Want a Higher Lift!!! HELP?
Old 01-05-2013, 10:11 AM   #1
Know Hope
RoyalThunder is on a distinguished road
RoyalThunder's Avatar
RoyalThunder's Tacoma Gallery
Okay well im under a budget so i wouldnt wanna spend over a grand
I currently have 2.5" spacers in front and 1" block in rear which is still low and i wanna go a bit higher so what can i get to get higher than this? I want to know all my options and also the cheapest!
At least to a 3" or 3.5" lift i dont know or what do you guys reccomend is the next cheapest lift higher than what i got.
It can be a body lift or suspension lift i just want to know all my options to decide
( no worries i dont mind a low end lift since im not gonna be doing major offroading)
Also I would like to know if this would fit my truck
2002 Toyota Tacoma PreRunner 2WD(6lug)
Old 01-05-2013, 10:17 AM   #2
rockgecko03 is one of the sharper tools in the shedrockgecko03 is one of the sharper tools in the shedrockgecko03 is one of the sharper tools in the shedrockgecko03 is one of the sharper tools in the shedrockgecko03 is one of the sharper tools in the shedrockgecko03 is one of the sharper tools in the shedrockgecko03 is one of the sharper tools in the shedrockgecko03 is one of the sharper tools in the shedrockgecko03 is one of the sharper tools in the shedrockgecko03 is one of the sharper tools in the shedrockgecko03 is one of the sharper tools in the shed
rockgecko03's Avatar
rockgecko03's Tacoma Gallery
A 1" body lift is probably going to be the cheapest route. $100 or so. Just make sure you upgrade all your hardware to grade 8 and I wouldn't go any higher.
At 3.5" of susp. lift in your front end, you're cv's will probably want to die. (assuming you're 4wd)
Edit: pick up an AAL for the rear and ditch the block. That'll also help to level you out as it looks like you've got a little bro lean going. Unless that's the look you were going for.
..and yes, that lift from toytec will fit your truck as you are a 1st gen and not a 5lug.
Old 01-05-2013, 10:24 AM   #3
ah...you're 2wd... nvm my comment about the cv's then
If you want cheap, then stick with what you have for the suspension. You don't want to stack a suspension lift on top of another suspension lift. You may look into some lift spindles since you're 2wd. I dunno what the options are on those for 1st gens.
Old 01-05-2013, 10:26 AM   #4
Know Hope
So i would get a 1" body lift on top of what i already have?
Because that wouldnt make sense if i take of what i already have and get a 1" lift since what i have is higher
And what AAL do you reccomend?
Old 01-05-2013, 10:30 AM   #5
JDMcQ is one of the sharper tools in the shedJDMcQ is one of the sharper tools in the shedJDMcQ is one of the sharper tools in the shedJDMcQ is one of the sharper tools in the shedJDMcQ is one of the sharper tools in the shedJDMcQ is one of the sharper tools in the shedJDMcQ is one of the sharper tools in the shedJDMcQ is one of the sharper tools in the shedJDMcQ is one of the sharper tools in the shedJDMcQ is one of the sharper tools in the shedJDMcQ is one of the sharper tools in the shed
JDMcQ's Avatar
JDMcQ's Tacoma Gallery
A body lift raises the body only in relation to the frame. You have spacers, which raise the vehicle (body, frame, all) via the suspension.
Have you considered replacing your springs and shocks? A good set of coils and leaves will cost you about a grand and might give you what you are looking for. Your current springs have settled in the 11 years since new, the new stuff will correct that and add lift. Your vehicle will ride and handle way better than it does now as well.
Old 01-05-2013, 10:31 AM   #6
you can do a BL on top of what you already have since you can do a BL and a suspension lift together. Check out http://www.4crawler.com/ for body lift options.
the toytec AAL will do fine for you. You can also check out wheelers: http://www.wheelersoffroad.com/9504tacoaal.htm
Old 01-05-2013, 10:33 AM   #7
x2 and this would be preferred. I only gave the cheaper suggestion
Pre-Runner, can I lift it higher? pschmidt 1st Gen. Tacomas 11 11-30-2012 05:41 AM
6" or higher lift show off! likeoof808 2nd Gen. Tacomas 17 09-10-2011 06:43 PM
Rear end still 1.5" higher after lift 02stepsidetaco 1st Gen. Tacomas 8 09-06-2011 10:41 PM
Will 5100's lift my truck higher than now? VirginiaBound Suspension 8 03-22-2010 12:00 PM
3 inch lift or higher $ odyssey1 1st Gen. Tacomas 2 03-08-2010 07:36 PM
