Silicone grease for UCA and Shackles
Discussion in 'Suspension' started by aportis72, Oct 15, 2012.
  1. Oct 15, 2012 at 8:51 PM
    aportis72
    aportis72 [OP] Well-Known Member
    Austin
    Supercharger
    What is the best Silicone grease to use for my Camburg UCA and Defined Shackles. I have searched and searched, but these recommend Silicone lube and the only Silicone lube I can find is in a can for like rubbing on not pushing through a Zerks fitting. Should I just buy the 3M stuff in a can and dump it n the grease gun?
    Thanks.
  2. Oct 15, 2012 at 8:52 PM
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
    Super Lube , at least that is what was recommended for the Defined shackles
    I had to order it in at my local auto parts store
  3. Oct 15, 2012 at 8:56 PM
    OZ-T
    Peter North
    British Columbia
  4. Oct 15, 2012 at 9:31 PM
    aportis72
    Austin
    Supercharger
  5. Oct 15, 2012 at 9:32 PM
    92LandCruiser
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
  6. Oct 15, 2012 at 9:33 PM
    OZ-T
    Peter North
    British Columbia
    Super Lube is the lube recommended to me by Defined Engineering specifically for the Defined Engineering Greaseable shackles for 2nd gens
  7. Oct 15, 2012 at 9:33 PM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    yeah thats what mike reccomended to me
  8. Oct 15, 2012 at 10:27 PM
    OZ-T
    Peter North
    British Columbia
    You're welcome
  9. Oct 16, 2012 at 9:01 AM
    aportis72
    Austin
    Supercharger
    I will use the recommended super line for the shackles, but was just wondering for the UCA.
  10. Oct 16, 2012 at 11:29 AM
    Defined
    Defined Well-Known Member
    mike
    southern california
    you can use superlube on all pivots, been racing on it for years. i just dont recommend it for drivelines.
    you can use whatever you want but just dont use a petroleum based grease on delron bushings
