OME lift kit, anything else I might need?
Discussion in 'Suspension' started by Imageoguy, Nov 23, 2012.
  1. Aug 7, 2014 at 7:19 PM
    #21
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
  2. Aug 7, 2014 at 7:34 PM
    #22
    V5ioV
    V5ioV My drinking team has a wheeling problem
    V5ioV
    Out n 'bout
    '13 Pewp Water Slut
    King 2.5 Rem Resi Ext Travel w/comp adj w/700# springs, TC Uni-Ball UCAs, ARB/OME Dakar Leaf Springs w/ King 2.5 Rem Resi w/comp adj and custm eyelets, Stealth Custom Series F-5 Wheels wrapped on: 285/75/16 Fierce Attitudes, BORA 2.25 wheel spacers, GOODRIDGE extended Brake lines, Triple-6" Double Row LED Light Bars behind lower grill, ATFL MOD, TRD Ball Type Shift Knob, Husky WeatherBeater Floor Liners, 60'' HiLift Xtreme, 4xInnovations Bolt-On Sliders w/Kickout, Spring Hanger Skid, Custom BlackPipe Fabs CMC and custom FYL Bed Rack, CVT Mt. Shasta RTT, Trasharoo, 4xInnovations HiLift Bedside Mounts, 4xInnovations Front Skid Plate, TOYWERX Ghost Raptor thin-lip Satoshi Grill, RedLine Hood Struts, 4xInnovations Transmission Skid and T-Case Skid Plates, Wheelers Rear SuperBumps Bump Stops, All-Pro Off Road U-Bolt Flip Kit, UltraGauge, ARB OBA, Pelfreybilt HC rear Bumper, Rotopax system (Single Mounting Plate and Bed Rail Mounting Plate both with LOX handles.
  3. Aug 7, 2014 at 7:57 PM
    #23
    V5ioV
    V5ioV
    Out n 'bout
    '13 Pewp Water Slut
  4. Aug 7, 2014 at 8:17 PM
    #24
    medic2230
    Murph
    Bama! Roll Tide
    Here's the OME chart for center bolts.
  5. Aug 7, 2014 at 8:27 PM
    #25
    medic2230
    Murph
    Bama! Roll Tide
    Wheelers has some in 3/8" x 4". Not OME I believe.
  6. Aug 7, 2014 at 8:38 PM
    #26
    OZ-T
    Peter North
    British Columbia
    They don't have to be OME as long as the dimensions are correct
  7. Dec 14, 2015 at 5:26 PM
    #27
    JanBoothius
    JanBoothius Well-Known Member
    Jan (Pronounced Yon)
    Upstate New York
    2015 TRD OR DCSB 6 speed
    Heavy stuff big tires drives like hell
    Is the center bolt that comes with the Dakars long enough for the D29XL AAL?
    Edit: After continued Googling (on a proper computer this time), I found this answer on Headstrongoffroad.com: "Leafs can be installed using the existing center pin provided with the Dakar packs eliminating the need for longer ones."
    Edit #2: Confirmed, installed the D29XL with the stock Dakar center pins no problem.
