations with that much front lift?
    with 1" block I'd say you're probably fine without new shocks. with 2" I'd say get some shocks.
    as far as AAL. go with Icon 3 leaf progressive from DSM or Wheelers 3 leaf progressive. for about 1.75" of lift. they're around $170-180
  18. Oct 21, 2012 at 4:55 PM
    GreyGhost
    Eli
    Placentia, Ca.
    2020 TRD Sport
    So given the measurements I have, and if I go with Wheelers 3 leaf progressive AAL, would that get me level or would I still have bro lean. I want it to sit level. Sorry for all the questions
  19. Oct 22, 2012 at 4:24 AM
    JRod4928
    Pittsburgh
    '12 Tacoma SR5
    you'll be juuuuust about level. maybe little-bro lean. :thumbsup:
  20. Oct 22, 2012 at 5:18 AM
    Pugga
    Massachusetts
    If you get the 3-leaf progressive from Wheeler's or Icon, the advertised 1.5" of lift is with the overload leaf removed. Keep the overload leaf in place and you gain an extra 1/2" which would put you damn near dead level.
