2013 Leveling Kits Out?
Old 10-22-2012, 07:24 PM   #1
Tmbrooks [OP] Tmbrooks is offline
Tmbrooks is on a distinguished road
Tmbrooks's Tacoma Gallery
Anyone know of any 2013 leveling kits out? Just trying to level the front 2 inches or so.
Les Schwab claimed that no one has released leveling kits for the 2013's yet...
This is for my 2013 Double Cab Tacoma TRD Sport
Old 10-22-2012, 07:25 PM   #2
Mayor of TW
Delmarva is one of the sharper tools in the shedDelmarva is one of the sharper tools in the shedDelmarva is one of the sharper tools in the shedDelmarva is one of the sharper tools in the shedDelmarva is one of the sharper tools in the shedDelmarva is one of the sharper tools in the shedDelmarva is one of the sharper tools in the shedDelmarva is one of the sharper tools in the shedDelmarva is one of the sharper tools in the shedDelmarva is one of the sharper tools in the shedDelmarva is one of the sharper tools in the shed
Delmarva's Avatar
Army: Vet
Delmarva's Tacoma Gallery
Welcome to TW
2013 is identical to 2005+ Tacomas (suspension wise), so any lift or level kit will do for an 05+ Tacoma (6 lug).
Old 10-22-2012, 07:35 PM   #3
Good to know! Any recommendations on brand for a 2 inch level kit?
Also, with a 2 inch leveling kit up front, will I be able to fit 285/70/17's all around?
Old 10-22-2012, 07:37 PM   #4
Mayor of TW
Delmarva's Avatar
Army: Vet
For price, you can't beat a Bilstein 5100 lift in the front to level out with the rear. Look up Downsouth Motorsports (http://www.tacomaworld.com/forum/downsouth-motorsports/) and PM Sonny... he'll take care of you.
Now, if you want a better lift that performs well offroad, look into adjustable coilovers as the way to go.
Old 10-28-2012, 03:06 AM   #5
just ordered a pair, thanks for the info, really helped out.
Old 02-11-2014, 10:19 PM   #6
Nephree is on a distinguished road
Nephree's Avatar
Nephree's Tacoma Gallery
If the Billstein 5100's are set at 1.75" up front, what (if anything) needs to happen in the rear, even if leveling is the goal? I've heard that an AAL is still preferred, no?
I have the same goal as the OP.
Old 02-12-2014, 08:26 AM   #7
JRod4928 is one of the sharper tools in the shedJRod4928 is one of the sharper tools in the shedJRod4928 is one of the sharper tools in the shedJRod4928 is one of the sharper tools in the shedJRod4928 is one of the sharper tools in the shedJRod4928 is one of the sharper tools in the shedJRod4928 is one of the sharper tools in the shedJRod4928 is one of the sharper tools in the shedJRod4928 is one of the sharper tools in the shedJRod4928 is one of the sharper tools in the shedJRod4928 is one of the sharper tools in the shed
JRod4928's Avatar
JRod4928's Tacoma Gallery
EDIT::: Just realized someone else bumped this thread and it's like 2 years old.... I'll leave the info here for future reference incase anyone cares
You'll have to do some trimming. That's a 32.7" tall tire
The wheel backspacing plays a huge part in this as well. Depending on what your backspacing is, you'll have to make sure your tire doesn't hit the UCA, but 285's probably won't hit the UCA with stock tires (or after market tires, since most people buy wheels to push the tire outside of the fender, which helps the UCA interference issue) from what I've read on here... But if your backspacing is too small, you'll probably be hitting your fenders, hence the trimming.
For reference, I have 5" backspacing with 265/65/18 (31.5" tire) and I had to remove the little flap on the front bumper, because it was rubbing.
Your alignment will move the tire forward/backward as well, which will affect things a lot.
Leveling kits Glocker23 2nd Gen. Tacomas 12 05-16-2012 06:11 AM
leveling kits dfndDARUMA Hawaii 11 04-20-2012 09:22 PM
leveling kits? loaderman82 2nd Gen. Tacomas 0 10-03-2010 08:35 PM
Leveling kits? Norcalkid 2nd Gen. Tacomas 0 04-11-2010 07:56 PM
leveling kits derekAV Suspension 0 11-14-2009 11:32 AM
