Tacoma World Forums GreySky72's 2008 Tacoma TRD Sport 4x4, covered in mud and PackerfanXD's 2007 Tacoma TRD at the Phoenix Meetup
Register Site Information Glossary Calendar Search Today's Posts Mark Forums Read
3 inch lift
Old 08-13-2007, 01:23 PM   #1
TommyTaco is on a distinguished road
TommyTaco's Tacoma Gallery
3 inch lift
How much did you all pay. I got a quote yesterday for about 1600 parts and labor. Is this legit?
__________________
07 Impulse red Double cab
SR5 V6 4.0L 4X4 Shortbed
Old 08-13-2007, 03:21 PM   #2
Carolina Alliance
LQQKatmy06 is on a distinguished road
LQQKatmy06's Avatar
LQQKatmy06's Tacoma Gallery
Ya thats about the going rate for a SKYJACKER. Buy a TOYTEC and do it yourself its not really that hard took me about 4 hrs. If you live close to me I'll help you.
Old 08-13-2007, 11:42 PM   #3
reid will become famous soon enough
reid's Avatar
reid's Tacoma Gallery
Toytec cost me $300 and installed it myself, not that hard. Best upgrade for the money you can do for your truck.
__________________
Reid
Old 08-14-2007, 09:04 AM   #4
nd nd is online now
AKA: "The Velour Fog"
nd is infamous around these partsnd is infamous around these partsnd is infamous around these partsnd is infamous around these partsnd is infamous around these partsnd is infamous around these partsnd is infamous around these partsnd is infamous around these partsnd is infamous around these partsnd is infamous around these partsnd is infamous around these parts
nd's Avatar
Gender: Female
nd's Tacoma Gallery
I have the TRD so i wont be replacing the coils or shocks if when/if i get a lift. I will just use toytec's basic kit that sells for $210. after i get all the accesories (diff drop kit etc...) it should run me about 300 total, then i will instal it myself. 1600 sounds steep for just a 3"
__________________
When life gives you lemons, just say 'Fuck the lemons,' and bail.
Old 08-14-2007, 09:43 AM   #5
rick has much to be proud ofrick has much to be proud ofrick has much to be proud ofrick has much to be proud ofrick has much to be proud ofrick has much to be proud ofrick has much to be proud ofrick has much to be proud ofrick has much to be proud of
rick's Tacoma Gallery
it probably utilizes front coil overs instead of coil spacers which are $800-1100
__________________
Old 08-14-2007, 10:06 AM   #6
nd nd is online now
nd's Avatar
Gender: Female
nd's Tacoma Gallery
yeah but unless he is going to do alot of hardcore offroading his factory shocks work fine with toytec. No need to blow all that money unless he is really gonna put those heavy duty parts to use
__________________
Old 08-14-2007, 10:20 AM   #7
I don't plan on doing any extreme off roading. What do these kits include? What exactly are spacers? How big of a tire can I go with a 3 inch lift? Thanks for all of your help.
__________________
Old 08-14-2007, 11:43 AM   #8
nd nd is online now
nd's Avatar
Gender: Female
nd's Tacoma Gallery
if you go to toyteclifts.com you can check out everything that comes with these lifts. If you have the factory suspension you may want to go with the one that comes with OME springs, that set up runs you around $300. you will probably want to look at some of the options at the botom like the front differential drop kit etc.... things that will keep your angles as close to stock as possible to keep your joints from wearing. I think some people are running 33's with a three inch lift with minimal rubbing, but i plan on going with 32's. anyway, there are alot of people on this site that can give you more/better info than me. hopefully one of them will respond.
__________________
Old 08-18-2007, 01:46 AM   #9
reid's Avatar
The toytec lifts come with everything you need minus the tools. The front spacer lift is actually a set of aluminum blocks that compress your srings about 1.25" more than stock. They also come with a 0.75" spacer that moves your spring/strut setup lower. This 2" change close to your engine equals 3" at your tire. The add-a-leaf rear suspension lift is exactly that, an extra leaf spring that you add to the leaf pack with raises your rear 2". I have installed this kit as well as the 1" diff drop a few weeks ago. I have not yet had time to take pictures, but it will come soon.
I have just ordered 265/70/17 tires for mu truck. They are mickey thompsons and equal 31.9" I have heard that most people can run 32"tires with this lift, but 33"cause rubbing.
Be carefull which tires you order. 265/70/17 in another brand actually equal closer to 31" So if I chose that brand I could go up a size.
__________________
Reid
Display Modes
3 inch body lift and BFG's Flaadog 1st Gen. Tacomas 28 12-24-2007 02:03 PM
6 inch lift tcboss Suspension 5 11-22-2007 04:11 PM
best 3 inch suspension lift? tcboss Suspension 25 10-05-2007 09:36 PM
tires for stock wheels with 3 inch lift?? redline929_e Wheels & Tires 2 08-01-2007 03:44 PM
new trd owner. 3 inch lift??? need info redline929_e New Members 4 07-19-2007 05:26 PM
Copyright © 2008 Tacoma Forum
